However, they are well made, have a lot of power and smoother engine, crash ratings, the rear seat disappears and terrific resale, which probably led to the good lease terms you got. All in all, they seem to be a viable alternative for sure.
Hard to belive you had such depreciation on your van with Zero financing and a good purchase price, but that's the steepest part of the curve the first few years, and GM is not good at resale thats for sure. Makes a good deal on used vehicles however.
If Honda is still doing well on vans when my '98 grinds to a halt, I'll be looking at them, as the new '95 GM SUV nosed vans are ugly and are a step backwards I think, despite the likely improvement in underhood maintenance. Since your messages on the newer GM's not getting as good of MPG I'm holding on to our '98, its a runner and at 105k it still doesn't burn oil and runs great.
Anyone else see those new designs? U-L-G-Y. All they need is fake wood side to complete it.
Resale (vs list) isn't great but look at the discounts? The 0% you gave up is worth $3000+ on a van. Our van listed for C$33000. We got $5000 cash back, $1000 coupon in the mail and negotiated another $3000 off that. Our end price was $24k. Pay less and get less, that's the way it goes but a similar Oddy would have been $6000-8000 more so I can easily live with the lower resale in 6-7 years.
We have a 00 Windstar too, paid 1100 (list 13-1400+)for a 72/75 and have had a new tranny, new front tie end rods plus some other thing with the seat so far.! That was well worth it! We are ahead a few grand easily!
My 98 Subaru had a ext warranty, cost 800 (list 1100) for 72/100. Have had a new a.c, 2 new powered radio antennas, cam seal gasket leak fixed. I got a lot of freebies too, they replaced bulbs in the dash (not covered) as good will gestures and when they did the oil leak I asked them to do the timing belt and I would pay for the parts and any additional labor as they had done most of the labor already, they told SOA the belt was damged by the oil and I got that free.Have had more than double my money back esp with that a/c, ouch those things are expesnive to fix!
My 92 Subaru had no trouble till the ext warranty ended! That was 600 bucks wasted!It actually had an oil leak which would have been covered but I didn't know about it till a year later.
These were all zero deductible.
http://www.canadiandriver.com/news/031205-4.htm
http://www.chevrolet.com/uplander/
FYI - I filled up right next to the highway and started driving over the weekend, got avg of 27-28 mpg at 75 mph here in Houston. I had heard of others getting that MPG but thought they must have been driving like Grandma to get that sort of miliage, but it is clearly obtainable! 80mph, however, seems to add a lot of wind resistance and milage drops off. Has anyone had patience to drive 55-60 for an extended trip? I'd guess 31mpg is doable if you drafted off some trucks and actually worked at it.
Dirk
Like Dirkwork said about Syn getting past some seals in the engine and causing leaks. The Chrysler dealer put Syn oil in my Chrysler Sebring and I had a oil leak around the oil pan. Changed back to regular oil and the leak stopped. Don't want to have oil leaking out so I just change the oil regularly.
Hold overhead switch for PSD (the one that Open/closes door). Cycle the overhead PSD switch that turns it on/off about 8 times. This enters the Diagnostic mode. You count the number of chimes. I think 12 was No codes stored. When it was done, you cycle the on/off switch to shut it up. You'll need a shop manual or maybe chilton's to diagnose the codes, or if you're not a hurry, I could look it up for you.
Basically, if it shuts off mid-close, something is wrong. Mine doesn't shut 100% all the way reliably and then reverses, but I think that 105k miles has worn out the clutch for the PSD and it no longer has enough ummph. If I help it it will close. I had no error codes stored.
Stopping midway is very odd, and not working afterwards points to like a controller problem. The manual has about 80 pages of PSD diagnostics, its fairly complicated if you look at all the possible problems, but not that bad if you can rule out like door alignment and what not.
The dealer should have checked for PSD codes. Perhaps ask why they did not do this? Most service guys in dealers do not posess detailed knowledge, only swap parts. Does it operate smoothly in "manual" mode, with the PSD disabled by the switch? That would rule out a cable snag or something like that. Sounds like an electrical connection is going out and the PSD computer needs to be reset for it to work, but I'm only guessing.
