my leather on the steering wheel is peeling? Has anyone else had that problem? The door handles are peeling also and have had those replaced twice. i have a 2001 blue cabrio. my paint chips easily. Has anyone else had this trouble with the paint?
The difference between the standard Cabriolet and the Carat is easily seen on the outside as well as the inside. The Carat had standard 14" alloy wheels, a Wolfsburg emblem on the front quarter panels near the doors, a power roof, power windows, leather, and they usually came in what's called triple white (white paint, white leather, white top). As for reliability, VW was going through a rough time in the early 90s. The engine should be solid though as its the same exact engine that resides in my 84 GTI which has been flawlessly reliable even though it has over 200k. Just make sure it starts right up whether the engine is cold or hot. If it appears to have been taken care of mechanically and looks good, I say go for it. The Cabriolet is one neat convertible.
Hey all! First, thanks so much for all who have posted. I am seriously considering a cabrio and this discussion has helped point out some things to look for when purchasing (vinyl vs. cloth top, etc.)
I live in Fairfield, CT. There is a Volkswagen dealership (Miller)just down the road from me, but a few trips there for info and from first impressions, Im not sure what kind of service I would get from them. (But really have no nput to go on) Anyone have any recommendations for mechanics or a good dealership in this area?
Also, thinking about buying a cabrio on line - ebay. can get some good deals if your willing to travel and buy site unseen. But thats just it, buying sit unseen, car undriven. Anyone have any experience with this or know of anyone who has.
Thanks again to everyone who posts. Im looking forward to buying this car as I think the love outweighs most problems.
Hi Carrie, I bought my '97 through the Excite classifieds. I asked the seller lots of questions via email and got financing ready before flying down to Arizona and driving the car back to Idaho. I got a great deal on the car (~$4000 under blue book) but it did have some mechanical problems that weren't disclosed to me before I bought it. I even had the seller take it to a mechanic for me to check the car out, but the seller chose the mechanic. I would still buy a car this way in a heartbeat, but make sure YOU pick a mechanic and have the seller take the car there. You might have to pay for an inspection but I would take that extra precaution if I had to do it over again. Also, you may want to do a Carfax lemon check. Research things to ask when buying a car and if possible, take someone with you that will know what to look for when you take a test drive. (I took a test drive in Arizona before buying it and figured if I found problems & decided not to buy the car, it would be a fun little trip anyway.) Good luck! Laurie
I have a friend with a new 2002 Cabrio and she has two problems. Her gas mileage sucks for a small 4 cylinder car. only about 300 miles for a full tank. is this right or should she have the engine checked? My saab is bigger, heavier and a turbo that gets 30mpg on the highway and has a 400+ mile range on a single tank.
Second, does anyone know how to clean the tan colored headliner on the softtop. hers is covered with black soot from running with the top down and nothing seems to get it clean.
I would assume your friend has an automatic. If so, the Cabrio is only rated at 23 city/29 highway. The fuel tank's max capacity is 13.7 gallons. Let's assume she used 12 gallons over 300 miles. That means she got about 25 mpg, within the range that it should get. There is no problem with her engine and this is the mileage she should be getting. Keep these things in mind: the engine needs time to fully break-in (mileage should improve around 10k), the Cabrio is geared low in order to deal with the low power which leads to decreased mileage, and the car is heavy considering how little power it has. All these things conspire against good fuel economy.
I'm not sure what will clean black soot off of the tan headliner. Is she using the boot? That should keep the soot from coming in contact with the headliner. She should be using it anytime she is driving around more than a few miles with the top down.
I have a 02 Cab, that came with the factory radio cassette. I am in the process of installing a CD changer and have run into a ton of problems. I have solved almost all but now this is what I have. I bought a Panasonic CX DP610 changer & a Blitzsafe interface cord. I found the ground cord to be not grounded so I ran a different one. I now have power to the unit and all I get when I hit the CD button on the head unit is "CHK MAGAZIN" Anyone here have any ideas Thanks
I have a 97 VW (silver) with a vinyl top. Lately the top has started feeling sticky and is also showing minor cracks. Also, I don't know from where but there is a smell coming out of the car. I have had it detailed twice and also I showed it to mechanics for any problems they seem to think there is nothing wrong (mechanically) with the car.
