already changed the air/fuel sensors on my wife's 2003 highlander w/ V6. Now I am going to install a new O2 Sensor. I see that the sensor passes through a grommet in the floor pan, but on first glance its not real obvious the easiest way to get at the connector from inside. Is there an easy access through the carpet ? (I'm really hoping I don't need to pull the seat or carpet liner to get this installed)
I have a 2002 HL V6 AWD with VSC (Automatic). It has been the best car ever, now has 117K miles, and requires older car oil. I've been experiencing repeating thumping when decelerating, whether in gear or neutral. Not sure if it is related to brakes, transmission or something else. Didn't see anything quite the same on the forum so far. Thoughts and experiences appreciated.
" I see that the sensor passes through a grommet in the floor pan"
I don't think so. If its the rear bank O2 sensor, there is a connector at the back of the engine, and I needed two people to disconnect it. See post 4360.
My new highlander was delivered from another dealership with 1kmi oil change sticker. The dealer I purchased truck from said I don't need to change it until 5kmi and also said my truck comes with synthetic which can be changed every 10kmi.
Should I change it at 1kmi?
Also, my truck calls for 0w20 but I stocked up with 12 or so gallons of 5w30 synthetic. Can I use 5w30 instead (Pa area)?
The shelf life of synthetic oil is at least as long as dino oil... meaning, you will expire before the oil does.
Using the heavier weight oil could mean 1/10 less mpg. If you live in a very cold climate, that oil could make it marginally more difficult to start in the morning.
Change it at 5K if you want to be overly cautious. I change my HL oil ever 10,000 miles (just approaching 120K now) although I COULD be going over twice that mileage between changes.
I iust installed 4 new Michelin ltx m/s2's on my '05 Highlander. While driving 70+mph why does my steering wheel vibrate? I'm very uncomfortable when this happens.
Try rotating the tires side-to-side. If that doesn't solve it, try doing a regular tire rotation. If that doesn't solve it, are you running on the factory stamped steel wheels or the factory alloys? If running on the stamped steel wheels, try switching to the alloys.
My dealer did it. My guess was the balancing too. If I don't drive high miles should I do an alignment? Here in WI theres alot of potholes in the winter so I was gonna wait until Spring.
Other than the balancing, not sure on the vibration but I willl tell you that I put some of the higher quality Michelins on my 04 Highlander. When I first put them on, I could feel a sort of "clunk" when I turned sharply right or left. Had it checked out. Couldn't find anything; garage thought that since the tires were softer for the better ride, they were giving on a sharp turn and that was what I was feeling. The edges became slick in no time and I needed new tires at 20,000 miles on them. (I think the 04 was the first year there was quadra-track so I always thought that had something to do with it.)
Probably unbalanced, I always recommend General HTC Tires. Better price better ride. Check out tire rack for consumer comments. As for the clunking sound check to see if any service bulletins were issued by Toyota, I seem to remember something about that. I have an 03 HIGH/ 148K miles The Goodyear tires stink, would assume Michelin would be great.
I have found that calling around on tires works. You can save 30-40 bucks per tire
Now let's say I bring it back to get re-balanced and they also check the weights, but I run into the same problem? What's else could it be?
I also changed the battery recently and my Highlander just barely turned over yesterday. Could it be something like the alternator or it might need a fuel injection cleaning?
Okay I just got back from the dealership and they tell me that one tire was bad. It had a spin rate of 181 which is one of the worst tires they tested they say. But. The new one has a spin rate of 17. I'm not sure what all this means but what concerns me the most is why they put the bad tire on in the first place. They tell me it coulnt have been avoided. Is this true?
We've had a 2012 Highlander SE for a few weeks now. When we first got the car, I wasn't thrilled with the steering. I would have called it mushy and imprecise. But now both I and my wife are concerned. I can can move the wheel back and forth about 1/8 turn at highway speed and still be going in a straight line. Reminds me of a 70s American boat with power steering -- like the 1977 Jeep Wagoneer I once owned. My wife has complained that it seems to "wander" on the highway and doesn't handle that well. I noticed the one test drove before buying had steering that was less responsive than I'd like, but this has me worried. I'm used to driving a BMW -- and this is not even close.
Anyone else have a similar experience? Do we have a problem -- or is this the normal behavior and just a bad design?
