Chevy Silverado: Problems & Solutions
canayjun64
Member Posts: 34
Is anyone aware of a driveline clunk with 2000 Silverado’s or is it just me?
I have an automatic trans. that makes a clunking noise whenever the accelerator is quickly depressed and then released. Is this normal?
Any comments are welcome.
Canayjun64
Canayjun64
File In Section: 04 - Driveline Axle
Bulletin No.: 99-04-20-002A
Date: September, 2001
INFORMATION
Subject:
Driveline Clunk
Models:
2002 and Prior Light Duty Truck Models
This bulletin is being revised to add model years. Please discard Corporate Bulletin Number 99-04-20-002 (Section 04 - Driveline/Axle).
Important: The condition described in this bulletin should not be confused with Driveline Stop Clunk, described in Corporate Bulletin Number 964101R (Chevrolet 92-265-7A, GMC Truck 91-4A-77, Oldsmobile 47-71-20A, GM of Canada 93-4A-100) or Bump/Clunk Upon Acceleration, described in Corporate Bulletin Number 99-04-21-004.
Some owners of light duty trucks equipped with automatic transmissions may comment that the vehicle exhibits a clunk noise when shifting between Park and Drive, Park and Reverse, or Drive and Reverse. Similarly, owners of vehicles equipped with automatic or manual transmissions may comment that the vehicle exhibits a clunk noise while driving when the accelerator is quickly depressed and then released.
Whenever there are two or more gears interacting with one another, there must be a certain amount of clearance between those gears in order for the gears to operate properly. This clearance or freeplay (also known as lash) can translate into a clunk noise whenever the gear is loaded and unloaded quickly, or whenever the direction of rotation is reversed. The more gears you have in a system, the more freeplay the total system will have.
The clunk noise that owners sometimes hear may be the result of a buildup of freeplay (lash) between the components in the driveline.
For example, the potential for a driveline clunk would be greater in a 4-wheel drive or all-wheel drive vehicle than a 2-wheel drive vehicle. This is because in addition to the freeplay from the rear axle gears, the universal joints, and the transmission (common to both vehicles), the 4-wheel drive transfer case gears (and their associated clearances) add additional freeplay to the driveline.
In service, dealers are discouraged from attempting to repair driveline clunk conditions for the following reasons:
Comments of driveline clunk are almost never the result of one individual component with excessive lash, but rather the result of the added affect of freeplay (or lash) present in all of the driveline components.
Because all of the components in the driveline have a certain amount of lash by design, changing driveline components may not result in a satisfactory lash reduction.
While some owners may find the clunk noise objectionable, this will not adversely affect durability or performance.
PF Flyer
Canayjun64
Ryan
Ray T.
There is a TSB related to an A/C concern that would require new parts.
BURP the cooling system. Something about
a air pocket in cooling system. Since no
radiatior cap on rad. you gotta take off
or loosen one of the hoses.....geo
-David
01-01-39-002b
walter (gator)
P.S.
Thanks to all for replying on my "Sticky throttle" post. ....Canayjun64
Ray T.
I was getting pretty close to trading it in for a new one cause i couldnt stand the noise but now it is a dream to drive again (and the $35K sticker shock brought me back to reality oh yea it was a 2500HD ext cab 4wd LS in the new arrival blue)
Ryan
one this time!.......LOL........geo
hmmm well i turn 23 on sat so i guess i am getting there hehe
Couldn't find one in black...geo
Problem fixed. Brought it to the dealer and they cleaned it (sticky throttle). Works like a charm.
Thanks to all....Canayjun64
Ray T. :shades:
A bunch of us GM owners are experiencing this "knock" on cold start up, myself included.
Also try scrolling down to the GM Engine Knock discussion board for more on this issue that GM will do nothing but give you lip service about.
Ray T.
I have a question i hope someone can help me with.
I bought a used 2002 chevy silverado today and while driving it through my town, i could hear a thumping sound from the left front wheel when i hit small bumps.
This deep thumping seem to travel through the steering column.
Is it a loose shock?? My 2001 does not do this.
two more questions:
Does the 2002 have the "guards" at the top and bottom of the ignition key (like my 2001) or is it just a key hole. (I'm wondering if the ignition was replaced)
Last, isn't "keyless entry" standard on this model?? the deal said it was not But he may be full of it.
Please help.
Thank you in advance.
There are no guards on the 2002 models.
Take the truck back to the dealer to have your intermediate steering shaft lubed. Is the truck under warranty?
Here it is:
When driving on a standard city street, around 65 kilometres/hour or 40.3 miles/hour, I get (this is hard to explain) a groaning type of noise. Somewhat like a vibration or shudder. I suspect that the shifting sequence of my automatic trans is done to fast from the second gear to the third (same as a manual trans when it is shifted to fast) perhaps it's from the third to the fourth ... I’m not sure. Could this be related to a faulty modulator valve? Is this common?
In order to eliminate/quiet this, I need to accelerate a bit more to activated the passing gear until I reach a higher speed then it’ s gone.
P.S. Unfortunately, I don't know the transmission model/make for my 2000 Silverado 4.8 V8.... sorry.
Thanks in advance Canayjun64
My only suggestion when driving around town put it into 3rd. (select 3 after the D)
Now why the heck would GM discontinue a fix? This is weird... If there is indeed a fix for this, shouldn't they honor this?
Do you think this could lead to an eventual problem?
Canayjun64
One problem led to another
2002 RADO EXT. CAB LS THANKS AL
Ray T.
Additional info, Upper striker bolts tighten to 18 lb ft. Lower striker bolts to 15 lb ft.
I particularly like this part. If you decide to adjust the door striker plate, do not remove both bolts as it may cause the striker backing plate to fall into the body adding in additional time to perform the repair.
kec1
I had my passenger side doors adjusted. I thought the dealer had done it but when reading the RO, found out that they subbed it to an autobody shop. Go figure.....
Hans
So here it is (for info on the cold draft/passenger side)
brakob@earthlink.net
Just for reference the gas tank is on the left and fully filled it adds a good amount of weight
Also the sag could be attributed to the truck being shipped. Tighted down to the truck hauler to tight
Sometimes springs take a set. OK, springs always take a set. Some just settle more than others. Trying to find which spring is the culprit is not always straightforward. Swapping springs is acceptable.
Be happy you have a dealer who is willing to try and fix your problem. A lot (if not most) of dealers would just say "Its within limit" and let it go. At least your dealer is working on it for you.
Mike L
J