My wife had this problem with her 2001 Cabrio. I could get everything working except that I always got the damn CHK MAGAZINE message.
Since I installed the changer on top of the platform where the first aid kit is supposed to go (driver side of the trunk), I had to move the ground wire and wiring harness from the passenger side to the driver. The wire is just held down with adhesive. I then duct-taped the wire to the floor (under the pad) and ran it up to the platform. I used industrial strength velcro to secure the changer. After two extremely humid and hot summers in PA, the changer has not moved once. The velcro acts a natural cushion so no skips. Lastly, I got my father-in-law to secure the ground wire in to the metal floor of the trunk with a sheet metal screw. That was the key. Once that wire was properly seated (I had tried to tape it to metal -- no go), the changer worked perfectly.
Use the ground that's in the Cabrio and you should be in good shape.
I would like to buy a cabrio but the volkswagon dealer in Melbourne, Fl has a poor reputation. Does anyone have a dealer and/or mechanic that they would recommend in the Melbourne/Orlando area? Thanks for any info
I'VE HAD QUITE A FEW PROBLEMS WITH MY VW. 3 SETS OF DOOR HANDLES THE PEELING WAS A REAL ISSUE. THE RADIO/CD PLAYER CONSTANTLY GOES INTO SAFE MODE. A COUPLE OF ELECTRICAL PROBLEMS WITH THE DASH, ETC. THEY HAVE ALL BEEN REPAIRED, BUT WHAT A PAIN. I ONLY HAVE 19,000 MILES ON THIS CAR AND IT HAS BEEN GARAGE KEPT. DOES ANYONE HAVE ANY EXPERIENCES THEY WOULD LIKE TO SHRE WITH ME ABOUT SELLING A CAR ON THE INTERNET, LIKE EBAY.
Does anyone have any further information regarding the class action suit against VW regarding the defective roofs on a number of cabrios built in the late 90s? I was under the impression that VW agreed to re-imburse owners who owned their vehicles less than 5 years 100% and 50% for those who owned them more than 5 years. VW was supposed to have sent out a mailing regarding this issue in early May. Any ideas?
I bought a used 2000 cabrio convertible with 31,000 miles last April. I wish I would have thought to look into this discussion group before I bought. I live on Hilton Head Island and I wanted a fun little inexpensive convertible. It has been fun when it works. I have always bought General Motors boring cars and never had any problems. My last one was a buick! I still have it my daughter drives it back and forth from college. I had no problems with the buick in the whole 8 years of ownership. I love driving the cabrio convertible but in the past 15 months 4 starters blew while I was driving shutting down the motor. My mechanic after the 4th such eposoid realized that I had a faulty ignition switch. I thought its problems were solved. Since then I've replaced the mechanism for the power windows, my seat warmers don't warm, my automatic top doesn't work. I replaced an engine fan. I had a problem with a brake light constantly blinking making shorting noises. It has been fixed. I thought its demons were fixed and I was happy for about a week. It is so much fun driving. I was having a ball tooting around the island. When again disaster struck, engine light came on. I couldn't handle it anymore. I went and bought a Toyota Prius. It is being delivered next Thursday. So I have my cabrio for a little while, I can still drive it the engine light came on becuase I overfilled the tank!! Once I used up the gas it went out. That over filled gas tank cost me $24000!!!Too late I already bought the Prius. But guess what now the brakes are squealing. I guess I made the right decision. But boy was my little white cabrio fun when it was working. I just can't take anymore.. After I first engine stall I called VW saying that I could have been killed when the eengine shut down. They could have cared less.I only put 10,000 miles on it in 15 months!! This is not normal. Thank you for allowing me to rant
My daughter has a 2001 Cabrio that she loves with the exception of one problem that we have not been able to get corrected even after several trips to the dealer. He Cabrio is the base 2.0L with automatic. Every couple hundred miles, as she is driving along at any speed, the engine speed/power will just drop instantly to essentially idle (with dramatic change in speed of the car). After a couple of seconds this problem will clear, the engine speed will return and everything is fine until the next occurrence. As the problem is intermittent, tough for dealer to pin down. They did replace one of the engine sensor, but this did not fix the problem. Looking for any advice / experience from folks on the board.
