Honda Odyssey: Problems & Solutions:(1995-2004 Models)
I have a 2000 EX with 50,000 miles and no major problems, but...
Has anyone replaced the light for the clock?
The dealer wants $40.00 says the dashboard has to come out.
Can I replace the light without special tools?
Should I even try?
Help
If anyone is interested in how that is done let me know.
pmarvin Oct 31, 2001 7:27am
Check your junction boxes to make sure that the contacts are all clean, as well as check to make sure the sliding door open/close sensors are working properly.
The sliding doors should never open when in any other mode but Park.
I have had the same problem on my 2000 ODY ever since delivery. It is always the passenger side. The driver's side door has never malfunctioned. It has opened (sometimes fully and sometimes partially) while parked in the garage; is several different states; and, once when the vehicle was in motion. It has even opened with the doors locked and once when the internal power switch on the dash was off. Also it has opened when the batteries were out of the remote controllers. Several of the door malfunctions seem to occur after the vehicle has been exposed to vibration or shock such as driving on a gravel road or hitting a pot hole but I have not had a problem to occur during exposure. My local dealer has been very cooperative and tried several times (at least 15) to fix the problem to no avail. Honda Tech Line has been no help. We had the local district field engineer look at the problem but he could not find the cause since the problem occurs so intermittently. Honda extended the warranty on the doors. I called Honda's 800 number about 3 weeks ago (for the second time) and talked with a "Case Worker". She essentially said that unless the customer can demonstrate an intermittent problem actually occurring and witnessed by a Honda Tech, she does not consider it a problem. With that comment I said " Honda must either fix the problem in a reasonable time or replace the vehicle". Guess she got the message and got Honda engineering involved again. They recommend replacing the "Multiplexer" which they will do next week. They also inferred that this is not the only vehicle having the problem. I contend that Honda has an electronic problem with the control of the passenger side sliding door. My suggestion is to keep after them until it is fixed. I have posted several accounts of the problem going back almost 2 years.
Incidentally I have had a couple of other recent malfunctions which may be related. Once during the night the horn started blowing and the lights flashing. Another time the door only opened about half way when actuated from the external door handle. this latter incident was followed by the doors refusing to lock from the remote control. after setting for a while the locks worked OK.
Even though all doors were closed, locked, and the indicator lights were off.This seemed to happen most often in cold weather.
We spend about 6 times at the dealer to fix. Our only solution was to try opening/closing, rebooting (restarting the car) or turn the power doors off to just turn off the alarm. Very intermitant propblem.
Problem is gone now, we just picked up our '03 Ody, I hope.
I went through the discussion of size of the passenger side sliding door control button on the remote controller with Honda. The door lock button is about, if not, the same size as the passenger side door control button. In my case I have never had the vehicle to lock itself for no known reason. But I have had the door open many times. Statistically one would expect the door to lock itself as many times as it opens itself if the button size were the problem. The Honda field engineer agreed with my argument but replaced the remote controllers twice to see if the controllers were the problem. Even had me remove the batteries from both controllers. Still the door opened intermittently. So in my mind, the evidence doesn't point to a controller or a controller button size problem.
It usually involved the passenger side door and I could almost always attribute it to the remote. Either it was in my pocket, in my wife's purse while getting banged around, in my hands while I was also holding something else (groceries, etc.), or one of my kids had been playing with it. As to why not the Lock button...For one, I probably wouldn't have noticed it as a problem (not like an open door!). Also, I just bunched up my keys on my key chain (includes around 6 keys and 2 remote openers) and noticed that the Passenger door unlock button seems far more susceptible to being bumped by the head end of one of the other keys or remotes. That solves my mystery...I guess it doesn't help yours.
Spangler - you've got a lot more patience than I do. If my power doors suddenly openned in drive mode more than once I'd be suing Honda. A lot of people here paid a big premium for their Odys so that they can haul their kids around in relative safety.
Having it open my kids in the back (even with their belts on) is not something anyone should tolerate, IMHO.
