I think the original question was "miles", and the answer is 100K for non CARB, 150K for CARB states. The warranty is either the years OR the mileage.
So that hybrid with 75K is 1/2 way through the mileage warranty.
If the battery is "fully" charged, and you are traveling at 45 mph, and you shift into L, the engine may rev to dissapate power from the generator motor when it is not allowed to charge the battery any higher.
MODERATOR /ADMINISTRATOR
Share your vehicle reviews
I don't expect Lexus quiet, but my 92 exlporer is decent and you don't have to crank the radio.
-Your input is appreciated
I just took a 50 mile (one way) trip in my new 2008. It is an AWD. It is NOT loud on the road, but then I never got over 70 MPH. In fact I noticed how very quiet it runs.
"On AWD Escape Hybrid models, a third electric motor steps in to drive the rear wheels when extra acceleration or traction is needed. It's not a true all-wheel-drive system, though, and buyers needing a serious snow vehicle will be better served by the regular gasoline-powered Escape."
I think that the FEH uses a mechanical (electronically controlled) AWD system. The owner's manual has no warnings about the AWD system over heating, such as I would expect of an electric motor, and the underside of my FEH appears to be a normal AWD transfer case.
The following is from the owner's manual, page 151:
"Power is supplied to all four wheels through a transfer case or power transfer unit. You should become thoroughly familiar with this information before you operate your vehicle."
This would make the FEH a superior AWD system over the all-electric Toyota HH (in my opinion), because it isn't subject to overheating and shutting down.
Excuse me, but my QUOTE was accurate. The whole point of my post was that the Edmunds REVIEW was inaccurate.
If I understand you correctly you you are confirming my post.
[sheesh, sometimes responses in these forums get so emotional]
[sheesh, sometimes responses in these forums get so emotional]"
Ah, right. Just to reiterate - here are the points.
1. The FEH has a mechanical AWD system.
2. The Edmunds review of the FWH INCORRECTLY describes it as having a "3rd electric motor" to run the AWD system.
I was actually hoping that the host would pick up on this and get the editorial staff to update the review.
This is an important advantage to people in the snow belt: the Toyota HH AWD electric motors will shut down if they overheat (such as spinning a lot). The FEH mechanical system is not subject to these limitations.
But in any case, do you have a URL that explains the system? I am assuming it is the same electronically controlled system as the ICE only Escape, but the Ford vehicles website doesn't have any details.
FWIW, I hit the AUTO button because Ford vehicles are set to turn off the fans until the engine is heated up. Since the FEH has no engine temp guage, hitting AUTO gives a rough idea of how the engine is doing on the warm up, although the fans will run for a while before the engine is hot enough to use EV.
I already know that turning off ECON will run the compressor, and turning on the defrost or defrost / floor will also activate it.
Does anyone know how the FEH is programmed to turn on the compressor?
Has anyone else experienced this kind of problem?
The dealer had a 72hr exchange policy but only for something equal or greater in value from whats being returned. got a ford edge now.. will continue to look into hybrids however.
Occasional cold starts when the temperature has plummeted to -40F (-40C) were not a problem. One's fuel economy does take a bit of a a hit during the winter months but that is to be expected with any vehicle.
Having leased several Ford Explorers since 1995 plus formerly driven a 2005 Escape XLT, I often say that this 2008 FEH is my ultimate dream vehicle -- which is good since I'll be driving it for several more years.
Stephen @ Canmore, Alberta
in your scenario, IF you get this model in the both axle drive,
i would certainly say that replacing the factory tires with a really
good snow and ice rated set is the most important thing you could
do to make your FEH a better winter snow beast.
my experience with the Continentals on my vehicle (a 2008)
has been that roads with broken surfaces, ridges,
or anything which might be less than ideal conditions
is unsettling to my factory tires.
it goes ok, but the change to something like Blizzaks will
really make it keep it's teeth on the trail.
mine makes at least 3 distinct sounds one of which is
whistling and they are most noticeable when
i am at or below the gas engine starting event.
the other noises both sound like a state cop with
his siren on chasing me! my wife thinks the same.
heard was accurate. (delays due to battery supplier being
the main problem i have heard)
i placed the order in the last week of Dec., 2007.
just got the vehicle last week. June 2008.
i thought with such a late order cycle, mine
might be a 2009 but all the papers show
it is a 2008.
tires on your vehicle? i started this on all my
trucks and cars a few years ago and can't believe
the difference it makes in snow or ice or even
heavy rain for that matter.
traction is the key.
i know my FEH needs these and will have them
on before i see flurries in the Northeast USA.
