Mike
In regards to the A/C in my car, mine like most others has a very faint high pitch noise to it every now and then which does not bother me at all but I've also noticed that when I turn the air on, I feel a loss of power when the compressor kicks in. My brothers 88hp Escort does this but not my mom's 130hp Focus. I assumed that this would only happen on an underpowered car, not one with 140hp. I also notice that while my A/C is cold, it is not ICE cold as many other respondants have said, maybe its just my Canadian view of what "ice cold" is, is a little different than someone from the southern states. No offence meant by this statement.
Any respondants to my problems would be very much appreciated, thank you.
Now, with regard to cooling, we have already seen 100+ temps here in my part of Texas, and the cooling in my Elantra is some of the best I have ever seen. If you think your cooling is not up to snuff, I would get it checked. These newer a/c systems use much less freon (r134A) than the older systems so a slight undercharge could really show reduced cooling.
Good luck,
Jim
Once again thanks for your help.
Pete.
* The Elantra engine is tight initially; you will get better mpg as the engine loosens up. For me, that was after about 1500-2000 miles. Initially I got around 24 mpg, but now I am getting almost 30 with mostly city driving, some stop-and-go, a lot of urban freeways and city streets. That's with a 5-speed.
* How fast do you drive? You'll get lower mpg at 80 than you would at 60-70.
* How much stop-and-go driving do you do, or driving on city streets? You mentioned the trip computer's mpg reading goes down at an "unusually high rate" when you are stopped. I don't know what is usual for a GT because I have the GLS. When driving in town, do you like to gun it, keeping the revs high, or do you accelerate smoothly and anticipate stops? Driving habits can make a big difference with mpg.
* Have you checked tire pressures? I have mine set around 35 psi, a bit higher than recommended, but it seems to improve handling and may improve mpg too.
* How loaded is the car? I've noticed a difference of about 5 mpg between a car with just me and a car loaded with passengers and gear.
* How much do you use the A/C? That will rob a little mpg, how much I don't know, but I've done two long trips in my Elantra, one with A/C and one without, and on the non-A/C trip I got 40 mpg (all level freeway) and on the trip with A/C I got about 35 (with some hills and a few slow-downs through small towns). Each time my max speed was 70.
Mike
Mike
Mike
"Hyundai finally gave me my money back for the Elantra that had a horrible high-pitched squeal in it."
Are you saying you returned the car and got your money back?
Anyways, I bought the basic car (still has a lot of stuff *g*) with the auto trans. I almost gave into the $300 premium the dealer wanted for a CD player, but bypassed as I felt that was WAY to high. I am going to get a CD changer installed sometime in the future.
In the mean time, I was just planning on using my Sony CD player with a cassette adapter. However, the stock head unit seems to have the auto-side function (where it flips automatically from A to B at the end of each side)...when I plug in the adapter and play a CD, it will play for about 5 seconds, then try to switch sides (the adapter has no tabe, btw). It does it every 5 seconds or so. Obviously, I cannot listen to a CD...this is not a MAJOR issue...I mean, I'm happy with the quality stero I got for the price of the car, but it is rather annoying considering the vast collection of CD's I own, and total lack of cassettes. Anyone else have this prob? Any solutions?
Jon
I just wanted to get an oppinion from a few people. One day I when it was the 95 degree weather in chicago I came into my car and notice a large crack on the plastic of the instrument pannel (then on that covers the spedometer). I took it to the dealer closes to me the same day so that they would know it wasn't my foul. At first when I came into the car I though that somehow I did that about I have not touched it and even if I wanted to crack it on purpose (yea right) it would be hard. Well when I want back to that dealer to fix it, the menager told me that they would not fix it under the warranty and if I want to fight it then I have to go to the dealer I bought the car at. I made an appointment already with that dealer but I have a feeling they will give me a hard time. I think that plastic cracked from the heat, and I am sure it is nothing that I did. I just wanted to hear what people think. And also my cluch started squicking and being rough and they have to replace the main cylinder. My car is only 5 months also and I have a feeling that this is too much stuff for one time. Also I have a feeling my air conditioning is not cold enough and it that makes that noise but it does not bug me that much. Thanks you for responses.
5 times in 11 months for engine check light.
Dealer said that gas cap must be screwed on tight
!! three clicks has anyone had this solve the
problem!!!Not for me%@$#&%*!!!car has 20,000 on it
"Yes, W , that is exactly what I'm saying. Hyundai repurchased my lemon and I returned the car! "
Amazing. I have never heard first hand of someone taking the car back under the Lemon Law.
