Because a 72 Vet came originally with Dot 3.
I'm not much of an expert about this. But I would think the system had the Dot 3 flushed to put the silicone in it. So, I would think you could flush it and get Dot 3 back into it. But I've never heard the Vet nuts talking about taking a car back to Dot 3.
Either way, I would not think the entire system would need to be replaced. This would would be a major job to put new steel lines on a car, usually only done in a total restoration with the body off the frame.
Only thing I would know to try would be to disconnect all the lines. Blow them out with air. Be sure the air has good filters in the system, don't want oil or water from the air in the system. The 4 calipers would be the toughest to get the fluid out of. Rebuilding these would be the sure way of doing it.
Get all the fluid out of the master cylinder. Rebuild it also?
Then bleed, bleed, bleed. If you could get someone with a power bleeder this would be the best way.
"For the Chevrolet Corvette, interest rates range from zero for a three-year loan to 2.9 percent for five years."
Good way to save a couple thousand if you are in the market.
Btw, I really love the Z06 for now, I'm in a hurry to go back to work tomorrow morning.
Thank you for your help,
Sylvain
2002 Z06 Silver Vette, modifications will soon begin... Any suggestions? A better flow system for sure, what next...
Sylvain
As to the skip shift, most really hate it but I have learned to live with it through trial and error. Getting up over 2k rpms in first is actually fun most of the time, and so what if they look if you need to back off a little to keep it down. Seems most local Corvette clubs have someone who really knows the best local source for an eliminator.
Many change the stock exhaust on the coupe/vert but with the titanium system on the Z06 I would wonder about the benefits. The Corsa system that I hear many like is actually quieter at idle than the stock system and gets louder especially at WOT where better flow really helps.
Just some thoughts from a relatively new 2002 EB Coupe owner. ruking1 may have more ideas specific to the Z as well.
Yes, the crackle pop is very normal for an "abnormal" break in RPM. I would HIGHLY and DEFINITELY recommend that you stay UNDER 3000 RPMs at least during your break in period. Massive deceleration is particularily punishing on the engine and drive train components, not to mention the fact that on deceleration there is NO rev limiter in case you happen to make a mistake in shifting or controlling your RPM's!! You will probably hear some folks tell you to drive it like you stole it, but I am reminded that there are a lot of folks that do that and afterwards their cars run like they have been stolen!!
There are a number of ways to lessen the annoyance of the skip shift: 1. A .56 cent to 20 dollar skip shift eliminators 2., 3. Shift before and/or after the the skip shift RPM range comes on 4. And under certain cases start off in second gear,(like when you dont come to a complete stop if the stoplight turns green).
There are OEM and aftermarket solutions to your need for a trunk isolator and trunk cover for the center recessed portion of the trunk. You might try WWW.Corvetteforum.com in the mall section.
Enjoy your Z06 !!!
The competing best flow systems are: Vararam, Haltech, Vortex, Blackwing, and I am sure I have left off a bunch more. On the exhaust department you might want to consider the Borla Stinger which has out of phase noise cancelling going on. It is a straight through pipe design and is much louder than stock. Dynos have indicated 40 or so rwhp !!!! Headers of course help you with app 10 hp. But the coins start to add up! So you can see starting with 405 plus 10 plus 10 plus 40 = app 465.
Before you even do mod one, you might want to do a survey of the dealers near you who would possibly do warranty work for you in the future. Some dealers are ok with mild to wild modifications, others will void your warranty if you just look at em funny.
Maybe I haven't understood well but was it "normal" or completly "abnormal"?
Thank you for helping,
Sylvain
Sorry: NORMAL !! I was reacting to higher revs during break in.
I noticed a little SOTP gain from the Blackwing, but no SOTP from the Stingers - the Stingers are strictly for SIGHT and SOUND enhancement!!!
I doubt there would be any HP gain at all on a Z06 from the Stingers as the stock Z06 titanium exhaust is already very well set up for free flowing fun. (It also costs 3 times the price of the Stingers anyway).
