Tacoma Towing
burthusen1
Member Posts: 5
Looking for feedback on the performance of towing with a Tacoma. I have a 2000 Tacoma, Ex. Cab, v-6, 5spd, 4x4 with rear lock and am thinking about using it to tow an 18ft Lund. I'd say the aprx. weight of the boat, trailer, and equipment will be pushing 2000-2300lbs. Can the Tacoma do it? Any input appreciated.
Even though I have a Tundra and a bigger rear-end (4.10), its the same engine.
I pulled a 3200 pound trailer earlier in life and it was a breeze. My present 5000 pound trailer is more of a pull.
So 2300 pounds should be a breeze.
Gas mileage with the old trailer was 13 and 11 with the new one.
I also have a 5-speed, too.
The 3.4 V6 engine is built to rev, and if you short shift you will be missing out on taking advantage of all the torque this engine puts out. I keep mine in 3rd gear on the mountain passes and can easily keep up with 70mph traffic.
Be careful when braking if you don't have trailer brakes (definitely one thing I would not want to be w/o towing my trailer).
Galen
Thanks again to everyone who responded!
Thanks for the info on towing, but are you referring to travel trailers, pop-up trailers, or what, when you have referred to the weights. There is a big difference in the way things tow depending upon what it is.
I am interested in towing a small travel trailer, probably not exceeding 2500 lbs. I had a '95 Toyota 4X4 Xcab 4cyl. (22R engine) and it wouldn't do it. It was a great engine, but simply didn't have enough power. Travel trailers push a lot of air in the front, and on the sides when there is a cross wind.
Does anyone tow a travel trailer with the new 4cyl. engine? I am pretty sure the 6cyl. would handle it fine, but any input would be greatly appreciated. The truck will be a 4X4 extended cab with camper shell.
Thanks again for your help.
toyota is a great dependable truck and if it will pull your needs get it, but i needed a v8.
good luck.
robert
Always wondered about ording parts from that site.
smgilles -
For that price I'll get two. One to use and one for spare. ;-)
I have had both engines, the 2.7 in the T-100 and presently the 3.4 in the Tundra.
The 2.7 will net better mileage and still tow with ease (that weight) and cost you less money.
If you plan on towing more in life, I would consider the 3.4.
Just have to be careful of the GCWR figure but with those weights mentioned above, you are find.
Any time you tow (over 2000 for the Tacoma) you need to take out of overdrive or use 4th gear on a manual.
As far as towing the amounts you are talking about with the 150hp 2.7L...you'll have no problems. Happy Trailering.
John
Basically, I don't have a tachometer, and I'm looking for engine RPM at these given speeds:
20 MPH
45 MPH
60 MPH
70 MPH
80 MPH
If anyone would be willing to take note of their tachs when they're driving around and get back to me on these, I would be greatly appreciative. Thanks.
