Subaru Outback: Catastrophic Engine Failure at 70K Miles---Need Advice!
lreinstein
Member Posts: 18
I own a 1998 Subaru Outback Limited. 4 days ago, when trying to start it, the engine cranked but did not start. Mechanic thought was timing belt but this was not the case. He believes the engine needs replacement--there is no compression and camshafts turn easily by hand.
I called SOA and they told me to go through the dealership. The Service Manager at our Local Subaru Dealer (where I bought the car) says that since it is out of warranty, Subaru will do nothing about it. Interestingly, they replaced the "short block" on this 4 cylinder engine at 30K under warranty. THe car is meticulously cared for. How can a SUBARU engine suddenly fail after only 70K (40K really since short block)? Isnt there an implied warranty that an engine should last beyond this.
I am very upset at the way SUBARU is handling this. I loved how the car drived and wanted to buy another one (a 6 cylinder) next year. Given this attitude I never want to buy one again.
Any advice is appreciated.
I would ask to talk with the district warranty person and propose a split of parts and labor or something.
If someone hasn't torn down the engine I'd be very curious why it isn't the timing belts, given the symptoms of instant loss of compression in all cylinders simultaneously and free-spinning cams.
How can they deny any culpability if they don't even know the problem yet? What if the block cracked in half or the main bearing bolts came loose? (not saying this is what happened, just to show that this could be a metallurgical failure on a 40K block).
THe odd thing is that the failure happend in my driveway when trying to start the car. No symptoms prior!!!! We had it towed to my Mechanic (not the dealership), and he thought it was timing belt so removed belts etc for access. He tells me that he found no compression, and could "easily hand turn" the cams which he said is a really bad sign, and that I would probably need a new engine.
I told him not to do anything until I called SUBARU. I called the 800SUBARU3 number and they assigned it a case number, but said I must go through the Service Manager at the dealership. I went to see him and he told me that he "spoke to subaru and that they refused to provide assistance since it was out of warranty". He did not even want me to tow the car to his dealership to have them look at it.
I tried to offer him a chance to keep me happy. I actually told him (truly, though perhaps not wisely) that we were planning to trade this car in to get a newer top of the line 6VDC model. I asked if he could talk to the Sales Manager and offer some kind of compromise which would keep me in the SUBARU family, by giving me a reasonable trade-in based upon the book value (with a working engine of course). He declined this as well saying that it would not work out.
Why do the dealerships not realize that by having this attitude towards service they are spoiling future sales. Out of curiousity I went to the sales room and talked to a salesman (did not tell him my problem( and asked him how long I could expect the engine to last. He told me that 200K was not unreasonable and certainly 150K. So, shouldnt they be embarrased about this?
I will certainly not be able to buy another SUBARU after this.
Larry
Again, I advise you to contact the district warranty rep through your service manager.
The other idea is a used motor, then trade the car...
Patti
The only other thing I can think of is that the engine locked hydraulically in your driveway; that is, overnight the piston tops were covered with coolant from a bad head gasket leak, and in the morning you started the car, thereby causing the pistons to try and compress water (which can't be done), thereby bending all the valves. Voila, a no start, no compression, etc.
I'm not so sure you have an entirely bad engine for one thing, and I'm not so sure your mechanic is right on this one.
Statistically, there are going to be a certain small percentage of any manufactured product that is going to self-destruct "before its time" (average lifespan). No car escapes this, not Rolls or Ferrari or Lexus or Aston Martin. A certain number of them will blow up and you can count on it.
As for your unfortunate situation, a used engine sounds like a good solution since you don't even have a block to rebuild and a crate engine from the factory would be a shock to pay for. Also it doesn't make sense to put a brand new engine in a car that is otherwise about 1/2 worn out.
So I hope you'll at least consider that alternative. You might get by with $1,500-2,000 instead of $5,0000.
I strongly feel that people who don't purchase an ESC, if given the opportunity (and we all are), shouldn't get a free ride when something breaks outside of warranty - unless, of course, it's a repetitive issue that surfaced before the warranty expired.
They can't warranty things forever, you know...
Some of the higher grade wrecking yards will give a limited warranty on an engine, or, if not that, at least run them, test them, bag them and post compression and oil pressure readings for you.
It's either new engine, used engine or sell it has a cripple, that's about it for choices. Given that #1 and #3 are at either extreme, the used engine does seem (to me anyway) a sober choice, if not perfect in all respects. An engine-less 5 year old Subaru has little value while one with a used engine is probably worth $8,500 or so.
