Toyota Prius Basic Care & Maintenance
24567
    little_pogilittle_pogi Member Posts: 149
    There will be somebody who may have miscalculated that curb and scrapping the plastic cover on your passenger side wheels. It happened to me a lot of times and it makes me feel bad. I found out that Dupli-color auto spray, paint code DSGM 340 silver, exactly matched the silver color of the Prius wheels. Just smoothen the scratch with a file and spray over it. From 10 feet away, nobody will even notice that scratch.
    I also make it a point to keep those scratched wheel cover on the passenger side wheels whenever I do a tire rotation. This will always keep the driver side wheel covers scratch free.
    allendaallenda Member Posts: 1
    I'm looking for a good after market repair manual for my '04 Toyota Prius. Any suggestions?
    jebsterjebster Member Posts: 6
    Greetings! Just wondering if my '05 Prius uses a serpintine (sp?) belt? Couldn't see one, and no mention of it in the maintenance schedule.
    I know there is no alternator / starter motor... just wondering what else there might be (or not be) that is shared with a convensional car that might go bad. Water pump?
    Finally, when coasting and braking, the current MPG goes up to 99.9. Just wondering if that is figured into the average MPG report. For example, if I have 3 readings of 35 MPG, 45 and 99.9, will my average be 40 (thowing the 99.9 out) or will it be 59.9?
    tempusvntempusvn Member Posts: 119
    Sorry, no Belts
    Alternator - Gone
    Starter - Gone
    Water Pump - Electric
    AC - Electric
    Power Steering - Electric
    Brake Pump - Electric (With UltraCaps no less)
    MPG is calculated by fuel injection metering. The 5 minute bars are just displays and those numbers aren't used in the calculated total.
    joanmmdjoanmmd Member Posts: 2
    This is my first time to post on this forum. I live in the sunny Southwest and I am considering purchasing a Pruis. I went to look at one recently and it was like nothing I'd ever experienced before. I sat in the car thinking I was going to have to learn to drive all over again, with the gear shift set up, etc. BUT I'm very impressed with the mileage, and the fact that the Prius is so friendly to the environment. I do have some questions as I start to make my decision to buy or not to buy. I've read a lot of information here and find it very helpful. I have been told that the battery can cost $3,000 to replace. Is that true, and if so how often does it have to be replaced? That is a scary thought that I would have to add 3,000 to the cost of the car every time I replace the battery. I'm sure I'll be picking your brains in the upcoming months and I figure out what the best car for me is going to be. Thanks for your help. Joan
    gagricegagrice Member Posts: 31,450
    Welcome to the Forum,
    The main battery has a 10 year 150k mile warranty if you live in CA. That is the law on cars rated AT-PZEV. Any part that is required to keep that rating is covered. I don't think I would let that discourage me if I liked the car.
    Thanks for the information. It is amazing how everyone tries to act like an expert when you are considering a new car purchase. Glad I've found this forum to get my questions answered by people who actually own Priuses. Joan
    stevewastevewa Member Posts: 203
    Also, Toyota has yet to replace a battery pack for normal wear and tear in _any_ Prius, and they've been selling them in Japan since 1998.
    bobraxtonbobraxton Member Posts: 11
    "The main battery has a 10 year 150k mile warranty if you live in CA"
    Does the Platinum warranty (or any other) provide that same coverage in the state of VA where I live?
    That was forced onto the hybrid manufacturers by CARB. To get the AT-PZEV rating you have to warranty the components that can drop that rating. I would think that most of the drive train should be covered. Anything that does not operate properly can screw up the emissions.
    I don't believe you can get the AT-PZEV rating in any state that does not mandate low sulfur gasoline.
    tsvitsvi Member Posts: 3
    Eyeman2, did you find a solution to the beep problem?
    We have a new 05 and also find the reverse beep annoying...actually more than annoying. My wife has hearing aids and the beep causes ringing and discomfort. I have also noticed that someone standing behind the car cannot hear the beep, so it only discomforts the passengers and does not help protect pedestrians against the stealthly moving car in its electric drive mode. Strange...the rest of the car seems so well engineered.
