So it's really the other way around.
Frontal: Acceptable
Side: Poor
Rear: Marginal
The tests were w/o side bags. Ford has asked for a re-test with the side bags.
I was beginning to warm up to the Milan. Now, it will be a cold day in (you know) before I get a Milan.
http://www.iihs.org/ratings/summary.aspx?class=30
Crash test ratings for the Fusion and six other midsize sedans were released today by the Institute. Other cars for which results were released today were the Hyundai Sonata, Pontiac G6, Acura TSX, BMW 3-series, Infiniti G35, and Lexus IS.
"The Fusion is a disappointment because it's a brand new design," said Adrian Lund, president of the Institute, in an announcement. "Ford has done a good job with some other recent models, but the Fusion is at the back of the pack among midsize sedans for overall safety performance."
The detailed frontal tests were actually "good" except for right leg/foot. They should have designed the car to avoid this, however.
http://www.iihs.org/ratings/rating.aspx?id=631
The side test will improve when they re-do it with side air bags...but they should have designed it to be strong enough to get a "good" rating on the safety cage, imo.
http://www.iihs.org/ratings/rating.aspx?id=621
Thats not really a fair expectation, no car without side airbags in this size catagory received better than a P for side impact.
I think something wierd definately happened because the Mazda6 was rated G overall.
Mark
If side air bags are needed for safety, then they should have been standard.
Looks like they were ranked in order and the Fusion was the worst possible of those tested.
~alpha
~alpha
But VW seems to have figured out how to design their cars to get a "good" on that safety cage sub rating. Now that Volvo has lost their leadership on safety, maybe Ford should look into hiring someone from VW to help them figure that out .
In some ways Ford has gone backward on safety. The 2000-2006 Taurus (and even the 1996 model) did better in the frontal crash test than the Fusion.
http://tinyurl.com/qlxbe
Ford can do a 3.5L AWD version of the Fusion with up to 270 hp without forced induction. I'd expect that instead of a turbo 4 cylinder. However, it's not clear when (or if) that would happen.
AWD would be nice too for people who deal with lots of snow. They need to add stability control ASAP!
That's because the IIHS buys cars from dealers. Ford didn't supply the vehicle. Makes me wonder if dealers aren't stocking vehicles with side airbags.
IIHS FAQ's
My Fusion was ordered for stock and it had side airbags (and every other option) so I'm sure they're available on the higher end models but probably not on the lower trim levels.
I don't understand why they don't test the car with all the safety options if they're available. They shouldn't have to be standard and there's no reason to make the mfr pay for another test. Doing a safety test without all available safety equipment seems silly.
Offering a vehicle that will not score well on crash tests without optional equipment seems silly.
Perhaps IIHS buys vehicles without optional safety gear thinking that the manufacturer must be pretty confident that the vehicle will score well without the safety gear.
Also what if the IIHS did test the side airbag equipped model first and it passed with flying colors. That's worth a lot of marketing to the manufacturer but most folks would never see the tiny print in the ad stating the optional equipment required to achieve those results.
I'm a Ford shareholder and I'm disappointed that the vehicle expected to do well in the most competitive market segment didn't do well in a test that all makers prepare for.
http://www.iihs.org/ratings/default.aspx
What a foolish decision that was by Ford. Along with whatever they did that resulted in frontal rating of "acceptable".
The oddest thing about this is the last photo at:
Described as:
Postcrash photo indicating the added "ramp" intended to reduce loading on the right leg and foot in frontal offset crashes.
What is that about :confuse:
Since the IIHS buys from dealerships, it looks like they buy the worst case scenario and then allows the manafacturer to pay for a second test with the safety gear.
IIRC, Subaru earned a low grade with the latest Legacy and paid to retest after they made some changes.
The Subaru Legacy was redesigned for the 2005 model year. Beginning with 2006 models, changes were made to the side structure, front seats, and front seat-mounted torso airbags to improve occupant protection in side impact crashes.
http://www.iihs.org/ratings/rating.aspx?id=602
Legacy was only marginal in side test even with air bags before the changes were made:
http://www.iihs.org/ratings/rating.aspx?id=259
Hopefully, Ford will also make the changes necessary to improve their rating.
They'll fix it and retest it. In the meantime I guess I'll just have to avoid driving head on into a fixed object at an offset angle at 40 mph. :sick:
As for the test with the side and curtain air bags, it is very difficult to believe that they were too cheap to give the IIHS the price of a Fusion so that one with those could be tested. Again they must have know the result, and apparently though that the poor result would not be publicized.