Yeah...I read that. They said it might cause problems when starting the van as the computer wouldn't recognize the key/chip. I've never had a problem in 2.5 years, so I'm not worried about it. I have enough trouble keeping track of one set of keys let alone multiple sets!
I now have a new transmission that Honda put in (parts, labor & rental included).
PLEASE NOTE!!!! ANY TRANSMISSION RELATED PROBLEMS SHOULD BE REPORTED TO HONDA AMERICA, BEFORE YOU SPEND ONE PENNY OUT OF YOUR POCKET.
I have found that if you've done the scheduled maintenance as mandated, they have worked with me very well. Or, maybe it's because I've owned Honda's for 22 years????
1. Noise only occurs when I drive 50-70mph.
2. when the car is in nuetral, there is no noise.
3. In early morning or late night, there is no noise: I guess it is weather temperature related.
4. Noise is periodic: doesn't sound like wind noise.
5. Noise sounds like from the spot close to where the left small speaker(the one under the front winshield).
Anybody has any suggestion? Thanks.
I believe (in my case) that I am accidently hitting the key fob buttons. They are too easily actuated. I had a Windstar with dual power doors before this van ('02 Ody EX). Ford had a more intelligent remote - it required a 'mouse like' double click to transmit. We never had an unintended action.
On the noise front, the doors began driving me crazy about 6 months after delivery. I took some Maguires (sp?) (like Armor All) to all of the rubber seals and gaskets. It made an amazing difference. I now do it every couple of weeks to keep them quiet. If I let them dry out, the noise and rattles return.
Steve
I had to take keys out, perhaps its time to get a bigger pair of jeans and retire the 1980's circa.
They called it normal - built in free play between pads & caliper, caliper & carrier, to prevent siezing. Never heard this much noise on any disk assembly before. Ignore it???
Steve
It hasn't happened to me recently (though I bet it will now!), and the Honda techs have never pinned it down.
thanks in advance!
Also, nuwiseguy, there have been previous posts regarding fuel capacity.
I have a 2000 Ody EX, problem has occurred twice in two weeks. First time: My wife left the doors open and the key in the ignition while she was cleaning out the van. The door agar dinging turned into a clicking noise that she described as sounding like a clock/time bomb. The van would not start after this. She got absolutely NO response when the key was turned. Called AAA and they jump started the van, check out the battery, etc. Said they didn't see what the problem was. Called the dealer, who had no idea what the problem was. Van continued to run fine, until yesterday. Same problem. AAA came, jump started the van, could not find anything wrong. I saw that a few others had a similar problem back in 2001. Any ideas? Has anyone else run into this problem (and can keep me out of a few wild goose chases ;-) Thanks.
I wanted to see if anyone has had a tranny problem on a 2002.
Steven
Anyone here experience this check engine light and what was the problem?
Thanks in advance.
If you're going to own a Honda it is helpful to have a spare vehicle. While they may have better than average reliability, when something does go wrong the service (From HONDA...don't blame the dealer when they can't get parts or when HONDA's Tech line won't admit the problem is occurring) is astonishingly poor. This is the third time my van has sat for more than 10 days waiting for parts. I will admit that on one of the previous occasions a rental car (Chevy Malibu) was paid for by Honda. The other time I declined the offered Subaru Imprezza and did without a loaner.
This time broke the camel's back. No matter what happens to this Odyssey, the replacement will not be another Honda of any description. I guess I'm weird but I've had very good luck with Domestic vehicles (except for my first and last Grand Caravan). With that one exception they've all either been perfectly reliable or have spent a total of less than a week in the shop the entire time I've owned them, and I've put nearly 200,000 miles on most of them.
Anyone have any ideas? I will of course be taking it back to the dealer, but I would like to sound somewhat educated to them before they tell me that it's "normal".
OBDII gives a DTC of P1676 in the OE Module, which is proprietary to Honda and not translatable by my generic scanner. Can you translate?
TIA!
BTW - how did you put on all those miles so fast?
Yes, I just took delivery of a 2003 EX-L. Got it in Dallas, but saved enough over the Atlanta dealers to pay my plane ticket, my gas back home and still lots to spare.