    Tsvi
    05 maintenance manual recommends first oil change at 5k miles. Conventional wisdom, at least in the previous century, was that a new car should have its oil changed at about 500 miles to get rid of any fine metal filings from the break-in. Was that an urban legend or are new Toyotas more precise when made or the new filters better, etc? Anyone out there know? We have about 300 miles on our Prius now.
    Tsvi
    All of the above. Most modern engines can go at least the standard maintenance interval from the factory. Special "Break-in" oils, etc. are mostly a waste of money today.
    shebytheseashebythesea Member Posts: 1
    We're about to buy a 2005 Prius. We live here in S. Florida for six months of the year. When leaving our present car,a 10-year old Camry, we have someone start and run it for 20 min. every two weeks. Any advice on proper maintenance in this situation for a Prius?
    If you can get 30 minutes every two weeks or so you'd be fine. Or get a battery tender hooked up to the 12v battery, and just have it run for 10-15 minutes every month or so for the high-voltage battery.
    flyslow2flyslow2 Member Posts: 1
    I have searched the owners manuals of my 05 Prius and can find nothing about cleaning the touch screen. Anyone know the approved method?
    Clean water on a soft cloth should do it. Better to clean with the ignition off so you don't accidentally press any "buttons".
    Don't spray anything onto the screen as there's a chance it could drip down into the innards.
    I might add that anything but 100% cotton cloth may be abrasive. I only use a cotton washcloth or towel on my laptops with just a bit of dampness. Unless the screen is glass it will scratch with cleaning.
    Jofam1,
    Did you get your answer to the worth of the prepaid maintenance contract? We got talked into one, but when it was received, I noticed it really only covers oil changes, fluids & inspection of hoses. When sold to us, I was told that Toyota does all kinds of electronic tests on the condition of the car that cannot be done elsewhere.
    I also saw in the fine print that one can get out of the contract within 60 days...I have a few days left to that point.
    Tsvi
    jjprinsjjprins Member Posts: 2
    I've always changed the oil of my previous cars myself, and would like to do the same with my new '05 Prius. Is the procedure the same as for any other car, or do other steps/ precautions need to be taken? Any input would be greatly appreciated!
    JJ
    gdfgdf Member Posts: 2
    To turn of the the "beep" when putting the car in reverse, follow the instructions inserted below. Enjoy the silence :).
    - Greg
    1. Power on the car to IG-ON or READY. IG-ON will do for this purpose.
    2. Using the Trip/ODO button, set the Trip/ODO display to ODO (not Trip A or Trip B)
    3. Power off the car.
    4. Now power the car to READY (brake on). This is required so that step 6 works correctly.
    5. Within 6 seconds of powering on, press and hold the Trip/ODO button for 10 seconds or more.
    6. WHILE STILL HOLDING ODO *after* the 10 seconds, shift the "gear" selector from P to R, then back to P. Now release the Trip/ODO button.
    7. If the last step was successful, "b on" or "b off" should be displayed in the location where the Trip Odometer or Odometer is normally displayed. "b on" is beep on, and "b off" is beep off.
    8. Press Trip/ODO to toggle the mode.
    9. Now power the car off to exit the toggle mode.
    10. Power the car on to READY and confirm the reverse beep status by shifting to R. The beep should not be audible if "b off" was selected, and should be audible if "b on" was selected
    karlheinzkarlheinz Member Posts: 1
    I can confirm all that tempusvn said. No belts is true
    some misnomers. -- while a small 40A "alternator" isn't in the Prius - a huge generator is. That electricity must come from somewhere.
    While a conventional tiny starter that you start with a key is gone, the main electric motor will turn over the motor to start it - (by the way, the starting procedure is monitored by the computer which controls aspects such as timing, opening of valves, and metering of fuel to ensure a "jerk" free low impulse start of the motor so don't even think of trying to "push" start this baby. If you run out of electrical juice things get tough. yes there are emergency procedures... recommended only for emergencies)
    Most importantly, regarding MPG --- it is calculated from the fuel used (determined from fuel injection metering and mileage.) What is calculated for the min by min MPG is real...as real as can be... except when the MPG goes over 99 MPG or, as happens, goes to infinity (this is when the battery is being charged up by coasting or breaking and no fuel is being consumed yet the car moves.) it only shows 99.9 mpg. The total cumulative fuel usage is still being accumulated in the computer as is the mileage. This means that the 5 min bars will show TRUE mpg "for that 5 min time period" . The total is a compilaiton of all the mileage divided by the fuel use, which is mathematically the same as adding up those mpg bars... HERE IS THE RUB.
