I think maybe is a starter system related problem.
So now after 3 hours of labor (Are you serious? Don't they have a computer code retriever???), they say i need the ABS/TC module (which I already knew), but now i need a body/chassis control module, because supposedly the car thinks its on, even when it's turned off? Pretty much the car is undrivable, and has to have the battery cable disconnected while it sits, or the battery will drain. WTF?!!!?
Should I fix this stuff or should i sell/donate it at the local salvage yard for $500 and take a mutiple thousand dollar loss and have to ride the damn bus? Not sure what to do, because i have sunk so much money into repairs that I could have bought another another car!!! This sheit has to be illegal or something. GRRRRRRRRRRRR!!!
In any case I will follow your advise!
Thanks a lot...
MD
He're the original post:
My 98 catera ran great for over a year after i bought it. Almost out of nowhere the damn thing has taken a major sheit! First the MAF sensor went out. No biggie. Fixed it. Nothing but regular matinence otherwise. Next, it started having issues starting and stalling at idle. Needed a new crankshaft sensor. Worked for a couple days. Then the dash lights went nuts and the speedometer, ABS/TC and power steering went out, all at the same time. Then they said I needed a new fuel pump and a new electronic brake control module and now a new body control module! WTF?!? Is this the M.O. for all these things to crap out at the same time? I've shelled out so much cash on repairs for this thing and it's still not fixed. I haven't replaced the ABS/TC and body control module yet, cuz they are so damn expensive, i wanted to see about buying them myself and either having somewhere else install them or install them myself. Are these things something i shouldn't even attempt myself? They mechanic wanted to charge me $1200 to replace the MAF sensor. Instead, I bought it for $300 including shipping and had pepboys install it for $80. I've gotten raped on a couple of other repairs that I was told had to be done NOW, and that they would fix all the problems but didn't. I don't want to get screwed over again, and I need this damn thing fixed ASAP. Having to borrow cars and spending almost twice as much in repairs than what i bought it for and the car not be fixed is KILLING ME!!! I loved this car until everything started breaking almost all at the same time! At this point i couldn't even sell it without sinking another $2000 into it at the shop I took it to. I never thought pepboys would be a better choice of auto shops. Somebody tell me something good, cuz i'm at a loss and going crazy.
Call them and see if they can repair the body control module as well. They should be able to tell you over the phone. Again, you just need to send the module to them via mail, UPS, or Fed-Ex. They can fix, test, and send it back with a warranty. Reinstall yourself and save big money.
I don't know if there is an electronic control system for the power steering, but it wouldn't surprise me. But, this module could be connected to another module that has gone bad, and just went into 'safe' mode. Check the fluid in the power steering reservoir first.
I was also told to check the sensors and clean them and that this would fix this problem, I have 3 sets of ABS sensors in the given case they need to be replaced.
2.) My dashboard is lit up like a christmas tree. Aside from the ABS/TC lights, the following lights are on as well, Radiator, Windshield & Check Engine. I figure if I replace the ABS module I'll knock out 2 lights.
My question for the remaining lights is what can I fix/replace to knock out the other 3? I think the oil change will knock out Check Engine, but still would have 2 lights left.
3.) I took the car to an auto shop to do an oil change but they refused because they were afraid I would blame them for the other problems they said there was with the car, possibly head gaskets but they weren't sure since they wanted to charge $80 to check + $80 for each light lit on the car (about $240 in total). When I take off the oil cap, it looks like there is some chocolate pudding smeared on the cap. Is there a way to know for sure if the head gaskets are bad? Or if it's a difficult challenge to tackle on myself? A friend said he would charge me $800 but for that price I can either buy another motor or find me another friend.
One other thing if you have the ABS/TC lights on, check the ABS sensors. There's 1 in each front tires. Make sure those are clean. For this, you have to remove the tire to find it. You have to remove them with one of those little " L " shape tools with the octagon shape at the tip, they're small and they're no problem to remove. They are located behind the brake pad.
I would suggest cleaning up the ABS sensors which is a different item from the ABS module. These can get rusty, dirty and you could have your speedometer working on and off. If the cleaning doesn't work, replace the ABS module, unplug your battery for a bit then reconnect and see if the lights go away.
I haven't got around to doing this stuff because I don't have with what to remove the tires or the ABS module which doesn't seem like an easy thing to remove, unless you have patience and time to spare.
