I solved the TC light issue; the ABS Module was bad.
The rough idle I can't get. There are posts as you mention but I can't find anyhting as specific as my problem. Anything close doesn't carry a solution.
It's fabulous.....
eBay item #130307408623 Cadillac Catera Service Repair Manual 1998 1999 2001 01
Check it out for your self.
The dealer (in Canada) wants $200 for the key (comes with a remote) and $130 to program it. A friend of mine who is a locksmith has the unit to program the key, however, it wouldn't work on this car because you need a dealer pin code to access the program. Dealer doesn't know his pin code because it's been embedded in his programmer and just starts up without asking for the code.
What we did was bought 4 aftermarket keys from Ilco for $17ea. (no caddy emblem), took the serial number and cut the key to the data from the serial number. 3 keys were cut and one was left uncut. Towed the car to the dealer and programmed 1 key ($130).
We then drove the car home, placed the programmed key in a key reader/programmer (not the unit I mentiond above) which copied the info on the dealer programmed key and copied the other 3 keys.
Then I bought a fancy Bulldog remote starter system for the car and used the one uncut key as the resident key for the remote starter. The remote starter uses this key (the metal part is cut off and just the bow is used with the chip in it) to allow the car to start by remote.
You still need a programmed key to drive the car because when you insert your key after remotley starting the car, the key in the ignition takes over and the resident key (bow only key) is disabled.
Yes it's a pain, but, $660 for 2 keys andf 2 remotes is insane.
I paid $70 for 4 keys cut, $130 to program 1 key (dealer), $119 for Bulldog fancy remote starter system and another $29 for spare remote (unit only came with 1 fancy LCD remote); about $325 total.
I have 1 key in my household safe, my wife and I have one key each, and the fourth is embedded in the starter system.
Codes would include misfires and many others.
I would rule out the heater control valve prior to replacing the heater core.
How many miles do you have on the Catera?
I have a 2000 Cadillac Catera. The radio does not work, it only comes on when the car is off. At the same time that went out, the heated seats did as well. Does anyone know what the problem is here?
In addition, when I turn on the air conditioner, the oil pressure drops below the red when idling, and only shows pressure when accelerating. Also, when the ac is turned on, the temp gauge gradually climbs up into the red.
I would appreciate any help. Thank you.
there is a little gray box on the drivers side, forget what they call it, but you need a new one.
> Started since 2 days ago. My radio unit shuts off on its own,
doesn't
> matter if its radio, CD or tape. It shuts sporadically sometimes
after
> 5 min sometimes after 30 min. The power goes off for like 5 minutes
> with even clock off, like there is no power to the unit at all.
Then
> power to the unit is restored and I can turn the radio on.
> Radio unit is the type that has CD, radio and the tape.
K-134 multi-malfunction relay
GM part number 90494163
K134 location:
Remove the trim panel from below the steering wheel.
Remove the black vinyl covered insert that is underneath that.
With a flashlight, lay on your back head next to the pedals and look
up
and to the right, over by the fender.
Gray box just above smaller red box.
Twist the gray box slightly clockwise and pull up.
It should pop off it's mount.
Now remove the wiring harness plug.
Is the coolant the right mix of half water and half anti-freeze?
My car radio comes on when it wants to and goes off when it wants to. When I first got it the radio only came on when the car was off and I changed a bad fuse and it worked. I would be careful about the heated seats because , from what i hear, they catch on fire. My car smells hot to but the gauge doesn't show it. You would be well severed to read all the old post on this site.
Are all your engine fans working and maybe you could take out your thermostat like we did years ago so a car wouldn't overheat but then you need to put it back in for winter.
2 On the dashboard the TBS ABS Check Engine lights as well as the speedometer acting sporatic all at once, when speedometer works lights go out.
Wallmart says they have a new battery for $65..Advance Auto Parts says the Catera needs a special battery for $150.
Has anyone tried the Wallmart replacement?
PS
once I had to replace the coolant reservior........... plastic split
There is hope. We called www.bba-reman.com, and they were able to fix the ABS controller. This is the black plastic box on the ABS module mounted down on the car's frame rail on the driver's side. They have DIY instructions on their website to remove the controller without removing the valve assembly and motor. This means you don't need to remove any brake lines or crack any of the lines open. Mail off the controller, and they rebuild it, test it, and warranty the work for a year, and send it back. According to them, you can still drive the car without the module. They charged us $169, which included return postage. This fixed the ABS, TC and CEL lights.
For the coolant light, check the coolant level in the reservoir. If it is fine, then the sensor may be bad. It is mounted to the bottom of the reservoir.
The most common cause is contamination of the catalyst because the engine is burning oil or leaking coolant internally (leaky head gasket or a crack in a combustion chamber or cylinder). Converters can also be damaged if they overheat due to ignition misfiring that allows unburned fuel to pass through into the exhaust (check for a fouled spark plug or bad plug wire). The same thing can happen if the engine has a bad exhaust valve that leaks compression into the exhaust (check compression).
How old is the Catera? How many miles? Do you ever have the brake fluid changed?
I've read that the tensioner kit includes water pump, timing belt, and tensioner.
The dealer repair person is telling me that it is so expensive becuase they have to get the part from the dealer. They looked for aftermarket parts, but could find none.
I've looked on the internet and have seen the same part number for half that price.
Questions: does anyone know: is that tensioner unit really all one part...and I have to replace the whole thing like they are telling me?
What is included in that part number 9291887?
Could damage have been done by them trying to replace the timing belt without the proper tool? (They now have the tool)
I've already paid $100 for the timing belt.
Thanks in advance for your wisdom.
They can rent the tool at the link below. So what are they charging you, if its not too personal?
http://www.ledfix. com/timingbeltto olrental. html
What they originally told me to replace the timing belt was $100 for the belt and $333 for the labor.
I'll update with actual figures after the work is completed.
