Chevy Vans: Problems & Solutions
Has anyone else had this problem? I really could use your help on it - we are heading south with it or renting if we have to, by the end of the week! HELP!!
the front wipers works only on the high and dos not move at any others speeds and when i switch it off it stops on the top and dos not go back home
the rear one dos not move it only make noisy sounds
anybody can help
thanks in advance
Our hazard light circuit board was shorted due to the previous owners installing the wrong wiring harness for the tow hitch (our mechanic says there is a specific one for the Venture). The fix cost us 300.00 but so far so good!
I hope this is helpful to someone.
A few weeks ago, the van sat out overnight in <10 degree F weather. The locks started continuously unlocking every 20 seconds or so. I pulled the battery from my remote, just to be sure that wasn't it, and it didn't stop the problem. I pulled the fuse for the locks to be sure the battery wouldn't drain overnight, and flipped the switch on the overhead lights.
The next day, after driving it a while, I replaced the fuse and the problem was no longer happening.
Then we had a cold spell with temps below 0 F. The locks started acting up again. When I had the door open, it would give me a warning tone, like when you hit the lock button with the door open, but the locks were mostly trying to unlock, as far as I could tell. Even with the dask fuse for the power locks pulled, there was still a clicking behind the dash and the warning tone. I pulled a main fuse from under the hood to prevent battery drain. The next day, after replacing the fuse it was still happening, so I made an appointment with the dealer shop and took it in. By the time I got there, it had stopped happening.
The dealer pulled the switches and inspected them for shorts. They said that was the most common problem with the locks acting up - the switches getting wet from rain or some other cause. They didn't find anything, and of course the problems wasn't happening for them.
It happened again this past weekend when the van was left outside overnight. No warning tone, but the continuous clicking of some mechanism behind the dash even when the locks fuse was pulled. I took it in to the dealer, left it overnight so they could check it first thing in the morning. Of course, we've had some warmer weather, so the van didn't get as cold, I guess. They reported that nothing was going wrong for them.
I left it out again last night just to see, and when I got up this AM the locks were at it again, along with the warning tone.
I'm trying to get this fixed under the extended warranty, so I think they are hesitant to just start replacing things. If anyone has had this experience and could point us in some direction, I would really appreciate it.
I've had it in to my mechanic who has replaced plugs, checked wires (judged okay), fuel filter, and replaced the oxygen sensor. When my mechanic pulled the plugs, although not abnormally worn, he noted that the 3 left bank plugs were "normal" in color while the 3 right bank plugs were very dark...he thought indicating a rich mixture on that side of the engine. I've seen the old parts and can confirm his observations.
Previously, in late 1992, the following items were replaced (mileage was about 112K miles): fuel pump & strainer, fuel filter, throttle position sensor, EGR valve, plugs, distributor cap, distributor rotor, distributor ignition control module, ignition coil, plug wires, idle air control valve, fuel injectors and spider, and the engine control PROM.
My mechanic now believes there may be a problem with the distributor itself and wants to replace it.
I think he's guessing...while I don't necessarily mind that, he's guessing with my checkbook which bothers me in light of the possibile, never ending, perhaps un-necessary replacement of what can be very expensive parts. The mechanic has had the vehicle in his shop for over 2 weeks and there's no end in sight at this point.
Is there anyone out there who might be able to give me an idea of what might be wrong here? What could cause the plugs on one side of the engine to look as tho the mixture might be to rich? The service engine light has not come on. My mechanic tells me that the vehicle "computer" has registered no problems.
Previous to this, for the most part, the engine has run well inspite of high mileage.
Hope someone has a few ideas besides finding a new mechanic!
Anything is appreciated.
noticed the a/c vents will not let air past.
must be the vacume hoses or what do you think?
with van running and a/c on I get no air at all through the vents.
ideas?
we need to try to keep van for as long we can... would like to know what to look for when these gasket problems start....thanks
thanks.....i'll keep an eye on the oil for signs of coolant....and on the floor where we park....
I have a 2004 Chevy Astro Cargo van.
A paper or a bag was sucked up into the intake for the AC
from the floor.
Any ideas on how to get it out?
Budly