Do you leave the snow tires on all year or change them back seasonally?
I never thought about the tires because I don't plan to use the FEH off road. I just want to be able to stay on the roads in conditions that are less than ideal - especially the steep and curvey mountain access roads in winter. Afternoon flurries are common here and can make these roads pretty treacherous when descending at the end of the day. The highways are generally OK except when the snow is falling but then visibility tends to be the limiting factor for my Jeep rather than how slippery the road surface is.
My Jeep came with all-season radials (Wranglers) and I never had a problem until they were almost worn out. I had to replace them last Fall after 50K miles and bought some Michelins that turned out to be mud and snow tires (I didn't realize- I just liked the tread). I felt a difference right away but I'm comparing new M&S tires to used-up all-season radials. It's a good thing I do most of my driving in the winter because I don't think these tires are a good choice the rest of the year.
Where you live, do you have extreme low temps overnight in winter? I'd also be interested in your experience with the FEH batteries and electric motor in these conditions. And the gasoline motor is tiny - right? Does it really heat the cabin OK in extreme temps? I find when I'm driving my Jeep in falling snow, I need to blast my heater onto the windshield to prevent my wipers from icing up. Sometimes this is not enough - that's when I know it's time to get off the road and wait it out.
Any experience you or others reading this have had with FEH's in extreme conditions would be greatly appreciated.
Over time the gauge should correct itself.
my basic analysis, which excludes finance charges, insurance and annual property taxes is pretty much a wash @ $4.00 per gallon over 5 years.
anyone else have an opinion?
my basic analysis, which excludes finance charges, insurance and annual property taxes is pretty much a wash $4.00 per gallon over 5 years.
anyone else have an opinion? "
If your 04 Escape is running well, you will never make up the difference in payments (zero $$ with the 2004, XXX $$ with the new FEH) based on the MPG gains. So if you like the 2004, my suggestion is to keep it.
If you are definitely getting rid of the 04, then the FEH is a good option, though it is a bit more expensive than a 2009 ICE Escape. A limited will cost you 33K. If you don't need an SUV, consider the Toyota Prius or Honda Civic Hybrid; both are considerably cheaper than the FEH - and get much better MPG.
One thing to consider is the driving you will do. If it is all short trips, then a Hybrid is not generally the best option - it has to warm up the engine before the hybrid technology kicks in completely. It also gets less MPG in winter. A last item is the fact that the FEH A/C shuts off if the car is stopped (in ECON mode) - so you are forced to live without A/C while stopped, or lose the MPG gained by the engine shutting down. The Prius has an electric A/C compressor and does not have this limitation.
"As of June 30, 2008, Ford Motor Company has 55,990 Hybrid Vehicles (in the tax credit window)(Escape and Mariner Hybrids). Based on Sales patterns, it appears the 60,000 unit threshold will be reached within the 3rd Quarter of 2008. If this is the case, purchasers of an Escape Hybrid would be eiligible for the full tax credit until December 31, 2008."
As near as I can tell, the credits run out six months AFTER the quarter in which 60K is achieved, which would be Mar 30, 2009, if I understand you to say that Ford had not sold 60K before July 1.
http://www.irs.gov/newsroom/article/0,,id=157632,00.html
We debated the FEH vs MMH, but, the MMH worked out to be cheaper based on what we wanted. Bummer, is that they don't offer the side steps on MMH.
Also, just checked NPLM website...they are showing in stock 3 '08 MMH's.