While many other vehicles do poorly on the side crash test without the side and curtain air bags, the message people who do not follow cars as closely as most of here will receive is "the Fusion and Milan are unsafe." Ford pays the individuals and departments responsible for this PR disaster, and in the case of the poor rightleg result, engineering disaster, millions of dollars per year, and this is what they get?
Now, too late to undo the damage, they announce that the 2007 Fusion and Milan will have the side and curtain air bags standard.
I saw a similar video on one of the morning shows on TV today, so it's getting publicity.
This is a PR disaster for Ford. Very few newly designed cars do this poorly.
I guess you should wait for crash test results before buying and not assume every new vehicle will do well.
What I thought is odd is I can't imagine how this ramp was supposed to protect the leg/foot from injury. It just seems very strange...at least to me.
Ford wasn't cheap about not providing a Fusion with the airbags. The IIHS buys the initial test vehicle from a dealership. They buy them without the airbags if offered - they look for the worst case scenario.
The manufacturer then can supply a fully safety equipped vehicle for retesting if they are not happy with the initial test.
I think they can pay for the extra test with airbags upfront and get it done at the same time. The IIHS news release implies this, where it says:
Manufacturers who want a second test with side airbags have to reimburse the Institute for the cost of the vehicle. Initially, Ford didn't request a second test of the Fusion with optional side airbags.
"Usually when an automaker doesn't ask for the optional test, we presume it means the side airbags wouldn't help much to improve the car's rating," explains Lund. "But now Ford has requested a second test, so the Fusion with side airbags may earn a better rating than poor.
The way I read the IIHS statement that they when buy the initial car, it's out of their pocket. The manufacturer isn't sponsoring the test, it's the consortium of insurance companies that are affiliated with the "Insurance Institute for Highway Safety". They're independent of the auto maker.
The manufacturer can then ask for a retest on their dime if they are not satisfied with the results.
The ONLY thing Ford did wrong was to make the side airbags optional, not standard. It's the IIHS's decision as to what car to get, since THEY initially buy the car off the showroom floor. They'll buy the non-airbag-equipped model first, test it, then if Ford wants them to retest with airbags, Ford will cover the cost of the second test car.
Ford wasn't too cheap for anything. They maybe should've made side airbags standard, but doing that would take the car off some people's shopping list. Wrong or not, some don't like side airbags.
I'm just curious to see how it tests with them...
What are the other two safety features that will be added? Is ABS one of them?
I don't remember seeing this publicized by the news media as much as the Fusion's Poor result has been lately (If it was shown by any of the national media outlets at all.) I could be wrong, but it seems a little like another case of "Ford bashing" by the media.
The problem though is then dealers have to order the car with that option to really give people choice.
As the previous poster noted, if you want the side airbags and ABS in a Focus, you most likely have to order one.
Last year Ford really screwed up by haveing a commodities restriction on side airbags in the 500 because to many people WHERE ordering them.
As someone who sells Fords, customers are pretty much 50-50 for side airbags. But, the people that want the airbags insist on them. Its not like a moonroof or an up graded radio where you can get a customer to consider the car without that equipment.
The side impact test is more recently getting a lot more play and people are much more aware of desire for side airbags now than even 2 or 3 years ago.
ABS is totally unimportant to most Ford buyers that I encounter who are interested in the few Ford models that DO NOT have it standard.
The real player is the the dealer who orders the cars and if Ford has data suggesting that side airbags are desired by a certain percentage of people then Ford needs to get that DATA to the dealers and make side airbags available.
Mark
I assume this means some other things that are now standard will instead be optional?
To me the side impact test is really not likely to be a problem, I would have paid for side airbags anyway and I assume the car will do well in the test with them. But, what are they going to do about the frontal test result?
Saying that it "meets all Federal safety standards", which was a statement from Ford in one of the news articles that someone linked, is not going to cut it.
Thanks for the correction. I completely forgot about that and I even shopped the Focus while it still had stability control and now remember not being able to find a single copy on any local lot that was equipped with it.
The Fusion would still be the first Ford car to have stability control standard if they do it though. We just leased an '06 Explorer with AdvanceTrac with RSC standard (they started that last year actually) so it is starting to filter out at Ford. I still don't see a need for it in cars but it was a must in the truck.
The reason for only having a L option is the shifter was originally designed to be used with the CVT transmission (as was the one in the 500) as that was supposed to be the only automatic transmission option. They ditched the CVT but didn't change the shifter. They'll eventually change it but to be honest it works just fine as is. The only people complaining about it are the people who don't own one.