Of course EVERYTHING is relative and sometimes confusing. I have heard of folks doing the Blackwing and feeling NO difference and others saying it really woke up the car enormously. I have heard others say all you have to do is to remove the stock Z06 air cover and use cable ties to secure the stock factory air filter. I would not do a Blackwing modification for while it reputedly flows more air they do NOT gurantee that it filters better than the cheapo 10 dollar air filter, that to me affects reliability over the long haul. Keep in mind that the Blackwing is 20 times the price!!! So if I use cheapo 10 dollar air filters I can buy enough to last 600,000 miles.
The Stinger info I gleaned from a Corvette mag article where Lingerfelter did an AB test with a Stinger exhaust. The Stinger exhaust gained between 37-60 hp on a dyno. Can I say it is true? Well frankly I didn't do it. I have done Borla exhausts on other vehicles and truly was under whelmed. (less than 10 hp) But they do sound "better".
Personally, I am highly skeptical of almost ANY modification. There is almost ALWAYS some trade off or issue with durability, reliability, craftsmanship. While almost always the vendors stand behind their products it is always a PITA to rectify these things.
I almost forget to mention that you have to treat the Blackwing system by degreasing and re oiling the cotton gauze filtering material., which is another extra cost and extra procedure every what 15-30k miles?
The "mods" that I have been happy with have been:
1. conventional ATF to synthetic ATF.
not only are the transmission shifts less notchy, but I have gained app 1 mpg and it seems to run far smoother and the infrequent popping out of first or second gear does not happen at all now.
2. I went from an 2001 to 2002 airbox. This was barely a SOTP improvement, but I might add that SOTP feeling is usually 3- 5% or in the Z06's case 11- 19 hp While I feel better air flow and get app 1 mpg from this mod, and it feels stronger at the same RPM and speed points, it doesnt have stand up and take notice written all over it.
Please email your answer (if possible) to r_a_y_d@hotmail.com
Thanks in advance guys!
http://www.corvetteactioncenter.com/forums/showthread.php?s=&threadid=11842
Good luck!
Mark
Normal condition for occurance is:
Tank(s) are usually about 1/2 to 1/3 full.
Car has been running for 40 minutes plus
It's hot outside
All this leads to a combination of situations that give the empty tank reading.
I have the advantage of an inside contact at Corvette in the fuel systems group and the problem has taken a great deal of effort, but if you live in a hot climate, drive longer periods, etc - all the fixes are for naught
On the good side, remember it is just an annoyance. Shut off the car, restart and your good for another 45 minutes, or top off the tank and your set again till you hit that 1/2 to 1/3 level. Yeah, I recognize that this is small condolances as the General ought to be able to make the damn gas gauge work, but it's still one hell of a ride.
You can go to the following link for service bulletins for help.
http://www.corvetteactioncenter.com/kb/index.php?ownertopic_id=33
Best of luck
My 2001 MN6 is in the shop as we speak to have the recall fix applied due to an inconvenient lockup on the weekend.
With a C5, you can notice it literally a mile away, and that's the way it should be. I will be hanging on to my C5 for a long time if the C6 looks anything like the pictures.
We're getting a 50th Anniversary convertible and are wondering whether we should get the body side moldings. Cost is (obviously at this point) not a consideration...
What do you think?
John Mulhern III
In so far as getting the moulding for "protection" do you think it likely that someone who will give you a door ding has measured precisely that his scofflaw door will hit right on the moulding? I am thinking that it is looks, pure and simple.
I like the look, but at the same time I dont't have that option on a white 2001 Z06.
In terms of the amenities and options I think that the coupe and convertible probably has it over the Z06. Also some folks would not like the look of the hardtop! I happen to like it and like the car hemetically sealed while driving at speeds the Corvette is capable of. In addition to being lighter and faster the suspension comes with the more "performance" set up. But I think you also can not underestimate the increased grip due to having oem Goodyear F1 SC's. which are an inch or two wider at each tire.
So, you really can't go wrong either way.
http://corvetteactioncenter.com/forums/showthread.php?s=&threadid=14619
Pretty interesting.
Good luck with the 50th!
Thanks for the link! The new shocks sound like an almost radical improvement over conventional shocks. I would be interested in seeing and also feeling the skidpad #'s!