This is a wild guess, but also check your battery connection and battery strength, they cause electrical gremlins when going bad, and yours is getting old - the Delco ones are not known to last very long and can drip acid on the wiring harness causing wierd problems, check it out.
Dirk
on another note, my driver side control for the passenger window also doesn't work intermittently but last time it did that, i made it to the dealer to show them, so they can't say "we can't duplicate". as soon as i left the dealer, it worked again. i wish the door would do it's thing in front of them too. last time i got "we can't duplicate-we opened and closed it 20 times" from them.
is the intake manifold gasket a certain given failure on the 3.4? i just couldn't afford the extended warranty at this time, even with payments. it's been a decent van for the wife and kids-at an excellent price.
Dirk
Changed oil, Transmission fluid, looked at brakes. Needed pads and rotors, in only 18 month from my last brand new set! Luckily, I bought the Autozone "lifetime" set and got a new set free. The rotors, however, I had to buy new ones after they could not be turned (barely) and had 2-3mm of the surface gone, creating a rut where the pads hit. Local parts place, Hi-lo O'Reiley had a USA made rotors, lifetime warrenty for $40 each. Figured I'd come out ahead on the deal and I'm not so hot on those import rotors.
The transmission oil needed changing at 105k miles. I had been lazy and putting that off.
Dirk
I'm still rolling my dice I guess, you can try some stop leak if you have trouble.
Dirk
Dirk
7,380 miles: Belt squeal, serpentine belt replaced.
12,130 Miles: Pass. Rear door motor assembly replaced, door opens while driving (recall), Driver side rear door latch replaced, Serpentine belt and tensioner replaced (belt squeal), Rear brakes replaced, Rough idle, can’t duplicate. Front suspension bushing replaced(noise) alignment checked.
14,473 miles, Serpentine belt replaced(squeal,chirping).
14,990 miles, Water leaking at rear hatch, Rear intake leaking oil( oil pan bolts, oil filter, drain plug tightened) Questioned fix and was told that’s how they fix Honda’s., Front alignment( Paid by me)
17,578 miles, Serpentine belt squealing and chirping( belt replaced) Water in LR taillight(replaced)
19,696 miles, AC pressure valve blew out.(replaced) AC air is warm and spitting water out vents. This is Aug. 2003
19,826 miles, Told AC is working Fine, use recirculate to cool Vehicle. Water coming out of vents normal. Was told no problem with serpentine belt, tensioners, pulleys etc. Belt squealing and chirping normal. Some belts do this(This is 4th belt since new) At this time I made the mistake to contact GM Customer Service, then the BBB. Both said they would help me neither did. All I have ever got is to be told to take it in for repairs. Dah! That’s what I have been doing.
20,752 miles, AC recharged, Vents stopped spitting water, Air cool at times but not close to what it was, mostly warm and humid. Belt squeal was used on belt many times and did not fix. Belt noise to be fixed for last time Per area Service Manager. Dealer saturated the belt with belt lube, then told me they could not duplicate problem. Belt still squealing and chirping. E-brake not holding, brakes not stopping van. Rear brake parts fell apart.
21,380 miles, Belt problem addressed again, pulleys not lined up properly, seems to fix. AC still not working right, told cannot fix unless hot outside. Begged them to fix so I could travel to Arizona and Florida, they refused. Pleaded with them to compare to other like vans( I did) they refused. 60 degrees outside, drive all day long will AC full blast and not be cold.
Arbitration Hearing, IMPARTIAL Tech. Determines AC is working properly( 35 Degrees outside) Failed to mention noise in vent for which there is a TSB on. Offered extended warranty, Told GM I couldn’t get it fixed with the one I had.
23,296 miles, Loss of power, bad gas mileage, Oil leak, anti-freeze in oil, rough Idle( intake gasket replaced) engine oil overfilled 3/4 Qt. AC checked(warm outside) No Problem found. Although dealer claims they did not work on AC, works a little better.
