Fog Lights
i just purchases a 98 dakota sport 4x2. unfortunately it doesn't have fog lights. what's involved in adding this feature? is there an aftermarket kit specific for this vehicle & does anyone know where i can purchase them? also my truck doesn't seem to have a lite for the glove box & ashtray. it's annoying. thanx for the help.
I want to add after market lights in the stock mounting positions.
I believe there must be factory wiring already included in my wiring harness and it is probably tied off somewhere. I figure that 2000 or 2001 and up are similarly set up. My question is if someone has already identified where the wiring is located and/or what color coded wiring to look for. A schematic or wiring harness routing guide are probably too much to hope for.
Bill
Has anyone replaced their stock fog lamps and what brand/model number was purchased.
and the lights are BRIGHT!!!!! Oh yeah, They also have AMBER glass for FOG light use. I took some pix of the mod and put them on my homepage:
http://home.bellsouth.net/p/PWP-ahasher
The accessory package had everything you need to put them on the vehicle, wiring harness, switch, mounting brackets attached to the lights (just like what comes on a factory order). I had my dealer reprogram BCM to make them work. NO CHARGE since I done all the work myself!!!!!
Well satisfied ........
On a clear night, you could use both for max visibility, but I'd NEVER use high beams in fog -
Jim
From Coastal Texas with 98% humidity year-round - we know fog!
DTI Color Vehicle Color Location
Start:
Yellow BLACK/WHITE IGNITION SWITCH HARNESS *
Ignition #1:
Blue BLACK/RED IGNITION SWITCH HARNESS
Ignition #2:
Green BLACK/YELLOW IGNITION SWITCH HARNESS
Ignition #3:
Wht/Blk N/A
Accessory:
White PINK IGNITION SWITCH HARNESS
Brake Light:
Orange GREEN/WHITE AT SWITCH ABOVE BRAKE PEDAL
Tach Signal:
Green YELLOW/GREEN AT ECM PIN B4 **
Parking Lights:
Yellow GREEN (+) AT JUNCTION BLOCK ON PASSENGER SIDE AT ECM
Headlights:
Yellow
OEM Alarm Disarm:
Brn/Wht RED/YELLOW (-) INSIDE OF DRIVER'S DOOR
Diesel Glow Plug:
Red/Black
Clutch Bypass Wire:
n/a
lower case colors are for the alarm maunfacturers wiring that provided this info. The Toyota colors are uppercase. This may help, Rick
Start:
Ignition #1:
Blue BLACK IGNITION SWITCH HARNESS
Ignition #2:
Green BLACK.YELLOW IGNITION SWITCH HARNESS
Ignition #3:
Wht/Blk N/A
Accessory:
Brake Light:
Tach Signal:
Green WHITE/GREEN IN A 28-PIN PLUG AT THE ECM **
Parking Lights:
Yellow GREEN (+) DRIVER'S KICK PANEL
Headlights:
Yellow RED/BLUE (-) AT HEADLIGHT SWITCH
OEM Alarm Disarm:
Brn/Wht RED THAT CHANGES TO BLUE (-) STEERING COLUMN HARNESS ***
Diesel Glow Plug:
Red/Black ARMS WITH LOCKS
Clutch Bypass Wire:
n/a N/A
Regards,, Clubman
Fog lights are intended to make you more visible to others. There is nothing magical about the color, from a physics perspective, since all visible wavelengths are pretty much equally scattered by fog droplets though the eyes are more sensitive to colors in the middle of the visible spectrum.
To aid the driver, fog lights do have a very sharp cutoff helping somewhat to minimize the problem of backscatter but also helping to avoid disorientation.
The BIGGEST things are good quality lights with excellent pattern control and a MUST is PROPER aiming. Directions are listed many places. Basically lights need to be lower to the ground than headlights. Park car facing a wall 25 ft away. Measure from ground to center of light on vehicle, go to wall and measure, the top of the cutoff line should be 4" less than what you measured at car. This way they are aimed slightly down, illuminate the road well, and don't blind oncoming traffic.
Many people that are adding them to their vehicles have no clue on this, don't care, they just want it to look good and "sporty". Unfortunately it's dangerous that way.
Thanks a million
- Rich
They don't go very far or very high because if they hit the moisture or fog they'll be reflected all over the place and create glare. So don't expect your fogs to improve long or medium distance night vision when it's clear out. Get driving lamps for that.
I find most OEM fog lights are weak and low-wattage and aimed way to low, to the point where they're basically illuminating the ground underneath the front bumper and not much more. This was the way the ones on my Dakota Quad were and based on that I assumed fog lights in general must be pretty much worthless. I then tried an aftermarket 55 watt set from Pep boys for 45$ and aimed them carefully. Before with the OEMs on they lit up an area maybe 3-4 feet in front of the truck and threw a very narrow, limited amount of useful light 8-10 feet to the side. The new ones completely fill in the dead spot between the front bumper and where the headlight beam starts and light up whole houses on the side of the road. It's amazing, even inexpensive entry-level aftermarket lamps will out-shine the overpriced OEMS. The stock ones on my Dakota Quad cost anywhere from 150-200 from a dealer for a complete kit and put almost no useful light in comparison. Even just one single Dodge fog light at a dealer costs nearly twice as much as an inexpensive complete aftermarket kit.
So I guess in short I would say yes, most OEM fogs are there purely for decoration. I think they put the cheapest ones they can get from their suppliers on there just to be able to say they offer fog lights on their vehicles. But alot of aftermarket ones make a real difference in inclement weather.
Also, I did alot of experimentation with aiming using the precise textbook methods on PIAA's website and elsewhere on the web as well as my own subjective measures of where I thought they would be most effective. Turns out the angle of aim where I get the most useable light on the ground with minimal useless light thrown up in the air happened to coincide with the PIAA method, which has the top of the beam about 3-4 inches below beam center on a wall at 25 feet on level ground. Too high and I had alot of weak, unfocused light in the air doing nothing for me. Too low and they didn't light up enough of the road in front of me.
I see there are several posters in the Camry Hybrid threads with the same quiery, so I thought I would post here to see what anyone has to say.
The fogs should cut a wide low beam and allow you to see the sides of the road better. If they are aimed too high they will just bounce back at you.
Take a look at this link, and let me know if this helps (unless you have found this already).
http://www.blinglights.com/shopbling/store/comersus_listCategoriesAndProducts.as- p?idCategory=56&curPage=2
Can some one tell me should, when i switch my rear red foglight on, the side lights come on at the same time, or should only the rear red foglight come on. Thanks, Rob Wilson.