So you can
spend nothing and have a $1,000 car
spend $2000 and have a $8,500 car
spend $5000 and have an $8,750 car
If you no longer have faith in Sabaru engines, you could sell the car and try something else once the used engine is installed.
Although I've never suggested that an ESC be mandated in every case, it should always be offered...
I got a really bad feeling when I had two Dodge Caravan owners at my service desk a while back. Both vans had tranny failures, both were out of basic warranty, and were towed in, we had trannies is stock (of course). One guy bought a $1200 DCC warranty at time of purchase. He paid a $100 deductible. The other guy threw a friggin' fit and whined to DCC, and DCC covered his transmission, save for a $200 deductible.
I don't see that as fair at all.
And PLEASE! FAIR!, since when is the world fair?..... That is really funny coming from someone who works anywhere near a service desk at a auto dealer.
Mr. Shift......I will see if the service dept. can find a used engine, it sounds like a good option....thanks
It is that loss of power.... then the smoke and engine lights coming on that make me think some thing happened first that caused the rod damage. If the rod was oil starved then froze and poped throough the block? why wouldn't I have seen a oil light before the failure? would it be able to cause the sudden loss of power equivelent of the car being taken out of gear/ or would it just make the engine run VERY poorly then pop through the block?
Have you been over to the Owners Board and then to the Subaru topic? Maybe they have some other ideas for you that could work to your advantage?
anyway, i am given estimates of $3k for used engine and more to install it.
Larry
Until then, we can "what if" ourselves to death.
"If i pursued this in the court (which i will not) and if such was the case (faulty part) i have no doubt that i would win the expenses"
I seriously doubt you would prevail - and Subaru knows it. I work on automotive warranty cases all day, all week, all year. It would take you $4-5K in attorney's fees and a year and a half, given normal court docket time, to fight this.
They know this, that's why they don't have to care. It's certainly not right in my opinion, but that's just the way it is.
The Subaru dealership where my car is at did not want my Outback ether. They said if I was not going to fix it they would call around to junk yards to get me something for it. This seem funny since if they did the repairs and sold the car at below market price they would make three or four times what they say they make on a new car sale.
$ 5,800 short block
-1200 if new heads are not needed
7,100 long block
I was charged $150 just to get the estimate, but said cause could not be determined so far.
HEY! anybody want to buy a Outback w/bad engine, Must pick it up in Normal, IL ..... LOL!
After you've determined the cause, contact a decent private shop and have them find a used motor for you.
If Subaru engines were blowing up left and right, well, then for goodwill the company might do something. Mazda did this very thing, replacing engines out of warranty. But they were not legally compelled to do so, it was a good will gesture based on saving their corporate butt. Ditto the infamous Lexus sludge issue.
I agree with zeus on this one, if you went to court you'd lose.
Of course, no harm is throwing yourself on Subaru's mercy.
They have all the info they need already.
I guess a big part of this is about empathy some people think they will act or feel a certain way in a given situation, but you never know until you are facing it head on. I was a Police Officer for several years and when I pulled people over for a traffic violation I was very likely to give people warnings. I did this because I could put myself in their place, they were thinking Oh crap I did not see that light change, I did not see a stop sign, I will have to go to court, pay a fine, my insurance rates are going to go up, what my spouse say....ect. Alot of Officers I worked with could care less, if they pulled you over you were going to get a ticket PERIOD! Who would you rather be pulled over buy me or them? What I am trying to say is their is more to things than black and white(no pun intended). The Officers I worked with saw it as they committed the violation "end of story". Sound familiar?
The extended warranty is a mute point here. What we are talking about is how long you expect/are told, that some thing will last.
Bob
Of course an engine, with regular maintenance should last quite a while. With a written warranty, which is a contract, there are limitations, like it or not.
DaimlerChrysler offered me $1,000 - AFTER I filed suit against them.
Please don't think that I don't understand what you're saying - it just doesn't work that way.
Bob
I've been involved in over 3,000 lemon law and breach of warranty cases in a little over 2 years - I shake my head at what the manufacturer's do to get out of complying with the law.
If they complied, though, I wouldn't have a great paying job, and the 15 attorneys and 25 staff members would have to find other work.
He also observed a peculiarity: one side of the engine had gaskets and the other side had silicone seal. He found this strange as if, when they "replaced the short block" at 30K miles, they did not do a full job--only one cylinder??
His advice is to do a "valve job" which is considerable labor and parts (needs new timing belt, water pump, etc)
So thats the status.
Look, we feel empathy, and I'd be upset too, if it happened to me; but that's not the point. You're simply letting your emotions cloud your thinking. Wishing things were different won't solve your problem.
Bob
