Took it into a Mazda dealer who told me it was OK.
Total crap, I was a Police Vehicle examiner for twenty years.
I took it to a company who had computer alignment equipment who set it up properly. A total different car afterwards, I sent the bill to Mazda who paid it.The delearship disgreed with the findings.
Guess what they closed down a short time afterwards.
I replaced the fronts with ceramic about 4 months ago. LOVE them. It cut the awful brake dust from the original pads down by 90% (at least). Only issue is the brakes squeak the first 2 or 3 times you use them. After they heat up a little, the squeak is gone.
Mazda6 i 2003 sedan
I own a 2004 6s, top of the line. 4 months ago I started to hear rattle noise coming from the back. Long story short, after going to the dealer 3 times, it turns out the entire rear panel where the subwoofer sits is loose/coming apart and had to be replaced.
I guess it's not good craftsmanship. What a shame.
We figured out on the board that the safety mechanism that prevents the car from being started when the clutch is not engaged (or if the car is not in neutral for automatics) was acting haywire. Now, whenever I turn the key, and the car will not start, I just have to disengage the clutch and engage it again, and the car will start. I have an '03 Mazda 6.
Khana
It turns out that the glove box latch was misaligned and allowed the glove box light to stay on even when the glove box door was shut.
So have the dealership check the load on the battery to see if anything is draining the battery while it sits. You never know what they might find out...
I just replaced all the pads on my '04 6s with Bendix ceramics. I've had good luck with Bendix in the past, I like their lifetime warranty, and while they are not always as easy to find on short notice as cheaper pads, at least one store usually has some on a shelf in my area. I wanted to try Hawk ceramics but didn't plan far enough in advance and nobody could get them to me for a reasonable price in less than 2 or 3 days.
So far (after 2 weeks) they are working great. They don't bite quite as well until warmed up which is expected for ceramics. I'm seeing less dust on the wheels than I did with the stock pads, and it is lighter in color. The OEM pads also glued themselves to the rotors a bit (resulting in some pad transfer) when the car was parked and the wheels got wet, but the ceramics haven't done that to me yet so I'm hoping that situation has improved.
The dealer check the computer did not find anything. Like everyone who had the same problem, the dealer said the battery was dead (which in my case could be true, because in February my alternator when down and drain empty my battery. I had the battery recharge but I know I would have to replace at one point) change the battery and the problem was fix, no starting problem. But I told the dealer that will not fix the problem and it will come back. The dealer told me they can't do anything more for now they had to change the battery first anyway because she was dead and the problem is not there anymore so they can't see the starting problem. If the problem come back I will have to go again to the dealer... that sound like it will cost me lot of $$$ trying to find a problem that they don't have a clue!
To date, I have close to 11,000 miles on the vehicle, which includes various driving conditions, and have not experienced the problem described in your email. Nor have I heard of the same problem with other owners (w/ 18" wheels).
It has been over six months since you posted this problem so hopefully your problem has been resolved. There are few things as frustrating as having a new car with an apparent problem and not receiving the proper attention from the manufacturer.
There is a small amount of wobble felt during low speeds and during braking. It is minor and may be caused by imperfections in road surface, tires out of balance during intitial break-in, or rotors that are warped.
I've experienced this increased perception of wobble on other vehicles when larger wheels and low profile tires have been added.
If the wheels and tires are in balance and the rotors true there should be no issue. Difficult to know how severe your problem is without driving your car.
It's under warrenty, barely, but still there. Once I find out what the story is from the dealer, I will repost...
Turns out this is the "normal" failure that occurs when the battery goes dead. Dealer confirmed there was nothing abnormal. Had new battery installed, shop checked the charge and everything is fine. Kind of a relief to replace the battery vs. the CPU or something...
The only reason I go to my Mazda dealer is for oil changes, as I know this car has a goofy Cartridge/O ring system, and for the free Mazda 'inspection'. I just went over the 60k mile mark and they found that my transmission fluid needs flushed. Is there any reason I should go to the dealer for that, or would any place like Meineke be ok for that?
Any competent mechanic can perform maintenance on the 6. No reason not to use an independent that is reputable.
Cost for new Mazda rotors and pads is about $190 total fyi.
If you don't like the cartridge oil change system there is a kit to change to a cannister for the Mazda6 2.3L. Showcase Mazda sells it and any Mazda dealer can obtain the parts.
The question remains though, do you think the average oil change place is ramped up on the Mazda cartridge system, or is it still a good idea to do it at the dealer?
Using an element (cartridge) is not unique to Mazda. Some GM's use them, VW's use them,...etc.
I still use a full service shop when not using the dealer unless I am buying tires.
What is right for me may not be right for you.
The warranty is explained in detail in the warranty booklet that is delivered with the vehicle.
Last Saturday in the driveway, my '05 Mazda6 Sport w/V6, automatic and low mileage (13,500) had the same no-start, crazy dancing needles on the gauges with and without the key in the ignition, buzzing sound when the hazard lights were turned on (or attempted to be turned on), can't unlock or lock doors via key fob, etc. When I saw the bouncing needles on the dash, I too initially thought that the engine computer had fried as others have mentioned. But as I investigated and checked the battery voltage as tehigham did in message #2306, I also measured 12.7 V (by the way, the "green eye" charge indicator that your battery has on the topside is not to be trusted, i.e., if it shows green, as my battery did, the battery is suppose to be fine). Knowing that 12.7 V is too low for a healthy battery, which should read closer to 14 V, I turned on the headlights to load the battery and saw the voltage drop to 7.2V. This told me that I had a bad battery with probably a bad cell. Now I did the following which resulted in a little bit different warranty experience than jbwilk above in message #2360.