The spare ABS module and the spare sensors I got because they're not that difficult to remove from other parted out cars. Specially if the engine is gone and there's no tires.
I have 4 abs sensors for a 97-98 Catera and 2 for 99-01 Catera. If my sensors don't work, I'll have the replacements ready, I'm gonna go to the dismantler later and get the other abs module too. I just want to know if it can be installed just like that or if it has to be air free when you install it like my pops told me.
If any one can answer me that one question, then I know I'll be fine.
Also, I don't think it's the computer, the issues started to happen individually, not all together, all the lights distract me now from the fact that the speedometer doesn't work. I have to kinda wing it with the RPM's and kinda guess how fast I'm going. 2.5k RPM's is about 65mph
I haven't given up on it, at least I don't want to, my wallet does. I want to turn it into a project like some I've seen. Catera's that would match up to a corvette.
http://www.pbase.com/elvin315/the_catera_v
Like that one. But one can dream. Might as well just buy the corvette, but I like the style of the Catera.
Open to suggestion!!!!!!!!!!!!
I was hoping you could help me?
My 2000 Catera is one issue after another but paid for would like to keep it and low mileage.
All my dash lights with the exception of the right hand side burned out well that is what the dealer ship said I paid $150 to get new bulbs so now i can see how fast I am going at night! BUT..now none of my gauges work the temp, rpm, mph, and the gas gauge! I refuse to take it to the dealership again they just ripped me off twice this month- and the other car repair place I went their computer can't read mine so they say they can't fix it?!
Did you get your MPH to work?
Just hoping for a cheap quick repair!
I hate my car I have repaired alot of items since I have owned it!
Thanks for any help you can give
If that doesn't work, I would try replacing your ABS module. I got one from the junkyard for about $10 and has been working fine ever since.
I've done similar work on a lot of cars, but this one takes the cake.Great craftsmanship in the machine work but design is not for the backyard mechanic.
Cannot get at the #3 rod to remove piston since upper oilpan has cast inner baffles and cannot remove pan without lifting engine and tran about two inches which might not be possible. Considering removing engine which means removing trans and disconnecting ac lines plus radiator and wiring. Found several difficult to remove items so far. I think the Germans thought they were building a Rolls Royce type car for Cadillac when I see the overkill design techniques in the engineering of this car. That's why I'm drawn to continue, otherwise I'd donate it someplace.
Any suggestions or ideas are welcome, car is mint otherwise. (sskl) Dave again.
Seriously thinking about plugging edge hole in piston in engine since the car has 104,000 miles on it. Too much work/cost to go further since there might be other serious problems after this fix.
Do you know of a JB WELD type material that is recommended. JB WELD is good for 500 degrees, but does not recommend using in combustion chamber.
Possibility of making a (from salvaged aluminum piston I have) wedge fitted slice bonded behind comp.ring. Have to use my gage building experience for accuracy, bonding is main problem. Slice would be forced into slot by compression, but intake stroke would cause some vacuum. Thanks for the reply; Dave again
Will proceed with caution.
Dave
This morning, I went out to start my car, it fired for about a half a second then it shut off. After that, it woudn't start at all, it's completely dead (cold). The dash lights kick on when I turn the key for about a half a second then shut off. Interior light works, headlights won't come on.
Got any suggestions? Any advise for a fix would be appreciated... I live in rural Montana and don't have a lot of options for mechanics nearby.
Blonde and Blue for my Catera.
Ben
2. Lift up the retainer clips on the strut ends.
3. Remove the rear compartment lid strut from the hinge.
4. Repeat step 1 through step 3 to remove the other rear compartment lid strut.
Installation Procedure
Notice: Apply pressure only at the end of the liftgate/hood assist rod that you are removing or attaching. Do NOT apply pressure to the middle of the rod because damage or bending will result.
NOTE: These struts are pricey from Cadillac----you may do better to take one off and try to match it at the auto parts store or shop online.
1. Install the rear compartment lid strut to the hinge.
2. Push in on the rear compartment lid strut until it locks in place.
3. Remove the support from the rear compartment lid.
4. Repeat steps 1 through 3 to install the other rear compartment lid strut.
You can refinish the fronts to 1.043" and the rears to 0.433"