24,000 miles to current 25,600 miles, Oil leak continues, Oil dripping from engine since May 2003. Engine stumbles or bucking while driving, Transmission slams into gear and slips. Driver window slow or almost stops midway. AC Blows warm humid air with moldy smell. Before AC was repaired you could have made ice-cream and van smelled new. I had to turn rear unit off cause kids were too cold. Dealers have never driven Van more than 2-3 miles. Vehicle never wrecked or abused and serviced above normal.
25,848 miles, Engine problem caused by spark plug wires not attached properly when intake was done. Bracket not connected and wires shorted out on egr tube. Had AC checked by a private tech. To confirm AC was not working properly. Then had GM dealer check again. Both agreed it was not right and has low charge. After 3 last chance to repair and 5 attempts to get fixed in almost a year I had an attorney file for repurchase under lemon law. GM refused my claim on that primary concerns have been fixed and AC problem cannot be duplicated. GM has flat out refused to fix the AC and properly diagnose problem since Aug. 03. At times AC vents look like a steam iron and now Recirculate/outside air switch will not work. I have gone to different dealers. Yes this is a true story, I wish it wasn’t.
29,000 miles After AC not right for over a year, 3 Last chance for repair notices, BBB hearing, and lemon law Attorney saying I had a weak case to do anything I put my tail between my legs and took Van in to be fixed again. The Van was there for 3 weeks. Driver window regulator replaced after a year of refusal. Oil leaking for over a year: Rear engine main oil seal replaced. Interior panel clips replaced. Since wires were replaced mpg on highway has dropped by 5 mpg, no problems found. Dealer claims AC had low charge and leak. Could not find leak and charged system and claims it is working fine. As soon as I got Van back I noticed AC is almost as bad as it was before just a little colder at times. I drove 30 miles from the dealer to my house with AC on full and was not cold. When I got home rear air was 75- 80 degrees, front was 50-55 degrees. Gm has spent more money on repair attempts and fighting to prove there is nothing wrong with AC than it would cost to replaced the whole system. It has not worked properly since Aug. 03. Last response from GM is there is no issue with AC problem. This is short version of my ownership of this Van.
We read your long post before. It was mentioned to you that:
A; Your dealer does not seem to have a good repair department that knows how to fix anything.
B; You need to operate your AC in recirc mode with AC for proper operation - same as on any vehicle
C; All of your troubles can be traced to the above, that is why they won't deal with you for a lemon law.
Things like slow windows on my Japanese Maxima are usually because the frame needs lubrication.
What was the point of reposting the same thing? Some sort of emotional release?
Sounds like you have issues with the vehicle. Find another dealer to repair if possible.
DD
Yes, I encourage everyone to replace the stock ones that has over 50k on the clock and who does any sort of non-puttering driving. I think you'll appreciate it more as you drive it.
I just finished some work related stuff and its time for bed or I'd post the PSD diagnostics. Another day.
Anyone driven the new version of the van yet, or work at the plants making them?
Dirk
syeb "Chevy Venture" Sep 28, 2004 2:56pm
What an idiot move I made!
So I start my quest to find out about the rattle, by now I had an idea it was piston slap. Service manager at one dealer shrugged his shoulders and said they all sounded like mine. Next I call Pontiac customer service and after some haggling low and behold they gave me an extended warranty for the engine for 100K/6 years. I was pretty happy but turn out this is standard procedure for GM. I have to say I was one year out of warranty window so I was pleasantly pleased.
Another dealer was reluctant to take on my cause fearing his own liability after he tears into the engine. Also he said he could not guarantee the noise would not return later.
I am a shadetree mechanic with previous experience about piston slap but ONLY with high miles so GM's claim of this being a nuisance issue only is IMHO corporate arrogance at it's best. In my judgement the two dealers I visited were not prepared for this type of heavy engine repair. Do they have clean rooms for assembling this stuff and are today's techs really experienced- yes Mr. Goodwrench I am talking about you- in the craft of engine repair?