Theoretically, if you have a new Vette and you're going to a packed restaurant on a Friday night, should you theoretically park exactly on the space line so that you exactly take up two spaces and thus no one else can use the extra space that you need for your overglorified Chevrolet and they have to park on the other end of town and walk across the river to get to dinner?
Also theoretically speaking, if you were this theoretical (and probably typical) Corvette geezer, would you theoretically give a crap if irate restaurant patron "X" decided to write on a piece of paper "free ticket to [non-permissible content removed] of the Year Award for 'Mr Cool' - nontransferable - cash value 'two cents'" ...? or would you theoretically throw the 'free award ceremony ticket' to the wind before plopping your oversized butt in your driver's seat when you had to run out to your precious overglorified Chevrolet because eventually someone realized that you're not "all that" in your overglorified Chevrolet (i.e. laws and reality do apply to you) and they (maybe restaurant management, maybe restaurant patron "Z") called the police? Excellent way to shop your woman a good night on the town, eh?
Or would it theoretically not matter unless the free ticket was hastily written on Acura NSX stationery?
All theoretically speaking, of course. I'm sure this is an "isolated incident" and no 'Vette owner would ever dream of doing such a thing. Even though it happened and it seems altogether typical to a certain person "X." Theoretically speaking, "X" wants to believe that Vettes attract the world's least desirable females, but maybe it's just in the Detroit area. Haven't been to California recently, but it wouldn't be to look at "exotic" Vettes.
Sylvain
Incidently, on a crowded Friday night a Acura Intergra Geezer trys to make a left turn from a shopping mall into a fast moving street without stopping for the red stop sign that it was supposed to stop at. He nearly plows into my drivers side door as I pass with the right of way on the crowded street. Lucky for him my "bad handling " suv motored around him. He would have had a dead passenger if I hadn't.
My parking garage here in Ann Arbor is home to a bunch of obsessive modified Hondas... I'm about 2 cm short of their "centered in parking space" record. >:(
That guy jumped out of the restaurant and threw his Vette into gear just as the police arrived... they let him go. Now, they had to help all the SUV people got out of their gridlock! Funny as heck. My parents drove right in with the Outback and dived into a parking space which had just opened up. Fine with me (parking on the other side of the town)... the place WAS a door-ding waiting to happen. 'especially with all the Michigan State people around...
This guy's Vette looked like he had spent 15 minutes at least trying to get it exactly symmetrical right on the line. Who is going to think he is special enough for that? Vettes are everywhere here, even new ones. Let's follow your logic. Other Chevrolet (=Impala) people are jealous of Vettes... Cadillac people think they're better (whatever!), and import sports car people, whether Benz or Acura or Porsche or Ferrari or Jaguar, are going to laugh (after they ding it).
This guy was asking for trouble and all he got was my sarcastic note (which he didn't even read... in a hurry before the police decided to give him a talk)... could have gotten more. Talk of the restaurant, obviously, because no one else could park in that valuable space he was taking up... and it's not like the clientele here was unable to afford it, pretty much a bunch of upper-middle-class Detroit suburbia types, all work for GM/Ford/Chrysler anyhow and drive Bonnevilles or Sevilles or Mustangs or 300Ms or Envoys or Expeditions or Grand Cherokees or Auroras, all nice new cars of not-exactly-beater value.
He comes out of the place, but not running fast enough to mess up his hair... "Mr Cool" who wants to look like a million bucks (meaning he should drive a XK instead at least) with his ugly-as-heck (my subjective observation) wife (or mistress).
No one would have cared if his Vette has parked centered in the first or last space in the lot, and you can bet your GM Card that the people in the Aurora or DeVille next to him weren't in any particular line of logic to be careless enough to dent his precious Vette.
But instead he wanted attention and got it. Not because he looked tackier and the chick looked worse, but because the car was nice, new, and clean... and because he thought maybe a $50K Vette was worth two spaces when a $40K Seville wasn't worth the one that he used up.
But I believe that a Corvette centered exactly on two spots attracts very negative publicity. It stands out as to the character of the owner. Not good.