In light of the many other satisfied customers, and I believe that you liked you car otherwise -- will you get another Hyundai, or have you decided to move on?
Had my Elantra (Chianti Red) for three months now and had my first problem, and a minor one at that. I ran the fuel down below a quarter tank and the Low Fuel indicator came on, the one that looks like a gas pump. Well, it came on for about three seconds and went out. I have run the tank low a couple of times since, but the lamp will not come back on. Anyone else had this happen, and if so, what was the problem? I have a lot of "wrench time" under my belt, so if this is just a bulb replacement, I would be tempted to just fix it myself rather than have the car back to the dealer.
Other than this minor glitch, the car has been flawless. I did the first oil change this weekend and noted that the engine had used less than 1/4 a quart of oil in 3000 miles, assuming it was properly filled when new. Have no reason to doubt that as I check the oil at every fill up and have not seen the level change since new.
Later,
Jim
Just curious--do you remember what was happening when the light came on before, e.g. did you make a sharp turn? The gas can slosh around in the tank and momentarily cause my Elantra's low fuel light to flash even before the needle is on E.
I haven't run it empty (I'm good for that ) but I trust the numbers the trip computer displays...they match my fuel records pretty close! (mpg)
Jim
The first a few months I owned my 2001 GLS(a little over one year now), the check engine light kept coming on for 3 or 4 times. All but once, the dealer told me to tighten the gas cap. Finally, I went to extremes to turn the cap at least ONE FULL TURN after each fill. It never comes on again since:)
Hope it helps,
Jeff
Stripped oil pan is a common problem with dealer serviced Elantras. The oil pan is made out of aluminum and has NO steel insert for the threads. The stripping of threads does not have to happen if the plug is torque right. This is the reason I and many others bought the Fumoto Drain Valve. Once the valve is inserted into the drain plug hole you simply turn the valve on to drain the oil. Also dealers have a nasty habit of over filling the oil. Results in slow acceleration and possibly blown gaskets.
Shaking in the steering wheel is tire balance problem. If you have the tires rebalanced correctly (this may involve breaking the bead and moving the tire on the wheel) that should go away. Alot of the Elantras came from the factory with wheels out of balance.
ONE tire being bald already means you have an alignment problem. Tell the dealer and they should take care of it under warranty.
I sense that there is nothing wrong with your car that my or other Elantras have not suffered. The problem seems to lie with your service techs. They dont give a damn. I would try another dealer for service. If not happy with service ask to see the district manager.
I had the dealer checked it a couple days ago. They couldn't find anything wrong, so they just lubricated something. However, I can still hear that sound, although it seems to be less often. Does anybody know what could be wrong? I'm concerned it might be something serious.
Jeff
It's a pity to know the dealer didn't do a good job. I'll have to try another dealer.
Jeff
A car is a mechanical device so I expect to have the occasionally problem, I think it is a bit unrealistic to expect it to always perform perfectly, that being said a lot of problems can be averted with a decent mechanic working on the car, finding one is the problem.
I do however think it is rather pointless to blame the car or the manufacturer for dealer problems, or to say you won't buy that make again because of a poor dealer, by all means change dealers or go to third parties but realise where blame lays, in reality manufacturers can't do a great deal about most dealers.
This week I had to take my Caravan in for a strange problem--the Check Engine Light would flash when I went over a sharp bump. I suspected something was loose, and the dealer had just done some work on the electrical system the week before. Sure enough, they had not tightened down a battery cable on the last service. This was the first goof this dealer had made in eleven years of otherwise exemplary service. Also, the service writer gave me a coupon for a free oil change for my trouble. Will I continue using this dealer for service? You bet.
on a manual (2002 GT)? Mine "pop"s into neutral after I push the clutch pedal and start to shift.
We live in a very hilly area, and most of the
problems are happening on hills. It is in the shop, and the mechanic can't seem to duplicate
the problem. This is my 4th manual transmission
car, but the mechanic started to hint that I might
not know how to drive it. (It never happened on the 3 manual trans. Hondas I owned!) The other day, it popped out of reverse while I was backing up, and I also have the problem with it killing in reverse, unless riding the clutch and the gas.
Do you actually get the car into gear and then have it pop back out into neutral?
If so, why can't the mechanic replicate this problem? Ask him to sit in the car while you do it in the parking lot.
did anyone has the same situation?
Is the noise coming from the brakes or the area of the brake pedal? I ask because my '01 GLS had a sound kind of like that, but when releasing the clutch pedal. The noise was coming from the clutch pedal, not the clutch. Details a few messages up.
(I'm beating a dead horse already...but hey..Canadian's are kinda funny *g*)
