I "used to" have 1991 Corolla. believe or not I have all the similar problem you have.
First at the first 5000 miles, I noticed that my front tire wear out unbalanced, I ask the dealer check the alignment, the answer is " no problem, I also ask the dealer to retate the tire.
But at the 10000 miles, I noticed again my front tire wear unbalanced again. I ask the dealer check the alignment again, I still got the " no problem". and the dealer kept blamed my problem to the Goodyear tires problem.
On the freeway, I also had fade right problem, but the dealer can not corrected it.
at 12000 miles, I had high pitch sound while I drove on freeway exactly at 65 mile/hr. I brought my car to 5 different dealership in San Diego, Calif, none of the dealership can find out what's wrong.
Finally I files the lemon, Toyota rep. was so bad and rude. AAA was the third partly to make the judgement, their answer was " repairable" and turned down my case.
Finally, I sent my car to one of the Goodyear tire dealer, they did the four wheel alignment for me, they print out the computer read out, adjust my alignment, my problem tire and fade problem gone!!!
What about my high pitch sound? believe or not? two months later, I found that my lever to switch the fan blowing was not working, the dealer fix the problem just because of the cable loose. then my high pitch sound gone also.
This was a very bad experience for me to deal with Toyota, they did not really want to help you to fix your car problem. Since then I do not buy Toyota anymore.
on it.
Now it has 18,200 miles, recently, when I press the break peddle, with speed of 15 to 25 miles I feel I don't have any pressure for about 1 or 2 seconds than continue to press the break, I get the break back.
It doesn't do all the time but happened 3 times
in the past 30 days. It did not happened when I purchased. I am very scared when I press the break and I don't have any pressure, feel like my engin is dieing for while or so.
Any one had same kind of problems? I am going to take the car to local dealer, but I would like to hear from 1999 Corolla owners for matter of interest.
JSLEESI from Seattle Washington.
About brake on 1999 Corolla.
Jsleesi. Was A/C on when it happened? And stay away from my rear. I live in Seattle too:-)))))
Any way check the brake fluid level. Any warning lights came on?
Thanks for your input, I now feel much comfortable after reading your comments.
I did took my car to the dealer, one of break tech took the car for test for about 15 minutes, came back, saying he did not find any thing wrong with it, he told me that he been with Toyota for past 20 years only on break job, never heard and never seen.
He never told me any thing about what you have described in detail. I thank you again.
I have not had any more incidents since I posted
in Edmunds trouble section.
Thanks again,
jsleesi from Seattle.
any thing about:
1: Time belt
2: Fuel filter
How often I have to change fuel filter?
Can any one knows? I did not ask the dealer, because I have better luck with Edmunds friends advise than some local dealer or such.
I would like to hear from some one,
jsleesi in Seattle
etc. If not you should search back in this topic
and find it.
Looking forward to your reply from Toyoto.
They never replied to me on same subject.
Charlie
I appreciate any help and input.
I ask the manager about Dupont and environmental safe paint and he said the last time car paint was changed was in 1980 and that was because of the lead in car paint. If the paint quality had changed he was not aware of this. He said that after a car is painted a final coat of polyurethane is applied to protect the paint. He believes the problem is with the polyurethane coating. I'll keep you posted.
Charlie
There are brown & black spots all over the car, they can not be wash or wiped off the only thing that seems to take them off is if you scrape with your fingernail. I am not sure if I have a bad paint finish or something else.
Do I have to get service done? Or Is it Okay that way, why the black particles in break fluid resovoir?
Has any one had this problems? Is my break is okay with the black particles in my resovoir? or I have to get break line flushed?
I need help!!!!
Jason
Jason.
I will wait and see more of the black particles
collecting in the filter. If more will appear, I will flush out. Thanks
Jason
Bruce
This is a question for our Smart Shopper conference, please.
Your host, Bruce
By the way, a better place for your message would be in our Smart Shopper Conference, that's where folks talk about buying. You can use the Topic Search feature on the left side of the page for an appropriate topic there in which to post.
Pat
My 2000 Corolla has run for exactly one year. Now,
I notice some unknown noise coming from the car.
Could anyone know what is the problem?
1. When the car run over bump slowly, the suspensions make some squeezing noise. Is it normal?
2. When I step on the brake and turn the steering
wheel at the same time, some squeezing noise comes
out from nowhere. I don't know if it is from steering parts or brake parts. It sounds like something is not lubricated well. Any idea?
I'm bringing it to the Dealer this monday to see what they can find. (They can't duplicate the problem the 1st time).
www.toyotarepair.com. So I'll be glad to hear some outputs.
I was reading the Service Manual and I found that If you drive your Toyota under heavy conditions(patrol car,taxi, etc.) you have to change the timing belt at 90 000 miles? I do not drive that way. Does this mean that the timing belt can be non-serviceable on 98 Corolla?
Regarding the timing belt/chain. The 98 corolla used a timing chain with a recommended service interval of 90K miles. I would change the timing chain at 90K regardles of the driving condition, just to be safe, since you never know if its going to fail, and when it did, you are going to get stranded. Better safe than sorry.
The car hums @ 90 mph and gets about 33 mpg combined. It recently started running terrible and I figured all of the abuse finally caught up to me and it was ready for the scrap heap. I checked the plugs and the wires were cracked. I changed the plugs, wires, dist cap, and rotor and it hums again. Cost me about $75 and I did it in 30 minutes, and I am not handy with cars. The only thing that seems to wear out is the exhausts-every 2-3 years. Must be the angle of the tailpipe allowing water to collect in it.
I am getting a new 2001 Maxima, but will keep 'Cory Corolla' as an insurance policy and for snowy travel, in which it handles like a snowmobile. I'm probably in the wrong forum for this, but I love that car and just felt like yapping.
It sounds like something is dragging under the car or something like that. It usually happened when the gear was changed from 1 to 2 and usually after it runs on highway long drive, but not always. It is not annoying if I don't pay attention to it. But I am worried. What might be the problem?
If I take the car to the dealer, how can I explain it? It doesn't always happen, especially when the car is cold.
