Nissan Altima
-juice
Don't you get more than just the engine for that price? The V6 may have better longevity because it is less stressed to pull the weight. It's quicker, more fun, perhaps even safer in passing situations. It's likely quieter and smoother at trip speeds, too.
Cons? Gas mileage will probably be 2-3mpg lower in the real world, plus it burns premium. Range also suffers, and insurance will be a little higher. More speeding tickets?
I would still get the V6, because what price can you put on happiness?
-juice
I would assume wind noise is the same in the two models, and the V6 probably has more tire noise because of the low-profile performance tires. The ride in the V6 is also much firmer.
Also, we had a tough time deciding on a car: Camry vs. Altima. The seats in the Camry were uncomfortable on a long test drive. We rented the 2002 Camry to take it out of town. I am 5'9" and my husband is 6'3" and the seats didn't seem long enough. The Altima and the G20 were both comfortable esp with the 8 way power seats.
-juice
I don't know how the car drives with regular (87) gas, but I'll never know since I won't put anything else in. Especially at these gas prices.
I was getting better gas milage in the beginning but I'm driving a little faster now so MPG has dropped off.
Since then I switched to Premium and no more knocks. So there you go!
Any how, shouldn't knock sensors be in place to retard ignition timing and prevent knocking? Where you just hearing the start of knocking, or was it sustained? If it's the latter you may have a bad knock sensor.
-juice
http://www.nhtsa.dot.gov/cars/problems/tsb/
Select Vehicle Search, then enter the information. They list 7 TSBs for the '02 Altima.
I noticed there are 9 TSBs out for the '02 Camry, so I guess we Altima owners are doing OK.
The 2.5 I4 Altimas can use regular gas. This might be one of the reasons why the HP rating dropped from 180 to 175. Maybe Nissan made a decision that 5 HP will make less of a difference than requiring premium fuel to be used. Especially when the gas prices were so high.
Don't let the engine use the knock sensors to retard timing. It can't be that good.
Of course you could have bought the Honda Accord. It's V-6 can use regular gas.
The same is generally true of fuel grade recommendations. Modern engines are tuned from the factory for a particular octane. And the fact is that using a lower octane can result in pre-ignition or knock. Luckily the knock sensors and ECU's in these cars will sense it and dynamically retard the timing to compensate. Car makers don't recommend premium fuel just because it sounds cool. They do it because they need it to attain those hp numbers. So, if you choose, you can use a lower octane. But, it does extract a performance penalty and possibly hurt your mpg a bit as well.
I think even the Accord V6 recommends premium. The exception is the Camry's V6, which makes far less power than the engine in the ES300 (premium required).
If wonder if CR will change their tune about oil change intervals after the Toyota sludge issues.
-juice
Since premium fuel is only like 1.15 a gallon here in Md., I figured I would give it the best.
Toyota's Camry and ES300 [with the six] are indeed cars where the most power and least fuel consumption will be achieved with premium fuel, but either will run on regular [computers, as noted above]. Honda has chosen to go a different route on most Honda-branded engines, as opposed to Acura, where they go for a few more hp and recommend premium on most engines.
Also, I noticed the prices almost down to invoice levels on Carmax's website here in Maryland. That true pretty much everywhere now that the Altima has been out for a couple of months?
They publish the higher figure (of course), but then mention that some power is lost with regular fuel.
-juice
I don't notice a difference, but they say by the SOTP you can't feel less than 5 horses.
-juice
Im looking at the S model with a stick. Has anyone had any problems with theirs. Also the invoice price is like 16,500. What kinda pricing have you guys been getting on your Altima?
Is the holdback enough for most dealers. The dealers I have gone to have been very rude. I cant imagine they get many sales. One dealer told me I couldnt test drive one without talking price, also said no brochure is available. Not very friendly people. This isnt the first time Ive gone to a Nissan dealer and gotten [non-permissible content removed] sales help. The price on the base S on the window was like 21,000. He said he can get me in for like 18,800, but knowing the invoice is 16,500. I doubt I'd be willing to pay much more then that.
I own 2 toyotas and I'm over them want to try something new. Looked at a low end Honda Accord but was not impressed with the interior. The engine is small too. The Altima interior appears to be a lot more Plush then the Accord.
You should try putting in premium to see for yourself.
-juice
I don't mind i still got it for 3% over actual dealer cost..
Thanks in advance,
Carguy585
You may recall that most cars these days [because of the sudden-acceleration hoo-hah] have an interlock between the trans and brake pedal - you have to have your foot on the brake to take it out of Park. The shift lock button or feature is designed to override that if the switch fails for some reason.
Any word on if they plan to update the interior or not? A good friend of mine really likes Altimas, but he said the interior looks too cheap. His car is like 8 years old, so he will me in the market soon and might get an Altima if they change the interior. Thanks.
"Edmunds.com Says: Nissan nails a home run with the bases loaded, going from also-ran to midsize sedan class champion in one fell swoop. The Altima rocks. "
http://www.edmunds.com/reviews/roadtests/spin/49765/article.html
The Altima got a major make over for 2002 so I would like to hear from 2002 Altima Owners what they think of their car....thanks in advance.
Check it out by following the link in the "Helpful Links" box on the left sidebar of this page.
Pat
Sedans Message Board
-juice
I think the Altima is one of these genre-busting cars. It's somewhere between the utility of a typical family sedan and the performance of a sports sedan. You get most of the utility of a Camry and most of the performance of a WRX all in one package.
My budget would have forced me to buy the 4-cyl. Passat anyway and that would have been even worse.
I think Edmunds did a good job with their comparo. I don't mind my Altima coming in second. I may buy the Passat once I'm in my 30s but no way would I be caught dead in that car right now.
The Altima is the only sports sedan in this group. I don't mind smokng a BMW 528i in my Altima either - mine is an automatic and I'm sure his BMW was auto too.
Finally, all of you guys should use synthetic oil. It makes a HUGE difference. I'm only going synthetic from now on. I may start changing the old myself to offset the additional cost because it costs $40 bucks at Midas.
And just because the Passat is slower doesn't mean anything. Some people (myself included) would buy it because of its interior amenities (close to a luxury car costing 2x more) and its cachet.
vocus - Different strokes for different folks, I guess. As long as my car is decently put together and built to last, I don't particularly care how the interior looks. But that 240 hp engine puts a smile on my face every time I get in the car.