Not wishing to end up in a feature on 60 Minutes ...
What you are describing is uncharacteristic. The Kluger/Highlander handling is not exciting, but very predictable. There should be understeer and it should feel a bit "mushy" if you are used to a good handler like a Subaru or BMW. The up side is that there are huge reserves of safety.
I would suggest that you check tyre pressures precisely using a good (recently calibrated) pressure gauge. You can then try lifting pressure about 2lb above recommended.
I have found with modern cars that it is vital that you have a four wheel balance and wheel alignment done regularly (about every 10-20,000 km). This dramatically improves handling and reduces tyre wear; I am getting 95,000km from a set.
Finally, adjust your expectations. If you are used to driving a BMW which has superb handling, go and try a few more routine vehicles. You may find that your tastes have become just a little too refined!
Something is wrong with your steering. There should be no play in the wheel. An eighth of a turn back and forth is definitely a concern. Off to the dealer.
luckyseven - I've spent a few hours googling and can't seem to find instructions for water pump swap on a Gen 2 Highlander from the PS wheel well. Nor can I figure out how to PM you on this Edmunds forum (and I'm a techie guy). Any leads in the right direction are appreciated.
I can't help with the procedure but I WOULD suggest that you install a Toyota water pump. I have friends that own auto repair shops and I've been told aftermarket pumps don't last as long as the factory part and can cause timing belt problems if they fail. These shops would normally install aftermarket parts but not for this car.
One shop had a HL in for repairs after an aftermarket pump failed that they'd installed only a year before.
I hope you post the directions for wheel well replacement if you find them. I'm nearing 125K on our '03 HL and plan on waterpump and timing belt replacement in the coming months.
I've got a 2012 Highlander Limited V6 that steers crazy. I've been driving a Cadillac SRX . I have terrible torque steer to the right on this vehicle and no matter what speed I'm traveling have to push down to the left on the steering wheel to keep it from going to the right. If I punch it the torgue steer,(pull to the right), is unbelievably bad. I am so disappointed. Dealer says it's normal.I say BS. Have you or anyone else experienced the "Hard" pull to the right when accelerating?
It is time to see someone in higher authority at your dealer. Whoever told you that your steering is normal is 100% wrong. If you can't get satisfaction take your Highlander to another dealer.
Hint: Try going on toyotanation highlander forum, there was a poster who replaced the water pump by himself and he posted a short write up.
Well, dang. Anyone have any experience with a Check Engine Light (CEL) and DTC P0174? Hauling up through the mountains of western Maryland in the snow, and "bling!" a CEL and VSC light. Grumble. Took an unplanned exit and found a place to stop to do a quick flashlight check (did I mention it was night?) and couldn't see anything. Decided to ignore it and continue the weekend, which happened to have the HL parked all weekend, then the ~150 mile trip home today. Seems to run fine, although the dash info says I only got 18 mpg on the highway. Something I'd expect if the computer couldn't figure out how to remedy a lean condition. My scanner reveals a DTC P0174, a generic code for a lean condition, bank 2. Generic meaning it is a code required by the feds on all cars which have to have the OBDII system on board, which is just about everything since '96. So its not a Toyota-specific code and its explanation is not specific. I initially thought, oh well, I need another O2 sensor (replaced bank 1 years ago, see post 4360). However, research shows many things could contribute to a P0174 - vacuum leak, Mass Airflow Sensor (MAF), O2 sensor, etc. If it were a MAF I would expect to get codes from both banks (P0171 and P0174), and I only have a code for bank 2. Fyi, bank 2 is the front row of cylinders on the V6.
Has anyone had a P0174, and if so, what was the diagnosis/repair?
I just took my 2002 Toyota Highlander in for a tripcheck...my front brakes have about 43,000 miles on them...I thought sure they'd need to be replaced. But my shop said the rotors are a little rough, but not bad enough to replace...and the brakes have between 30% and 40% of the pads remaining. Now, my rear brakes have been replaced twice in the last 50,000 miles.
How can this be???? This is an AWD vehicle...do front brakes last that much longer ???
No, I'm not sure why you'd have different wear on the back than on the front. My 2001 Highlander is also AWD with the V6. I replaced all of my original pads, front and back, last summer at 80,000 miles. And then, only because the brake material on the inner pad on the right front wheel had disintegrated, which I'm told sometimes happens when they get old. All of the remaining 7 pads still had at least 1/8" of material on them; the wear sensors hadn't begun squawking.