    You can NOT take an arithmetic average (what most people think of as average) of the bars to get the true mpg. You have to take a harmonic mean. I won't explain the math. The reason is that what you are really measuring is the fuel used to drive a distance. This is gallons per mile. You can average these figures to get a total fuel usage because what is being used is fuel. In fact they use that method in europe.
    Bottom line if I want to get 50 mpg for 10 min, and I did 25mpg the first 5 min (one half of the desired millage) I would have to get double the mileage (100mpg) for the next 5 min to get an average of 50 mpg - not 75mpg.
    Call this small lesson "How MPG is calculated"
    plusafplusaf Member Posts: 6
    please note that the best way to jump-start ANY car with a dead battery is to hook the two systems together and let the live one charge the dead one until the dead one's battery can start the car by itself.
    the 12 battery in the prius is a very low capacity unit, and i'd wager it could be easily damaged by putting a really dead battery across it and then trying to start the disabled car. electronically, a dead battery is the electrical equivalent of a short circuit until it charges up. and the starter looks like a heavy load, too, unless the disabled car starts VERY quickly....
    more details or stories? i used this technique at about 15 degrees below in troy new york, decades ago, and got a friend's car started after he'd unsuccessfully tried a jumpstart from three cars simultaneously !!!!!!! picture that!
    it took us half an hour of chatting in my warm car as my car charged his' battery, and his lit off without any spray ether or whatever. he gave me a buck for the gas consumed, which was a drastic overpayment at the time....
    :P
    yeah, they tried that in the D.C. area on one of the connectors near an airport.
    it cleared out the hov lane all right... it emptied it. onto the service roads, which were then REALLY blocked up...
    if you think arranging a carpool schedule for two people is fun, it goes up exponentially with three!
    if the hov lane is full, as in LA, and all of the lanes are going slow, can you ask yourself why there is an hov lane?
    next, if the hov lane is lightly loaded, and the other neighboring lanes are slow and packed, can you ask why there is an hov lane?
    keep working on that one.......
    aguy1aguy1 Member Posts: 2
    I have a 2002 with 70,000 miles - the car is going well, and I have had no problems. I follow the service instructions.
    I did talk to my dealer about a trade for another bybrid however he was only willing to offer me $8000.00 on my 2002 because of the high mileage?
    Any feed back about high miles and trade in value would be appreciated.
    Angela
    priusfan05priusfan05 Member Posts: 2
    Hi! I have a "Super White" 2005 Prius, which I love, and I want to keep looking good. What can I do to clean the outside of my Prius when I don't have time to do a real, full-on washing (with bucket, water, soap, etc.)? I've seen "car wash wipes" from ArmorAll, and I've heard that there is something out there that you spray on your car & just wipe off (but I don't have any "name" for that product). Has anyone out there used the ArmorAll product, or used any kind of spray & wipe product? And if so, what was your experience (and where did you find the stuff?)
    Thank you! :shades:
    stevedebistevedebi Member Posts: 4,098
    I suspect that if the Prius 12 volt battery goes out completely, you may have to tow it to a dealer to reset everything. Can anyone who has had this happen confirm / deny this?