I have a 2000 VW Cabrio with power door locks. The power locks do not work when attempting to lock the doors from the inside using the power door lock buttons on the door. Likewise, the remote will activate and deactivate the alarm system but cannot lock or unlock the car. I checked the fuse box in hopes of it being something simple such as a blown fuse, but all the fuses were in good shape. Has anyone had a similar problem and/or advice on how to proceed from here?
Hello Everyone, I am looking to buy a Cabrio within the next couple of weeks. I would like to know if buying a manual or power is better. And what is considered low mileage for a VW. I am looking to buy anywhere from a 96 to a 2001 if the price is right and the mileage is right. I have been looking to buy one that has all the extras with power windows etc..... but now thinking that all that isn't important. Trying to make the right choice. Any thought would help. Thanks. JA
I have not had any problems with my 2001 Cabrio. I bought used - so you take your chances. I did have to replace the trans & clutch, but that was covered under the warranty. I am currently experiences problems with the power top. The fluid is very low, I refilled it not long ago. VW sent the directions and it was not too difficult. Has anyone else had problems with the fluid level in the power top?
I have been having some problems with the Brake Light and the ABS light on my 2001 Cabrio. The Brake light has been flashing all the time now when i drive, and it seems like when it flashes, it coincides with a type of rattling noise underneath the hood. The ABS light has also been coming on. It comes on when I sometimes start the car. When it comes on, the Air Conditioner, among other things, don't work. I only have to turn the car off, and restart it, and then its usually fine.
Does anyone know what could be causing these problems?
AWESOME! I have been struggling for a week trying to install my cd changer on the right side of the trunk. I did what you said it works great! Thanks! Jennifer
Last week my daughter reported that the ABS light on her 2001 Cabrio was coming on intermittently -- she didn't say anything about a noise under the hood or the air conditioner not working. In searching the internet for other reports/solutions to this problem I did see a post on another board that indicated that some VWs had a problem with the ignition switch not fully returning to the right position after starting the car. Evidently, while the car runs, perhaps some accessories/features are affected. Maybe try wiggling the ignition switch when you experience the problem to see if it clears. If it does, it may need adjusted/replaced. I'm going to have a more detailed look at my daughters car, and maybe drive it a day or two myself to see if I can experience the problem and then try to see if I can relate it to the ignition switch.
I have a 92 5 speed cabrio and have the same problem. Change cables, spark plugs, rotor, distributor cap, air + gaz filters, mass air flow, etc. and I still have this engine skip at idle with a tendancy to die on me when the engine in cold and not to start at all when hot. Plus it skips at high revs. Mechanic is completely lost.
I bought a 95 Cabrio about a month ago, and I love this car. It does of course have its "quirks" (aka problems). Was wondering if anyone had any advice for the following (other than the obvious take it to the mechanic!)
1. My driver's side lock (auto lock, door lock, window raising and lowering) just stopped working last night. The key turns but doesn't unlock, arm/disarm the alarm, or raise and lower the windows. The passenger side door does still work, though its a bit of a pain to have to unlock the door every time from the other side of the car.
2. Also the driver's side interior window switch works only intermittently. Sometimes its works fine, other times nothing. Usually after a while (before the key stopped working) I was able to make the window raise and lower with the key. New switch? or new motor?
3. The a/c hasn't worked since I got the car (I knew this) but when I went to add freon, the compressor started turning (as it should) and cycling on and off, so I assume the problem isn't with the compressor. However, the air from the a/c is still warm. Any ideas?
I would have the fuel pump, fuel pressure regulator, or fuel pressure accumulator looked at. The fuel pump and fuel pressure accumulator will both cause hot starting problems. The fuel pressure regulator tends to cause stalling when cold. With the age of the vehicle, I would say the most likely culprit is a fuel pump not putting out the proper fuel pressure.
I will attempt to give some insight into your problems.
1. Sounds like a switch has gone kaput in the door or maybe you just lucked out and a plug came loose. Either way, the door panel will have to come off and unless you can find a plug that has come undone, this is best left to the professionals.
2. It's the power window switch or a loose connection. VW's are known for crappy electronics. The fact that it was working with the key means the motor is fine.
3. More then likely you have some sort of leak in the system. The compressor can still be the source of the leak even though it is running. The compressor may also not be pumping properly.