When your mechanic replaced your rear brake pads, twice, did you get the old parts back? If so, do you remember how much brake material was left on them?
If indeed the rear brake pads needed replacing, I would think a reputable shop would have suggested further diagnosis to find out why they were wearing out faster than the front. Based on my experience and what I've heard from others here, the brakes should be wearing more-or-less evenly front to back.
Toyota seems to be having, historically, problems of overheating the new electric power steering system. Overheats and then drops back into derating mode, less stearing effort help.
2012...
May have reduced the "normal" power assist level to alleviate the above instances.
Did you happen to notice the Trac system or VSC activating?? More than once or twice..?
On the RX or HL without DBW engine dethrottling during a trac or VSC event is accomplisheded via EFI fuel starvation. No way to close the throttle plate so the HOT oxygen sensors see PURE oxygen for brief period(s). That appears to somehow have an adverse impact on those sensors for some period after and a CEL is not altogether unusual.
Generally clears within a few drive cycles.
I have had instances of dirty MAF/IAT sensors throwing a diagnostic of only one lean bank. So I would first clean the MAF/IAT sensor elements.
I'm coming up on 80k miles and wanted to get an idea of what maintenance needs to be performed. I don't prefer dealer packages because you pay them to just "check" things. Can anyone give me a guide to follow and what fluids should be changed at certain intervals for every 30,60,90k?
The Edmunds Car Maintenance Guide will tell you what Toyota recommends be done and when. Same info that's in the owner's manual.
Dealers like to up-sell stuff. You may decide you need some of those "extra" services, but you're right. You should tell the service writer what you want done, not ask for a "90,000 mile service".
Can someone provide me with a guide to what they have followed for their Highlander's with high mileage? I would just like to know what others have been following over the years as far as when they changed fluids, what type of fluids were changed, etc....
If you look at this below for my HL it still shows that you have to pay the dealer to "check" things which I do not want to do. I figure they already do at oil changes, why give them more money to look around.
I recently purchased a used 2009 Toyota Highlander limited with 26000 miles. I currently have 27600 miles on it. I called local toyota dealership here in Plano, TX for a quote on getting the 30000-mile recommended service and was quoted $540. Recommended service at this mile include oil and filter change, air filter change, carbin filter change (dealer sells for about $17.00), then a bunch of check this and check that. Is $540.00 about right for this service? I called another foreign car repair shop and was quoted $181. I asked what they check and they repeated everything on the toyota's manual for 30000 mile service. Is there something to gain by paying extra to have this service done at toyota? Toyota service guy even told me they flush coolant or brake fluid but that service is not recommended at 30000 miles. Can somebody with 2nd generation H/L give me their opinion on this? I want to save money but also want things done right. The other repair shop have ACE or something certified technicians and have been around for over 25yrs.
Do not even bother. I've never had one of those "checks" done on my 2002 Highlander Limited with 75K miles and all is good.
IF you feel the need to get those items checked, go to a AAA auto service center and have an oil/filter change along with tire rotation and they will check everything else for free. Be prepared to have the cabin filter replaced (it is a tad of work to get to it) as 30K on that filter is more than enough. Save your money from your Toyota dealer (mine wanted over $700 for the same service) and spend it on something worthwhile.
Never go to a dealer and have them do a "check-up". Go to your owner's manual and look at what it suggests at be done at certain mileage. Go to the dealer and ask for an oil change and for that item to be checked. They check the other stuff anyway! Also if they tell you to do other things like flush steering, change transmission fluid, etc. press them with questions. And pull out your manual to see if that procedure is EVER recommended. For example, when I asked lots of questions, I found that I'm really not going to do any damage to my steering if I don't change the fluid until I start to get some "symptoms" which has never happened. I have an 04 with 160,000 miles. And when I pressed on the transmission fluid (which I have had to have changed so I do watch it), it was "discolored" but not "dirty" (needs changing). So my dealer won't lie to me as far as I know but they will lead you to think you need things you don't unless you question them. I have a girlfriend that for years continued to go to her dealer for her Outback and every time ended up with $500 bills. So it's okay to go to the dealer so you actually do get some of their "expertise" for your vehicle but just ask only for what you want and ask lots of questions for anything else recommended. BTW: only Goodyear tires last on my Highlander (originally came on it). I made the mistake of letting Goodyear do other work and I was lied to regularly (example: told me I needed brakes changed when they were normal levels and two years later still are okay. They rotate my tires, period)
Thanks for your advice. You guys confirmed what others have told me: be suspicious of unwanted services the dealer recommends and always go by what is recommended on the manual. I've seen some "oil and filter" change coupons that includes checking these other components for free. my H/L came with Bridgestone tires which i intend to change soon. Thanks again.
