Chevy C/K Series Maintenance and Repair
I know the water pump comes in two styles a clockwise and counter clockwise rotation. I purchased the clockwise rotation, I believe this is wrong. Can anyone help me.
I can't believe that Chevy can't get me the correct part.
I cannot speak for Chevy pickups specifically, but I have a Chilton manual for my 1969 Ford Econoline and had a Haynes manual for my '96 Subaru. The Haynes manual was not only far smaller, but much more detailed in every aspect other than, perhaps, basic maintenance.
I was wondering if anyone would have a diagram or know where I could get information regarding the brackets to hold on all the pumps and things of that nature, I know how some of them go together but I'm confused about two or three.
I appreciate the help,
Henry Bibb
It is running a 350 with throttle body injection.
One day just quit. Brought it home and it started, lot of black smoke. Found 2 codes on the computer O2 sensor (found broke) and temp switch (below -27 for 30 seconds at start-up).
Changed the 02 sensor, gave a complete tune-up.(plugs, wires, cap, rotor, fuel filter, air filter) Has never had a tune-up since I have owned it, so it was due.
Tried to start, would not start. Thought may need some gas to prime the fuel filter (????) put some into the throttle body after a few tries it started.
Pulled it out of the barn and let it warm up.
Turned it off. Would not restart. After a few times it finally started. RUN GREAT!. Took it for a ride, got down the street and it died again. Restarted it would only run full throttle with no RPM's. After about 3 or 4 minutes of running that way I let it stall out. Got out of the truck and found the muffler RED hot (glowing).
Thought it to be a plugged cat. converter. Cut the cat. out. No change can not restart at all. It has good spark, fuel coming Thur the injectors and cranks fine.
The only code is 15 (temp below -27 degrees for more than 30 seconds)
I do not know how to reset that code.
Any help would be great.
Also now put it a ignition module and still nothing
Todd
As for starting, have you tried shutting off fuel flow (press pedal all the way to the floor) to see if it helps the rig start sooner? It might just be starved of air, but if you are getting all that unburnt fuel into your exhaust system, I would not recommend driving it very far anyway.
Any tips?
They would clog the pump/filter, and make the truck starve for fuel.
After sitting, some of the pieces would flow back into the tank, allowing it to run good for a while until they were sucked back up again.
Good Luck
I don't know if you've done anything recently and left a ground wire off, if it's something that has just corroded to the point of not working, or if it's the actual headlight switch itself that contains a ground path.
A look under the dash and headlight switch may reveal something, hopefully something loose!
It is basically the electronics of your distributor.
On the older electronic distributors, it would have been called the pickup module.
