When I start up car after work (1500 pm) there is a sound like crickets chirping.
Lasts only a couple of seconds and gone.
I cannot duplicate it after the first start.
This does not happen in the morning (0600am)
Any ideas or anyone ever have this noise?
If this is a manual transmission car, a worn pilot bushing makes this noise but please Lord, not that.
Worn busings? Possible.
But, this car has 11,500 miles and still under warranty. I'd parade it back to the dealer to have them fix it, regardless the reason.
Of course, the likelihood of that is just about nil, but after many years, I have learned never to entirely discount the "weird" when it comes to cars, even new-ish ones.
Words of wisdom....
My car is auto transmission.
When I started up car AC was not on.
Slipping belt maybe.
I took my car to dearler and I could not dupliate the same noise.
It only happens after my work (1500PM) not in the morning.
Once it happens it will not happen in a short time.
Is is possible that is temperature related (morning 50F, after work 85F)?
On my 2010 TL, XM,HDD,USB or CD are all about the same around a 8 volume setting like my wife's TSX, HOWEVER when I go to AM or FM I have to increase the volume setting to almost 14 or 15 to get it close to the others sources.. Anyone have a similar issue and if yes, did you get it fixed and how? :confuse: :confuse:
My question is how to value the car after it has been in an accident like this so that the reduced value of the car on the market can be assessed and presented to the attorneys. At the time , the car had 22,000 miles on it , and I am orig owner. It now has 45k miles on it. I could not afford to purchase a new car...and had about $35,5K invested in the car new.
Thanks for suggestions.
My calipers locked. Calipers are suppose to be replaced only once in the lifetime of the car.
New brakes and rotors installed as well. Total for calipers and brakes and rotors $1200 at local shop (not acura dealer fees)
Front left fog light is out
a few internal glow lights are out (ie cruise control light that is on the handlebar)
Also, I would contact my own insurance agent and see how they would value the car if they were the underwriter. That may help. I would also ask for a new or replacement car if your having problems with it.
Sorry about your accident. I certainly can relate. I hope your health fully recovers. I would press/fight hard (get an attorney consultation). I had to settle a claim with Travelers about six years ago. I still have back problems that will always be there.
Nice sale at Sears. After shopping around, prices are all over the board. $800, $900. Some even more. not usually yes.
But,Sears for whatever reason is much more reasonable on installation. So, had an earlier quote (with 1/2 price install) for $627, OTD including tax and alignment.
however, they decided to have a 1 night sale (5 pm fri to noon saturday) . 1/2 off all struts (but normal install). Ended up cheaper.
So, getting it done for a grand total of $516.76. That's 4 monro sensormatic struts, alignment and tax. Not a bad deal considering that going to another tire place and getting the exact same units would have been $300-$400 more.
My TL has code A12 appearing, which means oil change and tire rotation and minor stuff. I followed instructions to turn off the code: up/down button until Oil Life percentage appears and press and hold Reset button. But it did not work this time. It did not reset the A12 code. I was able to turn off A000000 oil change code before but not this A12 code. It just beep and the code returned. What did I do wrong? Thanks.
My Dad and I replaced the brake pads and rotors (no calipers) and parts were about $125 or so. Local independent brake/tire shop wanted ~$500, and the Acura dealer was something like $700 to $800. Their PARTS alone were about $400 if I were to buy them from Acura. Crazy.
Too bad, both were interesting while they lasted.
We are all here on the TL blog, but for most of us working americans, we just drive our car every day and having a blast. The car is so well engineered, not a lot of bad things to say or report. So for the majority of the 2009-2010 TL owners, we just take that role of the Maytag Repair Man, and live the boring life, except when we get behind the wheel and hit the accelerator!
I think my 2010 TL SH-AWD, 3 months old and 2800 miles now has nothing less then 4 coats of wax! If I had to make a buying decision all over again, nothing has changed in the last 3 months to make me not once again select the Acura.
MODERATOR /ADMINISTRATOR
Share your vehicle reviews
Never experienced anything like this before with a new car, anyone else?
1) somehow, they delivered it way short of oil (not filled up at the factory?). or
2) it actually used that much (which would be extremly rare, and unacceptable even though Honda would claim it fell within "specs")
But, with 2, it seems like you would have to notice it going someplace (smoking or leaking). So if not, 1 makes more sense.
Also, does this actually have a low warning light (like a BMW does) telling you to add? If so, that should come on by 1 quart. Or did you get the light of death (oil pressure light)?
For sure, I would have it to the dealer to get inspected, and to make sure this is documented, just in case.
assume they find no problem, and keep a close eye on it. If it doesn't end up sucking down oil ilke that again, assume it was just low to begin with. Or you overfilled by 2 quarts!
I am so sorry you have this issue and lets hope other chime in over the next 2 or 3 days to give us all an idea on oil usage and what can be considered normal. BTW, what state do you live in?? Let us ALL know what your dealer is telling you! I will do the same.
:sick:
I currently have 65,000 miles on the car.
Between oil changes it does not use any measurable oil. It remains at the top "full" hole for the whole 5,000 mile period.
Also I am thinking about buying a warranty from the acura dealer which they said would cost around $1500-1700...is it worth buying if they check the car & say it has no problems.
I did a search and found 40 2003 TLs with an average asking price of $8500.
Here's a LOW MILES 2003 for $9000 asking price.
I'm also skeptical that you can get any kind of legit extended warranty on a salvage car.
The oil that is in the engine is a special blend for new engines. You will need to drain it all and replace the filter, and start from a fresh start. Then check your oil every week to see if it is OK.
When I returned from las Vegas a few weeks back I was down 1/2 qt. I have since put on another 500 miles, and my oil usage appears to be Zero... Check back with us in a few months and let us know how things have been.. :shades:
I just now read your thread.
This is curious to me. We have an '05.
I see this in many of the forums and think it needs to be clarified. A fuel's octane rating represents its detonation threshold, not a promise of better performance or mileage. Higher-octane fuels create a slower burning flame. This deters pre-ignition, which manifests itself as engine "knock" or "pinging." Higher-compression engines, turbocharged or supercharged engines and higher-revving engines make good use of 91-octane premium. If the manufacturer does not recommend high octane, don't use it. The ABC news magazine show "20/20" put this advice to the test, and the results showed there is no benefit to be had in using high-octane (unless recommended) and, in some cases, fuel efficiency will be lost to incomplete combustion. You are just cheating yourself out of $$ in the long run by using lower grade octane!
In a 2000 TL, I did a full year using fuel with 10% ethanol followed by a full year with non-ethanol fuel. I kept track and averaged the gas mileage.....Guess what? It was EXACTLY the same MPG.