I have a 95 VW Cabrio with an aftermarket alarm on it and I am having similar problems. After I unarm the car with the remote, get inside the car and start the engine, I cannot unlock the door locks with the power door lock button. Is this what you were describing? If it is, the VW dealership told me to take it back to the place where the alarm was installed and have them take a look at it. Right now I have it sitting at Best Buy trying to figure out what's wrong. One thing that could be the possibility (that I'm hoping it is and not something bigger) is that the factory alarm and aftermarket alarm are not communicating correctly or the factory alarm was not properly disabled.
My Girlfriend has a 2000 Cabrio and has the low fluid problem with the Convertible Top. I purchased the fluid and for some reason, I can't get the fluid to go into the reservoir. I have the top bolt out and there seems to be some sort of pressure preventing me from adding the fluid. Do you have the instructions from VW that you can post or e-mail to me?
This has been such a pain - the top goes down but can't come back up.
You need a small oil can with a grip pump and hose to fill the reservoir. There's a 90 degree turn from the bolt hole to the reservoir. Once it's filled (should be just above minimum when the top is down - half to full when up) put the bolt back on - but don't tighten. Cycle the top up and down 3-4 times to remove any air bubbles in the lines, then tighten the bolt all the way.
My top sometimes still gets stuck half way up - I just release the button, and tap it again - seems to work.
What type of fluid are you putting in? It should be power steering fluid - that's what VW sold me. It's frustrating that instructions are not in the owners manual - but my local VW dealer was nice enough to fax me instructions from their repair manual.
Anyone out there have a clue what's going on...... The radio and cassette player work great- but when I try to play CDs... I get an ERROR- E3 message. I tried switching out the CD changer unit..... with an identical unit- that works fine in another 95 Cabrio. Well- after changing it out- I still get the same ERROR-E3 message.
Any insight is much appreciated... as I am getting ready to take a long road trip. THANKS !
Just purchased a '96 Cabrio this past Tuesday. Relatively good shape for a 10-year-old VW, only had 58k miles on it. Had a few minor issues, had to replace the brake shoes, front rotors, and the valve cover gasket.
I've been considering getting a CD changer for this (car has the Premium sound system, AM/FM/Tape); as I peruse the forum I keep hearing about the CD connector being located somewhere in the rear-right of the trunk. I took a quick peek in last night, but as I'm somewhat unfamiliar with the VW's wiring, I didn't know exactly what I was looking at.
Here's the question: What exactly does the connector itself look like, and which panel/floorborad/whatever to I need to move to find it?
Back in 1984 when I was single and started to get a paycheck, I bought an year-old dealer demo 1984 Volkswagen Rabbit convertible (VW started calling them Cabriolet in 1985). Twenty one years later, after mostly short commutes, it has 130,000 miles but still gets 30 MPG. About two years ago, various items started to fall apart. I thought about donating it to charity, but because it was paid for and I live in Atlanta where you can drive with the top down most of the year, I decide to invest ~$3000 for 1) new top, 2) new engine gasket, 3) new tires, 4) new master cylinder and rear drums.
If I was still single, I would probably just keep driving it forever. But I now have two young children (2 and 4 years old) who enjoy riding in their respective child carseats in the rear. My wife is pressuring me to sell it as she is concerned about 1) its lack of airbags, and 2) some other major equipment may fail resulting in personal injury and/or costly repairs.
She drives an Acura MDX that we transport our kids in most of the time and we also own a low mileage 1996 Honda EX (her previous car), now used mostly by the nanny or as a backup.
Curious if others share her concerns? One option is to sell both the Rabbit and the Civic and buy another used (safer) convertible with the proceeds. If so, appreciate your suggestions.
I just bought a 98 cabrio that is in very good condition with 92k miles on it. It recently started having a problem with the turn signals. The turn signals work at all times except when I am breaking (this is when it is most important too). Also, the cruise control doesn't work and I since it is on the same stalk as the turn signals, I thought they might be on the same circuit. If anyone has any insight on what the problem is and how to fix it I would be very appreciative.
I had to change my battery in my '01 Cabrio. Now when I power up the radio I get SAFE followed by 1000. I contacted a friend with a service business and he got me the code from Volkswagon. My problem is that I do not have the owners manual and do not know how to get the radio to accept the code.
