Anyone with an Aviator that has driven it any distance in very cold air has experienced this problem
Hey, this is heyjewel. We emailed in the past about the HVAC problem (mine is in my LS.) Sorry I haven't been keeping up on the Aviator board. Just popped in today and saw you're proceesing with class action.
If it's not too late, I'll probably want to jump in. Please let me know how to go about.
Also, to those who've asked if this problem is in Explorer/Mountaineer? I'd say IF those vehicles have AUTO 2-zone HVAC then they probably also have the problem. If not, maybe not.
I sued Lexus in 1992, and lost, for the very same problems some of you seem to be experiencing.
Apparently some idiot in Japan came up with an HVAC design that relies EXCLUSIVELY on the ability of the A/C to dehumidify the incoming airflow and thereby prevent or even remove windshield fogging.
Even knowing that the A/C is shut down automatically at lower outside temperatures when the windshield is most likely to fog over due to cold outside airclow impinging on the exterior surface and thereby lowering the interior surface to dewpoint.
You can read a LOT more on the subject bt searching for wwest & defog here at Edmunds or denso & defog with google.
After 13 years of denying that there is a serious design flaw in the Denso design Lexus has recently added several C-best options that the dealer can set upon customer request.
1. Disable the A/C compressor completely, through multiple, ALL, restarts, if the driver turns it off manually.
2. Unlink the automatic operation of the A/C compressor from the defrost/defog/demist mode. In a Lexus the A/C will be automatically operated in defrost/defog/demist mode but with NO indication to the driver.
3. Absent having the dealer correct it using the 3rd c-best option the Lexus (NipponDenso, Denso US) climate control system will switch, automatically, from heating (airflow primarily from the footwell outlets with significant "leakage" to the defogger outlets) mode to cooling mode, dash & footwell initially when the temperature nears your "comfort" temperature setpoint and then to dash only once your setpoint is reached.
The important point is that if the system is allowed to switch to cooling mode, ABSOLUTELY no airflow is routed, "leaked" to the defogger outlets to keep the windshield warmed and hopefully above the dewpoint of the cabin atmosphere.
Additionally once the climate control "senses" that the cabin atmosphere has risen to near or at your temperature setpoint actuating the defrost/demist/defog mode will result in COOLING airflow, as much as 20F below the cabin temperature setpoint, being routed to the interior surface of the windshield.
For instance all Lexus & Toyota vehicle models use the Denso automatic climate control design but none share the same "appearance" and some not even the same "human" interface/.
In the State of Minnesota, in the case of Beckstrand v. Ford Motor Company and specifically on the HVAC issue, the jury unanimously found in favor of the plaintiff, Beckstrand. The jury instructed Ford Motor Company to buy back the vehicle and to pay the plaintiff an additional $50,000 (which is not allowed under the law in this particular case). The vehicle title will forever be marked as a Lemon Law buy back vehicle.
In open court testimony it was shown that Ford has A.) known about this issue, B.)has had many complaints, C.)acknowledged that there is no effective consumer solution to the problem, D.)is telling the consumer it is "within design spec" while internally stating they are working on a fix, E.)continued to sell Aviator vehicles to unsuspecting and uninformed buyers.
Representing the plaintiff in this matter was the Lemon Law counsel at Hauer, Fargione & Love.
1. Disconnect the A/C compressor clutch during the winter months when the climate is predominantly below 55F.
2. I added a switch such that just before I activate the defrost/defog/demist mode the IAT's (interior air temperature) sensor's voltage signal is raised enough that the system "thinks" it needs to HEAT the passenger cabin. This automatically results in HEATED airflow and HIGH blower now when I activate defrost/defog/demist.
You can accomplish the same thing by manually turning the cabin temperature setpoint up higher, a LOT higher, just before activating the defrost/defog/demist mode.
3. I added 4 small exhauster fans within the trunk to help EXHAUST the humid airflow resulting from operation of the defrost/defog/demist mode or the rear window defroster.
4. During the winter I manually close, and keep closed, the two dash outlet vents unless the side windows start fogging.
I have hired an engineer who is currently working on a fix for this problem in the Lexus RX300 series. Mine is a 2001 AWD RX300.