Other than the rattle our van seems to run OK, uses no oil from 30K to 40K and about 18-19mpg in the city and about 23mpg on the road at 70-75 mph.
The rattle lasts about 2-3 minutes after coldstart and less if it just sits for couple of hours.
Has anybody accumulated substantial mileage yet on their rattlevan in suburban/city driving? I know there has to be others!
Or has anybody had their rattler repaired at a dealer with good results?
Does anybody know if GM fixed this issue yet whether it is a matter of piston design or machining the block or whatever??
I am aware of a TSB in regard to polymer coated pistons but I am not certain that if that would be the fix here.
Thanks to those who posted the airbag light fix of moving the seat up, it worked for me!
Hey on those flickering dash lights you can install the alternator ground screw yourself but it is a bit hard to access. It took me 20-30 minutes but I was too cheap to pay the dealer $80 to install a machine screw. BTW the only difference seems to be the new screw comes w/ a wavy washer under the head.
Any thoughts?
Good Bless
alien10
Our van exhibits the rapping sound steadily every cold start. In our kind of driving the van gets a lot of cold starts, or at least where the engine has cooled down some.
I am thinking about running it thru the winter here in the Midwest and then pursuing repairs.
I have yet to see how it sounds at 10 degrees!
I am curious how long did your van stay quiet after the rebuild?
I keep pretty close tabs on our vehicles so hopefully I will be able to catch the intake gasket early if -or should I say when- it starts going.
alien10
The TSB used on my engine addressed noise caused by wrist-pin fit. If the tolerance of the hole was high and the pin low, the stackup would be a noise source.
be cut at the shock connectors and then have the connectors for the Gabriels spliced on? The stock lines seems like they're the same size as the lines for thr Gabriels. This would make things so much easier if it's possible. Any comments would be appreciated
air compressor for the spring upgrade. I never did get that thing out. Everything seems ok without the upgraded spring so I'll play it from there. Thanks again for the response.
"A new design intake gasket, P/N 89017279, has been released for service on the 3.1 and 3.4 engines and is currently available from GMSPO. The material used in the gasket has been changed in order to improve the sealing qualities of the gasket. The instruction sheet sent with the gaskets advises the technicians to replace the intake bolts with new ones that have a thread locker adhesive added. Currently the new bolts are unavailable from SPO. In the interim, the technicians are to clean the existing bolts and then apply a thread locking adhesive, P/N 12345382, and tighten to a new torque specification.
The new torque specification is a 2-step process; tighten the vertical lower intake manifold bolts (the four middle ones) to 7 N·m (62 lb in). Tighten the diagonal lower intake manifold bolts (two on each end) to 7 N·m (62 lb in). Tighten the vertical lower intake manifold bolts (the four middle ones) to 13 N·m (115 lb in). Tighten the diagonal lower intake manifold bolts (two on each end) to 25 N·m (18 lb ft)."
Be sure to mark the push rods as they are removed. Intake is different length from exhaust. When reinstalling torque rocker arm bolt to 14 lb ft plus 30degs.
A lot of things have to be removed but the job wasn't as bad as it looked. Helps to remove the two top engine mounts and rock the engine forward. Gives you some room to work on the rear bank. Might also consider changing the t-stat. Much easier with the upper manifold off.
I've read on other ng's the bolts are now available.
Enjoy!
The questions I have for you is around the serpentine belt. (mine is making noise after 95,000 miles.) From reading your narrative, it sounds like the alignment did the trick. Was there anything else that helped to solve that problem?
I was a hotel volunteer last night for the Special Olympics. Rode there in the usual big white Ford Econoline. Suprising, as it wasn't as tinny and junky as I expected. Not great either, but a lot less rattly and shaky than I expected.
