Jeep Liberty: Problems & Solutions
No problems at all yet with 9500 miles-except there is a developing vibration when decelerating from 54 to 45 with the o/d on. It is very high pitched-which makes me think it is a driveshaft rotation problem-possibly a universal joint-no vibration on acceleration through those speeds-I can go to 54 and take foot off gas and get the vibration-very rapid-down to 45 or so.
Any ideas?-For other people- I have a clunk also when slowing-but notice that it seems to be timed to the speedometer-the needle is slow to reach zero on hard barking-Maybe the transmission is tied to that-Slow braking doesn't have the clunk.
The clicking sound in mine at highway speeds were loose plastic roof strips-I reglued them
and no noise now.
Otherwise I love the Liberty-Get 19 mpg (40 mile commute to work)
So need some thoughts on the vibration!
I would like to know if anyone else has had any problems with this. Thanks
There was a shock absorber (or maybe a strut) placed in such a way that it could puncture the gas tank, and that was the safety problem with the Pinto. Once the arrangement was re-designed, the serious problem was gone.
I don't think there is any history of the Cherokee/GC gas tank being an issue. And maybe, if the Liberty design is similar,... this could be a good thing.
The Pinto tank trouble is due to a $7 part that connects the filler tube to the tank, Ford choose to save the $7 despite its own engineers recommendation.
Suzuke Grand Vitara XL7 also has gas tank behind the axle, was attacked by some automotive press. That tank is even closer to the rear bumper.
If the design was a problem before, I'm sure everybody would know about it. I'm too young to remember when the pinto was around but I sure have heard about it's crash results.
GM sued their pants off.
Have partially remedied the problems with top of the line Michelins, cross terrains, excellent tires, their talents are wasted on the Liberty.
If someone would ask me what's the best feature of the Liberty, I would answer my Michelin tires.
Matt
Good Luck.
On a different note: the dealership did not have any oil filters for the oil change. Supposedly, the dealership called everyone who was scheduled for an oil change to cancel. Needless to say, I did not get a call. Dealership problem over car problem, though. Did not make me happy that I could not get the service I requested, though.
Liberty has more than 8000 miles so far. I still love it!
Those of you who have rattle up front -- does it sort of sound like a tambourine in your front wheels? If so, check the hub cap in the center of your wheel (the small round cap cover in the very center of your wheel). Mine were loose and caused a tambourine sound at low speeds and light bumps. Pry it off, bend the tension tabs open a bit and snap it back in place. No more tambourine. This is not a Liberty only problem; I have had the same thing with previous jeep models with similar hub caps.
I went out last Friday to go to work and pushed the unlock button on my keyless entry. It didn't unlock, I thought this was rather strange and that the battery might be dead in the keyless entry thing. When I unlocked the door I looked at the odometer and noticed no lights there. I turned the key and it started to my surprise. I turned on the windshield wipers and nothing happened. I turned on the headlights and nothing happened. I looked at the computer stuff and totally blank. Even the speedometer didn't move.
I checked a few fuses but they all checked out fine. I called the dealership and they had me bring it in.
I explained the problem to them and they acted like they had never heard of this one. I ended up getting a rental car. They called me on Wednesday this week and told me it was ready to pick up. I asked what had happened and a computer control module had went out. They had to order the part in. I made arrangements for them to leave the Liberty outside for me to pick up after hours.
I arrived and checked the lights, wipers etc... all good. Took it for a quick test drive and the computer, speedometer and odometer where still not working. Luckily someone was still there and they plugged it into the computer and nothing came up. They needed to keep it 1 more night.
Come to find out they needed to program the tire size into the computer.
Just and FYI to all.
Still love the Liberty though!
Karl
PureONE Filter PL20195
Oil Filter(Premium Plus) L20195
Air Filter A35414
I cut open a MOPAR filter and it seems to be a Purolator Premium Plus, since it has "the string".
I called Mobil and the Mobil1 filter number is M1-209. From personal experience I would never touch a Fram filter, a a repackaged Fram, again.
Have you tried to change your own oil yet? I have the skid plate package and it's almost impossible for me to get to the oil filter without taking things off. Anyone have any tips or tricks?
The Liberty was bent on almost every body panel; Albrecht suffered cuts to his hands and still has a sore neck a month later.
Our slalom was not designed to induce a rollover, or even test for one,” said AutoWeek’s Detroit-based Road Test Editor Natalie Neff. “Its aim is to evaluate handling characteristics, especially in transitions. Typically, we find the limit when we hit a cone or spin out. We didn’t set out to roll the Jeep.”
more at http://www.autoweek.com
What is new is there is aother magazine that did their normal round of testing, independent of Auto Week, and also found issues with the Liberty's handling in their test. The info was posted one of the Liberty board.
That magazine also got the Liberty up on to two wheels.
a few suggestions:
1> Put a l arge piece of cardboard under the engine area (2ft. x 3ft) before starting
2> Purchase a oil filter wrench that grips the END of the oil filter & attaches to a ratchet wrench (v/s the kind that wraps around the filter).
3> When attaching the filter wrench you can 'peek' through the small hole in the skid pan to see what you're doing.
4> After the oil filter is loose AND BEFORE YOU REMOVE IT place the oil bucket UNDER THE CENTER HOLE IN THE SKID PAN (not your face)!!
5> When the oil starts to drip it WILL NOT be under the filter as you would expect, rather at the center opening in the skid pan. Jeep installed a "V" shaped tray under the filter to the skid pan opening.
******** REMINDER ********
Don't be under the skid pan when the oil starts to drain unless you have new clothes & lot's of shampoo!!!!!
Yours truly,
Oil in the face.
Excellent advice!
tidester
SUVs
Poor would have done nicely or very poor and possibly pathetically poor.
tidester
SUVs
Anyways.. I am complete happy with my Liberty and have not seen any troubles except for my accident last weekend.