    Obviously, if the traction battery goes out, it becomes a 3000 lb paperweight until it is towed to the dealer. The HSD has some advantages over the Honda IMA, but this is the drawback to HSD.
    ragueroraguero Member Posts: 60
    OK, so I took my '04 in for it's 30k oil change and asked what
    maintenance was suggested at this point. She printed out the list and
    it came to $379. Of course 2/3 of it were "inspections". The only
    work on it was the oil change, the engine air filter, the a/c air
    filter (both of which I'll do myself) and engine coolant replacement
    and inverter fluid replacement. Does anyone know what the "inverter"
    fluid replacement is? I asked them what it would cost just to flush
    the engine and inverter fluids. The inverter would be $250 and the
    engine $200. Sheesh. I'm having them change the oil. I'll think
    about the other two. Any ideas or opinions? - Rick
    Read your manual, Rick. The only replacements required at 30k are the oil and both air filters. Nothing other than these three things needs replacement until you hit 100k. Most dealerships sure are shamless...
    JP
    wayneswhirldwayneswhirld Member Posts: 7
    I have a 2005 Prius with 1,200 mi. I'm very pleased with it. Not surprisingly, the dealer's maintenance plan calls for a lot of added items to perform ranging from adding oil additives and at 15,000 miles replacing the air filter, a "transmission service" and a "recommended" engine flush service and throttle body service...wow! Plus they recommend oil/oil filter changes at 3,750 mi.
    Meanwhile the Prius guide suggests oil/oil filter changes every 5,000 mi. and at 15,000 an inspection of certain items, same thing at 30,000 except to replace the air filter...that's it.
    I plan to adhere to the Prius' plan except I think I should change the oil at 4,000.
    My main concern, however, is that while the dealer's plan suggests replacing the timing belt at 60,000, I can't find any suggested replacement of the timing belt in the Prius guide straight through to 120,000 mi. Did I miss something here?
    toyotakentoyotaken Member Posts: 897
    Follow the maintanence requirements in your owner's guide. Any/all of the "suggested" maintanence from the dealer you're going to is just that.... suggested. Feel free to use a shorter interval for oil changes if it makes you feel more confortable, but in all honesty, it isn't necessary. Same with engine/cabin air filters. Inspect them, if they're dirty, replace them. If not, wait until the next service interval and do the same thing. Engine air filter is more significant as it can make a VERY significant difference in engine efficiency (10% or more).
    Hope this helps.
    Toyota Ken
    Thanks Ken, that helps. The only remaining concern is what about the timing belt? I assume a Prius has one. Is it possible it doesn't need replacing up to 120,000? Would it ever need replacing (if I ask the dealer of course they'll recommend it)?
    Quite honestly, I'm not sure if it's a belt or a chain. I believe it's a chain, however. I can check on this when I get into the store tomorrow and post back with what I find out.
    Toyota Ken
    msheffieldmsheffield Member Posts: 1
    Can anyone recommend something to clean and protect the inside of my Prius, I tried Armorall and it left a streaky residue and didnt seem to do much past that.
    futureowner1futureowner1 Member Posts: 1
    After owning a gas guzzling SUV, I am obviously considering a Prius. However, I am wondering about the average maintanence; does it cost more or is it more frequent than a non hybrid car? Also, I live in a very snowy state; does anyone know how the Prius fares in winter weather?
    fndlyfmrflyrfndlyfmrflyr Member Posts: 668
    Only have the Prius for four weeks (1500 miles) and live in SoCal so I can't speak about snow. According to the owner's manual it appears that only oil and filter (oil, engine air, and cabin air) changes are required for the first 100K miles or so. There are the usual inspections and Toyota recommends tire rotations every 5000 miles.
    The tires are basic rim protectors and don't hold the road well, but they ride okay and are fine for non spirited driving. I have my doubts they would do well in the snow. The car comes with traction control so even with these tires you should be able to get around during the winter.
    I still have my SUV (MDX) and find it nicer for long drives. Nothng wrong with the Prius for long drives, just not as nice as the bigger (more room inside) car. I'm find that the Prius A/C has to work hard to keep me cool on hot days (95 plus), while my other cars don't. The Prius needs recirculated air and more fan speed, but gets the job done - with more wind inside and more fan noise.
    I've seen other posts that changing tires on a Prius makes a significant positive change in ride, quiet, and handling while not hurting mpg much.
    carol7565carol7565 Member Posts: 1
    I also own a g.g. SUV! I just started looking at the Toyota Prius today. I was wondering the same thing.
    How does the maintenance differ for this hybrid vs. non-hybrid auto?