Then this morning we got picked up in a relatively new, 2004 I think, white Venture LS. Couldn't see the odometer but it looked fresh in and out, but IT HAD TO BE ONE OF THE BIGGEST PIECES OF JUNK I'VE EVER RIDDEN IN! Thought something was weird at first when the power sliding door was dead and it was really hard to close manually. Started off, and holy crap, sounded like it was about to twist in half even over the smallest expansion joint or turn in the road--both sliding doors buzzed like crazy against the body, the back liftgate was squeaking, something in one of the back quarter panels was making a loud haunted house creaking noise over bumps, the roof creaked, etc.. When an Econoline puts it to shame, that's sad.
I'm always picky about rattles, but this thing was just insane. I can't imagine what it'd be like after 2 or more years--if it were still in one piece that'd be a good thing. Wasn't 100% bad though, as the engine and transmission were smooth and silk and actually sounded pretty good even though the van was overloaded, it actually seemed well insulated (not much road noise at all), and the dash was actually the one part that made no noise.
All seemed to pretty much fit with mag reviews I've read though. I just can't imagine why anyone would buy one of these heaps after riding in one!
We have a Montana and we love it. Zero rattles and no issues so far at all. It sounds like you were mis-using the power door, if you pull it too hard it gets stick like that. No surprise at all.
You can't judge a rental as being the norm, these vans sell well and it's because they are very good and reliable in general.
As a bonus, you get the best fuel milage of any minivan I know of (not counting euro vans with diesel).
RE; air shock replacment -
The spring replacment on the air compressor is a bit awkward but not tough. I am not sure if I have ever needed the additional capacity, but I like knowing its there if do.
I try to do my own repairs in most cases therefore a good manual is important to have.
Owner's manual for our van indicates there is a service manual available thru GM for a cool $120.
While $120 is steep it is worth buying if the manual is good.
Does anybody out there have this manual and found it to be useful for a DYI person?
I have the Hanes book but in the past I have benefited from having a factory manual as well.
Thank You and Happy Thanksgiving !!!
Alien10
There IS a great deal of information in those books, but getting it out and comprehending it is difficult. Perhaps if you are used to GM manuals you will not have any trouble. but...
I would honestly look at Chilton's or something that might be more user friendly. I have always bought MFG manuals, but I don't like this manual, esp. after using excellent Dodge manuals that would describe the high level overview of whatever, such as the fuel injection or suspension, giving a great insight as to the design and why it was setup like it was. The Dodge manuals were so good I would read them like a book and learn stuff. You certainly don't get that in these manuals.
Dirk
98 Olds GLS
I have read many of your postings on this board about different stuff so I value your input on usefulness of this manual or manuals.
Me too got used to excellent manuals from Volvo for our old 740 wagon. They were a series of books, very helpful in maintaining and understanding the car.
Yeah I don't like to beat on stuff either unless it is called out for. I have messed up enough times to know better. That is were a good manual comes in.
Will look at Chilton and others that I may be able to find.
Alien10
Here's an ebay link to give an idea of cost & what's covered. http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1- - - - &item=4505925107&category=43989 They seem to appear frequently. The CD version has an advantage that it uses Internet Explorer and uses hyperlinks to navigate to the various pages. This avoids what Dirk mentioned about jumping from section to section. Another plus is the TSBs are included. Anyway another option a little cheaper than the paper version.
Other than that, 110k on the van, no major problems.
My intermitent wipers are working intermitently, typically they stop in rest position and stay, you have to turn it to LOW or HIGH to get them back moving again. Anyone else have this problem and what was the solution? Is this a motor problem, or a controller problem? I dread looking this up in the manual....(grin)
I was lurking in the Honda/Sienna board and its funny, the "top rated" sienna apparently has a auto trans 'kickdown" delay that irks some people used to vehicles that have more responsive drivetrains. The Honda has complaints of torque steer. But overall, folks like them. Both are probably very nice but I really don't want a car payment - and a mushy riding sienna is not my style! I posted how they were nice vans but for my money a used GM was the best value and now we have no car payment at all. I could see the Honda eventually perhaps....my wife who I've also converted to being frugal-ish says we should drive the Olds 5 more years, as we just got new Michelin's for it. (grin)
We're expecting #2 in Jan, so we'll soon the extra seating...
D
