Miscellaneous Truck Questions
I see lots of 150's but need the strong suspension to pull with or the front comes up.
Is their a problem with them, I see few F250's on the lots.
how much higher?
- The Merg
- The Merg
More weight is also better, used to carry a ton of block in my F350 2wd. Stuck pretty well. Studded tires and chains also help alot. You can put the new Z chains on in less than 5 minutes a side without moving the truck.
Cabs. Does anyone know for sure if a B cab is a
regular or an Xtra?
friday I need to put my hitch on it from my 97 F250 light duty. The Dealer mounted it about 6 to 8 inches behind the center of the rear axel on my 97 this seems to far back to put it on the 99, should I mount it over the axel or should I keep it further back,I don't want to turn to sharp and put the camper into the rear of the cab. Even with it mounted 6 to 8 inches back I had to be carefull not to cut it to short. What is the best location to mounted it on a short box pickup.
use the edmunds pricing guide for used trucks on this web site.
i'm new to this but I have a few questions to throw out there...
1) If I use the four wheel drive of my 1991 ford f-150 4x4 then put it back into 2wd the front drivers side spline seems to want to re-ingage at about 15 MPH any ideas???
2) The vin on my truck specifies a 2.6 liter or 3.2 liter v6 to the best of my knowledge this has never been an option in this truck ... what gives???
I have a question that needs an answer. My sister owns a 1997 ford f 250 crew cab 4x4 with the power stroke. recently she has had a problem with the transfer case appearing to engage by itself when she makes a slow speed left hand turn and sometimes during braking. She says it feels most pronounced during turns. Her mechanic disassembled the entire front end, greased the hubs, ajusted all torgue requirements, and said he could find nothing wrong. has anyone else experienced this problem. She has the shift on the fly hubs. I suggested she upgrade this system to a manual hub system. Any help would be usefull. She fears a trip to the dealer for this.
Here in California you can't even have people ride inside a covered bed unless they are seat belted in. Thank you in advance for any info
If my memory is correct, the T series is a 4X4 S-10 compact Chevy truck, simply identified as a T-10.
I am a salesman on the road a lot. I am 6'3" and weigh 300#. I can't fit into a ranger. Should I buy a F150,F250, F250SD or an F350. I don't pull or haul anything. Just want the most cab room in a pickup. Need to factor in operating costs and comfort. My other Vehicle is Jeep Grand Cherokee.
My wife requires a decent ride with out jarring her teeth out. Suggestions? Please give me some feedback.
F150 Extended cab, with Bucket seats, and the small v-8. that should give you the best room for the cheapest operating cost, and a good ride.
But if you want even cheaper operating cost (better mileage, no maintenance for 5 years), a better ride (depends), and even more interior room (cab larger by 5 inches), go drive a new Silverado extended cab.
Any advise would be helpful. I really dont want to get rid of the truck.
Any info is appreciated - thanks! :-)
My advice would be to go to one of your local shops that make the truck racks for the guys in the construction trades. Probably they could build a rack that fits your truck and the kayaks. You may have to design the kayak part of the rack. You would get exactly what you want and need.
Rich
That is an excellent idea - I could easily buy foam protectors to rest the kayaks on and still use my tie-downs....thanks!
ladyblue
Community Leader/SUV Conference
ladyblue
You will want to seriously look at the f250 SuperDuty.. They are priced VERY CLOSE to a normal f150 but are bigger in every aspect. Interior room would fit most NBA players.
They are smooth on the road, (firm ride but definatly not jolting or rolly). If you get the 5.4L engine you can expect mileage between 13/15 mpg. (which is alot less than a Ranger, but not that far of of an F150).
F250 SuperDuty SuperCab 2wd short bed vs same f150
Longer: by about 3 inches, bed is 3 inches longer
Wider: by about 4 inches. Seems like more inside than outside.
Taller: ALOT, you literally look down on Suburban roof racks. (yes, even the 2wd)
Best of all, the truck will fit you.. Plan on getting the running boards so the wife can climb in.
Its sortof a stretch to call it a commuter vehicle, but then again, folks use 4x4 Expeditions and Suburbans for commuter vehicles every day..
Check one out, I think you will like it..
I own a 1994 B2300(Ranger disguised as a Mazda),
2.3 liter 4 cylinder engine.
I bought it with 42,000 miles on it. It now has
82,000 miles on it. I love it. I have only had
to tune it up once, and I am religious about
changing the oil every 2,000 to 2,500 miles. One
question though: obviously the vehicle lacks
power, but sometimes when I am pushing it on the
highway, like trying to climb a bit doing 55, I
hear a flutter coming from the engine as I depress
the accelerator to compensate for the hill or
whatever. Almost sounds like a diesel engine at
times. What is it,
and what might happen? It doesn't affect the
overall performance of the vehicle; it's simply a
weird fluttering sound.
