Gasoline in my new Diesel truck
I just bought a 2003 Silverado 2500HD with Duramax diesel engine. The dealer put 12 gallons of gasoline in the tank before I drove it off the lot and I drove it about 50 miles home. It wouldn't start after shutting it down so they towed it back to the dealer and concluded that they had topped it off with gasoline.
The dealer is telling me that there's no problem. They drained the tank and are now saying I can have it back. I told them that I wouldn't accept it until I get some confirmation from unbiased sources that no damage was done.
Any guidance out there?
My $.02, I would pick another one off their lot.
1. Visually inspect and replace seals if there is any swelling.
2. Replace the fuel filter and water separator.
3. Flush (not drain) the entire fuel system.
4. Replace the injection pump.
5. Document in writing that you have done the above.
6. Warranty the work for an extended period of time.
But you know, you can't take a chance with problems down the line.
I would be knee-deep in lawyers if that was my truck, wondering how "Schrader Chevrolet" would have looked on the signs. because on a 0-miles brand new truck, I would be figuring on owning the dump by the time I was done.
I would say they owe you a complete, brand-new truck minimum, and perhaps a little something in punitive damages.
1. Fuel density compensator built into the diesel injection pump
2. Swirl combustion chamber effect caused by specially designed intake manifold
3. Built-in hemispherical depressions in tops of pistons to control the fuel burn
The engine has 22 to 1 compression ratio and is a true diesel engine. I ran this engine on gasoline only once for about a mile when I accidentally ran out of diesel due to defective fuel gauge, and could not find diesel at the nearest gas station. The engine ran smooth without any adverse effects. (Having a multifuel engine sure comes in handy at times! Pushing a 16,000 lb truck off the road is not an easy task.)
I also own an 83 Mercedes 300 SD with a 5 cylinder turbo diesel engine. I would be very concerned with engine damage if I ran gasoline in this engine. In fact, I was told by a mechanic that running gasoline in this engine will surely damage it.
After all, these trucks are expensive - I recently saw a Chevy 3500 LT Dually 4X4 crew cab with almost $ 50K sticker price. This is no longer pocket change for most of us. (Note: Supposedly Al Capone carried about $ 50K with him at all times for pocket change. This was in the 1920's, when one dollar was worth probably $ 20 today).
the dealer pinhead who put a 3/4-inch filler into a 1-1/4-inch (I have not measured these, this is my impression of the relative sizes on first discovery of the size of that hippo-maw of a fuel line) diesel pipeline was unqualified to be doing that work. the green "DIESEL FUEL ONLY!" sticker all tar-burners have on the filler door should also have been a tip-off... even if the pinhead couldn't read, he ought to be able to match the colors... even colorblind, green ain't red or orange.
I'm amazed the regular nozzle didn't fall out and spray the ground, the poor dupe must have had to stand there and hold it.
as a result, I would think a court would plainly see that the dealer is responsible for abuse, and should bear all costs whatsoever in making the situation right for the customer.
it would be a darn difficult job to make a liquid density probe that recognizes diesel #1 with antigel, for instance, and passes it while blocking gasoline, all within a fraction of a second, continuously in flowing liquid. it would not be a $15 part.
part of it is fear of lawsuits, I suspect -- somebody who thinks, "one part good, so two parts must be better," is going to blow the heads off his tar-burner and get mad instead of get smart.
In Alaska, the solution was to just leave your truck running all night while you slept. At 40 below, not a bad idea.
One favorite trick to start diesel truck engines in cold weather was to build a fire under the engine oil pan to heat the oil first. The winter of 1942 in Russia was so severe that oil froze in the oil sumps of many vehicles overnight.