I have found some stuff on the 'net for jettas that uses a combination of pressing MODE and SCAN buttons, but I do not have a MODE button. My friend suggested pressing the SCAN after entering the code, but that does not do the trick. Anybody out there have an '01 with the proper procedure from the manual, or suggestions?
I'm brand new to the Cabrio world and this forum. I'm so excited to be here, because I just bought a 99 Cabrio with only 45k miles in wonderful condition! It's Batik blue/blue with black leather. I've had it for about two weeks, and even though it's been so hot, I've been cruising all over topless (I've even gotten sunburned).
I noticed that there are already some postings about the ABS light coming on, and I was wondering if that is common. Mine came on recently and stays on intermittently. There doesn't seem to be any mechanical problems, no noise from anywhere or problems with AC. I'm wondering what it could be. I'm waiting for a warranty to take effect before I take it to get serviced. If anyone has any guesses, could you please let me know?
I'm also looking for a boot for the top. It didn't come with one. Does anyone know of a good place to look for one that won't be as expensive as a dealership? It can be slightly used or new.
does anyone know what the white ball like container with a themometer symbol on the cover could be ( when looking into engine it is on the right side back) also where do you add anti antifreeze .
Hi all, I just bought a 96 Cabrio the other day with only 72,000 miles on it....I was impressed. The only problem was the leather interior has a few rips in it. Does anyone know where I could replace the seats or have them repaired? Thanks in advance.
My wife has a 2002 Cabrio. The warranty is over and the engine light keeps coming on. My mechanic hooked it up to his computer but the codes make no sense. Supposedly they are volkswagon only codes!! Does anybody know where I can find what the codes mean. Not for nothing I really don't want to take it to a dealership if it's something simple I can fix myself. The other issue I am having is the ABS light keeps coming on as well, but cannot find anything wrong with the braking system. Any help would be great. Thanks, Jim
I had a 98 Cabrio which I missed so much that I just bought used a 2001 and both are stick shifts. The stick makes driving this car a blast, sort of a poor man's sports car IMHO. I bought it to fix my midlife crisis and keep from getting a motorcycle, but it gives me the same open air thrill! You can also buy relatively inexpensive chip upgrades for under $200 that gives it more power.
I have back problems and never have noticed any issues with using the stick while driving around Metro Detroit which is a testimony to VW's ergonomics in seat design. The only reason to not get a stick would be if you drive in stop and go traffic a lot and insist on eating a lot while driving.
Hey fellow cabrio drivers. I ran trouble codes on my 98 cabrio after it started acting up, kinda like it's misfiring or something. The reading said something about the crankshaft timing sensor, but i found a sensor on the air intake that wasn't even plugged in, hooked it back up, and my car is running perfect. But even after a reset on my ECU, it is still giving me trouble codes. It's telling me "tank vent valve open" which is P1426. I don't own a repair manual, and I cannot figure out what the heck the "tank vent valve" is and where it is. Do any of you know, or could you look it up in your manual for me pretty please???? I just bought the car and I'm already having to trouble shoot.. uhg.
Help 1997 Cabrio Highline 5speed... runs great ... BUT I can't keep the passenger floor DRY because after running the air on long drives it starts leaking. My problem is mainly I don't know if this is a common problem or is the drain line plugged or disconneted. So please if there is anyone that can help me WRITE!! Plus the fact that I can't find the DRAIN LINE HELP ME
Take care -
Carrie
Laurie
thanks for any info or help you can provide.
Any body in same shoes?.
Ashish
Tony
There were few posts regarding 97 and 98 vinyl tops and their problems. Was there a class suit, recall or any settlement with VW regarding this?
Thank you,
Ashish
Thanks for any info
THANKS, DEBBIE
JA
Jennifer
Did you ever find a solution on your side?
Thanks ya'll.
Hope I could help!
Many thanks in advance,
Thanks in advance,
Chris
In my '01 Cabrio...
Radio will display SAFE then 1000
Use preset 1-4 to enter CODE
press on Seek simultaneously
Radio will display frequeuncy and viola! Radio is back!
sorry the editor stripped out the symbols!
Chris
I'll talk to you all later,
Peaches
swtpea
Jim
And you don't even have to have a mechanic run the codes, just take it to your local auto parts store, they should have a reader.