1. Knowing that I had some warranty coverage on my battery (I thought 25% since I'm past 24 months per the warranty book), I went to the nearest Walmart to find out the cost of the cheapest battery for my car. The only battery I could find was selling for $53 and had a 60 month warranty. Knowing that the dealer would overcharge for probably a 36 month battery, I called the local Mazda dealer to discuss my situation and then determine the better option. They let me know that they would pro-rate to 50% (better than the 25% I thought) and the labor to install the battery would be covered under the 4 yr/50K mile vehicle warranty (all this was assuming the battery was bad). I asked for a tow since I have roadside assistance (don't we all have this when we buy the Mazda6?) and was referred to Mazda Customer Care (1-800-...). Customer Care arranged for a tow truck and it arrived 45 minutes later (as I was told by an automated computer that called me a couple of times as to the status of the tow truck - worked very well and was accurate.)
2. I didn't let the tow truck driver jump my battery as he wanted because of what I had already found out through the voltage check, but also because I had charged my battery overnight Saturday and still had the no start condition and weird electrical signs.
3. When I arrived at the dealership in the tow truck with my car, I let the service guy know that I also wanted the recall done for the fan control module (code SSP 71) since I recvd a letter on this issue some time ago (April 2007). Now I tried to get him to throw in the battery for free since I argued that the fan's erratic behavior shortened the battery's life (the fan sometimes ran at different speeds after engine shut off or came on even when the engine was cold and the A/C was off). He didn't disagree with my reasoning but ultimately said that I should have had the recall done several months ago. I pushed a little more but he was telling me that if the battery was bad, he was going to replace it at a cost of $45 to me (50% pro-rated). I said that I could get a 60 month battery at Walmart for $53, but then he said I would also receive a 60 month battery but better yet the pro-rating would not apply with the dealership replacement battery. I would, however, pay for the labor to install the new battery if it every went bad which he said wouldn't be very much. I said Ok but also ask that he check the poor performing AC, which he blew off saying that nothing could be done about the weak AC (another dealer had said the same thing to me a while ago about Mazda6's and knowing that a lot of Mazda owners have had this complaint via their messages on Edmunds, I dropped the request). I also ask the service guy to check the sluggish throttle response (even though I had another dealer download the electronic throttle software fix which had almost cured the lag problem).
4. The recall work provided me a rental car for free. I was driven to a Herz rental car agency nearby and made the mistake of giving them my credit card when I was asked. After my brain was finally engaged, but too late since my number was now in the Herz computer, I started questioning the Herz guy why my credit card number was needed. He really didn't give me a straight answer, but he did acknowledge that some people who get the dealership loaner car have refused to give Herz their credit card number. So I take it that you don't need to give your credit card number when getting a free rental car during dealership work. Also, when he asked for my insurance company name, I politely refused and he was OK with that. After I got the rental paperwork, I noticed that Mazda would only provide $30 coverage so I was now vulnerable to any overcharges by Herz (by the way, don't play with the GPS in the rental car because you could get charged $10.95 per day for doing so).
4. Today Tuesday (it's actually very early Wed. morning as I write this), I got my car back from Mazda. They did find the battery to be faulty and replaced it for $45. They didn't do anything about the throttle response issue because I already had the software fix - I was hoping that Mazda had a second update since I'm still not happy with the sluggish response. I also had the oil changed for $19.95 due a coupon I printed out from the dealer's website. So I paid the dealer a total of $67.09 and ended up with a 60 month "Mazda" battery, an oil change, a new fan control module (the fan isn't running erratically anymore), and a car wash plus interior vacuum. This is not bad considering that last time I had my Honda minivan serviced at the Honda dealer it cost me over $800 for 60,000 mile service. I know, I got ripped off...
5. And speaking of rip off, when I returned the rental to Herz (Mazda didn't let me just drop the rental off at their place), I was looking at a big extra charge. Now, before I had left Herz on Monday, I made it very clear to them, knowing that Mazda would provide a rental car for only one day (exactly 24 hrs.), I did not expect to be charged for having the car a little over 24 hrs - obviously, delays can happen with dealership work. I was reassured that this wouldn't be an issue. But sure enough, I had the car for 27 hrs. and Herz was looking to charge my credit card with another day of rental (hence, I shouldn't have given them my credit card!). The other thing I did before I left the Mazda dealership on Monday, I asked the service guy about having the rental car beyond the one day if needed due to the repairs. He said no problem, they would cover any time over one day since I was asking Mazda to do more work than just the recall -
Just wanted to says thanks for you input about our Mazdas.
I have the notice here for the SSP71. I am hoping Mazda can send the unit here and somehow provide me the location to replace it, whether it be Ford, Lincoln, Mercury, Mazda (but I think there is not Mazda dealership in Korea) or maybe through the Army Air Force Exchange Service (AAFES) Motor Vehicles Sales. I am calling after Columbus Day.
As a side note, I used to work for AAFES at Mather Air Force Base in Sacramento, CA over 20 yrs. ago. My dad was in the USAF so I know exactly what you're talking about. I just hope AAFES has improved like 150% since I worked for them - especially when it comes to ordering things.
I have the 2003 Mazda6 with 18" wheels and 235/40/18 tires and the ride is amazing over 66000 miles. Feels as good as the day I bought it.
I will say what you are feeling is road irregularities which will be easily transmitted to you (feedback) because of the low profile / high perf tires.
awesome protection.
first time here sorry if this was asked recently !!!!!
KARLO
plug in their reader for free...at least in westcentral IL.