Our device is microprocessor based and will automatically detect that the airflow routing servomotor has moved to the defrost/defog/demist position, and therefore automatically increase the output signal of the IAT sensor.
So anytime I activate the windshield defrost/defog/demist mode the system will automatically provide lots of HOT airflow to the interior surface of the windshield.
A manual adjustment knob is provided so that once the windshield is cleared of condensation if the airflow to the windhsild must be maintained the temperature level of the airflow can be lowered to prevent discomfort.
there is a defrost and heat(feet) manual setting.
1. in my 02, i keep the HVAC exclusively on AUTO. When cold, i keep it set at 70F, and after the truck warms up, the fan goes very high for a bit, then slower and slower and slower. When at a low level for a while, I can suddenly feel VERY cool air coming from the defroster vents. I live in the northeast, so it is not too much of a problem, but on a couple of 10F days, the air was frigid
2. Since the Aviator and Explorer are basically the exact same vehicle, i ant imagine they would have a different system for the HVAC.
My thoughts are to install a switch in the speed sensor circuit going to the nav system so the system would think it is stopped, then after programing it, turn the switch back on. This could also apply to the XM radio.
Any help, ideas?
Also I need a source for a wiring manual, preferable on CD.
Thanks, Gene.
Is it really that much of a burden to set your destination while you're stopped? It's certainly safer.
What state are you in?
I am in Alabama
Many states have a fee shifting provision in their laws that require that the manufacturer pay for the attorney's fees if you are successful. Many attorneys will not charge you unless they are successful and, again, the manufacturer pays.
In my case, other than a great deal of personal time, I did not have any out of pocket expenses.
Regarding arbitration, the playing field is not level. In my arbitration, the manufacturer's representative was in fact a Ford dealer owner with a clear and unequivocal conflict of interest.
Check your laws carefully, because if you PERSONALLY present in arbitration, the manufacturers rep may have a vote on the outcome. If you do not present, some states do not allow the manufacturers rep to vote. This would have made the difference in my arbitration and my process would have ended much sooner.
I am not an suv type, like sporty sedans but wife wants an suv. i think aviator drives ok. I read all the issues about aviators and model being changed,etc. Dealer has some 2004's left and asks around 30k+tax for 2004 aviator ultimate loaded with dvd+navigation+etc..
would you take it after knowing the hvac issue + other problems? it is same price as honda pilot after all.
Ford has not responded. Did anyone else have this problem? Please any help would be greatly appreciated. Thank you
What has the dealer told you so far? Was the cable broken or damaged? Did it work right after the incident?
gas being applied.
Thanks for responding if you learn anything let me know, please
We feel for the extra $2500 we paid for the navigational system, it should work in all types of weather. We currently have to wait about 20 minutes before you're able to see the map clear enough to use.
apprently, the seats havent changed much in 13 years.
Thanx!
slasater - sounds like an electrical problem - bad ground or short or even a bad PCM. Don't blame Lincoln because the dealer can't troubleshoot it. And I don't think it's logical to think you'll avoid problems by buying only foreign cars. Even Honda and Toyota have problems.
thanks in advance..
Certainly not enough to offset the price difference. I've driven both, including a 4.6i X5 and I prefer the Aviator.
The X-5 offers little of the above in features, and will handle much differently. You'll feel much more of the road in the ride with some of the BMW weight in the steering. You get bluetooth which is very nice, not available in the Lincoln (Grrrr) but you also only get a single CD player instead of a 6 CD changer. You get seating for only 5, not 7, and not much, if any towing capacity. You're in full time all wheel drive in the Bimmer.
Neither of these vehicles have distinguished themselves in the "maintenance free" department, with the X-5 up to over 18 recalls I think by now, and the Aviator being famous for failing differentials and what not, but both of them seem to have ironed out their wrinkles since introduction. Be aware though, that the current Aviator is about done with its run, and will be replaced with a new model in 2007, so if you buy one, you'll own a classic really soon, if that matters to you.
Personally, even if they were the same price, I'd buy the Aviator - I like it much better - but that's just my opinion. YMMV. :shades:
