We share your pain. Really.
p.s. it's been 1268 days of pain-free ownership of my Mazda
The seatbelt warning beep can be fooled with various buckle, unbuckle tricks, but it is turned on again when the car is driven (picks up speed), and belts are unfastened. Somesort of double checking, by the car computer? I whish the car computer would warn about the parking brake, as well, while it's at it.
The brake light is useless, because the Mazda3 dashboard is ambient by definition. The brake warning light is not really a warning light, when it blends that well in, with the rest of the indicators. Same amber color for everything - the fancy indicator panel looks cool, but at the same time the warning function is lessened. Is there any after market gadget? to emit a beep for the parking brake when shift stick is out of neutral position? (1st,2nd,3rd gear etc)
I had the stalling problem - car would start then die - it always started again - never left me walking - replaced the fuel pump and my problem was solved.
Mazda has a new TSB out on the hard start condition it replaced the prior TSB - the new one is:
01-013/05 2004-2005 MAZDA3 - ENGINE HARD START
Some vehicles may experience an engine with hard starting (cranks but takes 10 seconds or longer to start). The condition is more likely after vehicle sits overnight or for an extended time. Rough idle may occur just after the engine is started.
This may be caused by fouled spark plugs if the vehicle is frequently driven in stop-and-go conditions, such as in heavy traffic.
IMO your ruff idle is being caused by fouled spark plugs.
mrblonde49 - I would agree with your statement except it is not just me that is having problems with the AC, brakes, suspension, tranny, engine stalling (plus more) - many other owners are also having problems. But before you say - but its a small % and all car companies bla bla bla - let me add that EVEN MAZDA ADMITS that the Mazda3 has all of these problems. They (Mazda) have issued a TSB on every one. How many problem cars (what %) do you think is required before Mazda issues a TSB?
autonomous - glad to hear about the GOOD LUCK you are having with Mazda. I am not saying every Mazda ever built is bad - I am saying that Mazda has not done enough to solve the problems on the cars that have defects.
I have been waiting more than 20 months to get my grinding brakes and harsh shifting tranny fixed. I think 20 months is too long (just like this post is too long!) How long do YOU think it should take a GOOD company to come up with a fix for these obvious defects?
I was recently contemplating purchasing a new M3 BUT decided to perform some necessary work on my 2001 Protege (timing belt, horn replacement)and keep it for one more Buffalo winter. After this winter, who knows? The Protege will be departing but for what, I don't know.
I've driven so many cars over the past few months that I can honestly say I am truly at a loss. Cars that were once virtually indestructible are becoming major headaches...boy do I wish they just facelifted the Protege instead of dumping it altogether.
Take care.
Just before giving my 16 year old her first driving lesson I wanted to see how fast the car would stop if I pulled up on the parking brake lever - seemed like a good thing to know at the time since it was about the only thing I could do to stop the car with her behind the wheel. I pulled hard on the lever - it did almost nothing to slow the car down - the last time I did this (with another car) it locked up the rear wheels. Is their something wrong with my parking brake - or is this normal on the Mazda3? It seems to hold the car fine when on a hill (with car in "N")
Well, maybe you should go to the direct source. But I suppose you're not a subscriber. Pull up the Mazda3 page on the CR wbsite, and it say RECOMMENDED.
For 2005, there is a FULL RED DOT for reliability.
Nuff on the subject
The brake light is useless, because the Mazda3 dashboard is ambient by definition. The brake warning light is not really a warning light, when it blends that well in, with the rest of the indicators. Same amber color for everything - the fancy indicator panel looks cool, but at the same time the warning function is lessened. Is there any after market gadget? to emit a beep for the parking brake when shift stick is out of neutral position? (1st,2nd,3rd gear etc) "
How do you drive with the e brake on and not know it - regardless of any light? Maybe you were busy tricking the seatbelt light? :confuse:
The anti-lock brake system does work if you hit the E-brake.
I sold my 1981 Pontiac Turbo TA about a year ago - it would lock the rear wheel if I slammed on the E-brake.
So far the Dealer replaced my fuel pump (no start)...then I took it back because the check engine light came on, they replaced the valve, and did the reflash for "shift shock", (it did make the car run better)...but as i was pulling out the car hesitated...I brought the tech outside , he said nothign was wrong...then I tried to start the car to leave...I would not start!!! The tech said i needed a starter? So they replaced that...I went back to pick it up, a few miles down the road shaking ans stalling..So now they replaced the Mass Airflow sensor. But they did not say anything about spark pulgs. So when i pick it up...we will see...I am afraid that It will break down again, I really feel that maybe there is something wrong with the car that the techs aren't fixing because there is no TSB for it!! Well I guess I will see tomorrow, and I will post what happens.
Print out a copy of the TSB and take it with you - in my experience it really helps to have it in black and white.
oldmazownr - My theory is the AC problem shows up more in the sedan - even though the HB and sedan have the same AC system - the AC is so marginal (weak) that the extra heat load - from the sun - coming through the rear glass on the sedan is enough to over load the system. IMO it is a combination of several "issues" - the main problem is that the evaperator is too small - this causes the compressor to cycle on and off - so you get cold - cool - warm - cold - cool - warm air about every 15-20 seconds - sure the compressor is designed to cycle on and off - but most cars don't start this quick cycle until the inside of the car is almost cooled off - I can get in my car after it has been in the sun on a 95 degree day - and the AC starts to cycle right away.
I have seen a few posts that claim the evaperator in the 2006 Mazda3 is larger (than the 2004 & 2005) I just dropped my Mazda3 off at the dealership - I plan to stop by the parts department when I pick the car up and ask them to look up the part number for a 2004 & 2006 evaperator - see if they are the same part number-
If you have taken a test drive and don't think the AC is good enough to satisfy you then DO NOT BUY THIS CAR - test drive a few more and see if you can find one with a good AC - because according to some people their cars AC works good. One thing I can say for sure - as in I am 100% positive that this is a FACT - if you get a Mazda3 with a weak AC system Mazda will not fix it - if it is blowing cool air they consider it within spec. This is true even if the inside of the car is sweaty hot. Trust me on this because I have had this problem for almost 2 years.
The brand has been taking a beating in my family...hard starting back in August, now squeaky brakes at Thanksgiving. I can't wait to hear from the old folks, "They sure don't build 'em like they used to!" when I squeak up in the morning.
At least Mazda's customer service has been pretty good (I'd say excellent, but I don't want to jinx myself).
I have owned several vehicles - that on the first few stops in the morning would have a small squeak or more often a slight grind - like SSSHHHH - this is normal - a very loud - long squeak is not.
If squeaky brakes are normal ask the service manager to show you a new Mazda3 with squeaky brakes - if it really is normal then they all should do it RIGHT?
If you're keeping the stock Goodyears on through the winter, than I really wouldn't worry.
I will mention this, I had a 2001 Volvo S40, it had the same "problem" with the rear brakes wearing first.
Lastly, I will get satisfaction over the AC though. My dealer's first car they sold me was wrecked before they sold it to me. No mention of that, just something I found during a wash and wax thenext day. Took it back... but we'll see about the other... :mad:
Also, no offense guys, but I always thought the E-brake shouldn't be used while driving. This past week I made my first mistake with my Maz3 when I forgot to put the e-brake handle down, but that was when I was trying to get the car out of a parking space and I was wondering why did it seem sluggish. Unless, you're planning on doing "Italian Job" car moves and don't mind taking the car to dealership to get the e-brake pads replaced afterwards, I personally think using the e-brake for moving situations isn't that smart. Then again, I'm using an auto for my car and really, what do I know? :P
Am I the only owner reading this discussion who has had a flawless Mazda3? My 2005 5-speed hatch has 12,500 trouble-free miles on the odometer. Am I odd? Or do I just treat my car properly?
Meade
Outings Inc
Outings Inc
It's called a Sidekick man, catch up with the technology, and I do carry a wireless laptop, it is 2005 you know. It helps that I am close to the dealer, and they take appointments until 6pm. I didn't need it back that day, they would keep it over night to check the brakes when cold, but if it only squeaked once, they would not repair. This IS the "problems and solutions" section, most posts here are because we are not happy with a new problem on our M3's. I am glad others have problem free M3's, but this area is for the rest of us WITH problems. Please respect that. We are usually a friendly bunch, I applaud your keen observation skills!
I don’t have the owners manual with me, but I recall reading something about avoid using the e-brake/parking brake in cold/frigid temps. This may be possibly due to in-boards literally freezing/seizing up in a locked position. I’m not saying this is acceptable or normal, but it may explain some
My compressor sounds like it kicks on automatically when air is being directed ONLY to the FLOOR outlets. I’ve never had a vehicle do that before. Is this correct or do I need to take it in for adjustments? Most cars will have the compressor kick on automatically in FLOOR/WINDSHIELD or WINDSHIELD ONLY modes.
Meade
Problems: only problem so far was a check engine light at 8k which turned out to be an evap issue with the gas tank due to the gas cap being loose.
Fix: I insist on filling my own tank regardless of what the half backwards law states in NJ
I've had them for two winters on my BMW 3-series (this would be the third, but I sold the car today).. they have about 12K miles on them, and my tire dealer says they look to be good for about 24K miles...
BMWs are notorious for poor winter traction, but with the Goodyears, it goes like a tank.. I would recommend them without reservation... My size is 225/45-VR17, which is the standard sport package size, and no problems whatsoever... I'm amazed at the traction, turning, and stopping power of them..
regards,
kyfdx
Host-Prices Paid Forums
The tires that CR tested are all Q-rated tires... Basically, geared to snow traction at the expense of all other attributes (sort of)....
When you get into the 17" sizes, most of the tires are H-rated and V-rated.. different tires for more performance oriented cars.... they don't have the snow traction of the mass-market Q-rated tires, but they have superior dry-road handling, along with pretty good snow traction, considering the sizes..
If I were getting Q-rated tires, I'd have no problem going with CR's recommendations..
My recommendation is from my personal experience, of course...
You could also check here:
Snow/Ice winter tires
regards,
kyfdx