I guess what I'm looking for is a maintenance schedule someone has followed on their HL. Someone who has alot of miles and didn't follow the dealer maintenance packages. How does one know when to replace certain fluids, etc...at what intervals. If I have the dealer check invaded on what the manual says they will always say change it which is what I'm afraid of. I would like to know how many miles I should definitely change certain fluids.
I don't understand your post. Read and understand your owner's manual, grow a pair, and then TELL the dealer what to do and what not to do. This isn't rocket science. All of the information you're seeking is right in your owner's manual.
Any car properly maintained -- wheels / steering in alignment, tires in good condition and balanced -- should go straight when you (briefly) take your hands off the wheel. It should not pull to the right or left. You're under warranty -- so if you have the option locally I'd say take it to a different dealer. And probably never go again to the one who said it's "normal". If another one calls it "normal" -- then escalate. Find out who the regional sales and/or service managers are and contact them (preferably both). The situation you have is not only irritating -- it's potentially dangerous.
As an aside, I'm not happy with the steering of our 2012, because I think it's imprecise (I call it 'mushy'). My other cars are German -- BMW and Porsche, so I'm used to a tight feel of the road. Even though they are 10 and 25 years old respectively. I haven't talked to the dealer yet about it -- thinking I'm likely to get the 'it's normal' response. I want to get a chance to drive another 2012 and see if it steers the same. (You might see if your dealer will let you drive a demo -- to compare to yours). But a month ago I had an instance where it was pulling to the right at high speed on the freeway. Only lasted maybe for 5 - 10 miles, then went back to what I consider 'normal' -- that is, staying in a straight line when I release the wheel.
The manual really doesn't give me a clear idea on when certain fluids absolutely have to be changed by . I also heard that there is no reason at all to change the transfer case oil and differential because they are sealed units. So that leaves the coolant, transmission, power steering
Electric power stearing will always feel slightly "mushy" when compared to the "solidness" of hydraulically "boosted" power stearing. But FE wise, the electric takes the prize by a wide margin.
What air filter & cabin air filter is the best one to use? I tried Fram filters about 8,000 mikes ago, but the air still smells funky when I turn on the heat to blow towards the windshield.
Have an 03 V6, replaced timing belt and water pump at 105K, at a Toyota store and they had a good deal. Free rental car to boot. Shop around for the best price.
thanks in advance,
Dave
Jonas
Also, what's the shelf life of synthetic oil?
I've been using synthetic since about 1978.
Phil
If you had the battery replaced and they didn't check, 'bad' on them.
If you replaced the battery yourself and didn't check, you need to verify that the alternator is working.
"Barely turning over" has absolutely nothing to do with how clean the injectors might be.
Phil
Cheers
Graham
Cheers
Graham
Phil
Rut
TIA,
Jonas
2012...
DIY..?
"..inner pad on the right..."
Very common problem, caused by a stuck or sticking caliper slide pin, replace and/or FULLY lubricate.
Confessions From the Dealership Service Department
http://www.edmunds.com/car-maintenance/results.html?year=2005&makeId=200003381&m- odelYearId=100503866&styleId=100413879&engCode=6VNAG3.3&transCode=AUTOMATIC&mile- age=90000&zip=53072
My dealer is asking for $700 including tax
steves8, "Toyota Highlander Maintenance and Repair" #4791, 16 Feb 2010 6:18 pm
Should I stick with genuine toyota filters?
oil & filter, tire rotation every 5,000 miles.
Air Filter, Cabin Filter, Transmission fluid, coolant service every 30,000 miles..
right now my HL @60,000 miles.. If it reaches 100K without major issues I will think abt changing timing belt.
http://www.ehow.com/how_4509187_check-refill-transfer-case-toyota.html