    How does it handle in snow?
    How long does the battery last? And what's the typical price to replace it?
    carol7565
    Most of these have been answered earlier in the forum but here some short answers for you. Maintanence is almost the same, but save alot on some things. Oil changes are every 5k along with tire rotations. However, because the brake pads/rotors are not used until almost stopped(regenerative braking) most of these vehicles go over 100k before needing brake service. No transmission = no transmission service.
    For driving in the snow, it is front wheel drive, so works well, you may want to invest in snow tires if you're in a snowy region of the country.
    Batteries have lasted well over 200k for several owners and there have been no issues with many owners over 100k on them. They're made up of smaller "blocks" of batteries, so you don't have to replace the whole battery pack if there is an issue, just one of the MANY smaller packs, and regardless, they're covered for 8yrs/100,000 miles.
    Hope this helps.
    Ken
    talleyidtalleyid Member Posts: 34
    It's been awhile since I've been on the site but I recently moved from the St. Louis area and had my Prius in several winters there. You'll also find info if you search the sites by keyword because I know this has been discussed.
    In short, winter performance was no different to me than with any other car I've drive in a snowy climate. My Prius did seem to provide warm air sooner which I attribute to the faster warming of the engine due to the stored, warm, coolant. I did have a slight decrease in mileage due to cold and winter fuel mixes but it was still in the low to mid 40's on average. In better weather I was averaging closer to 50 MPG. John1701a has dealt with this question extensively here and on his site, john1701a.com if you need more detail.
    sweetie2sweetie2 Member Posts: 2
    How do I get this warning light to turn off? I had my oil changed at a local service center (not at the Toyota dealership)
    mrvadeboncoeurmrvadeboncoeur Member Posts: 146
    Page 122-123 of the US 2004 Prius Owner's Manual (Section 2-5 "Operation
    of Instruments and Controls: Gauges, Meters and Service Reminder
    Indicators", item (j) in the "Service reminder indicators and warning
    buzzers" section.
    You can read the Passport to Performance (scheduled maintenance guide) for yourself at:
    http://smg.toyotapartsandservice.com/index.php?vehicle=Prius
    Call around to service shops in your area to find out what the going rate is for the listed services. (Most services is just a oil/filter change and tire rotation. US 2001-2003 Prius is 6 months or 7500 miles, US 2004-? Prius is 6 months or 5000 miles, in other countries the period is usually longer.)
    The Prius performs like any other FWD car of its weight class. I would suggest getting a set of snow tires, though.
    looking4priuslooking4prius Member Posts: 53
    Am considering buying an '06 Prius. Have been fortunate to be able to test drive one ('05). A small engine, but that was expected. Question is, has anybody experienced any problems with the CVT? :shades:
    "Question is, has anybody experienced any problems with the CVT?"
    The Prius doesn't use a CVT, it uses a Hybrid Synergy Drive. I distinguish them because the CVT technology generally has a belt (usually made of metal) that enables continuous gearing. The HSD uses planetary gears, a more reliable design.
    I haven't seen any reports of failures on the HSD.
    Sounds good to me. I threw a timing belt on my Honda Accord on the freeway...nasty stuff. I couldn't imagine why Honda would want to use a belt as part of their CVT..which is one reason I am leaning towards getting a Prius.
    Ok, I have another question. My Honda Accord has a black rubberized strip to protect the door from being dinged by other drivers opening their doors. In looking around using Google, I see that some people are recommending another Toyota door strip, from a Camry I think, to do the same thing for the Prius.
    Good idea? Bad Idea? Anybody have one?
    The strip on my Accord has saved my door several times...I don't want the Prius door to be dinged likewise. I will be buying a Prius, within a month or so so that the vehicle is delivered next year. Will be my first new car...
    marge3marge3 Member Posts: 1
    I just purchased a 2005 Prius. I live in upstate NY -- snow country. Any advice about which brand of snow tires will provide the best traction for a Prius in snow and ice? (So far, I am considering 2 kinds-- Michelin X-Ice or Bridgestone Blizzak).
    "I couldn't imagine why Honda would want to use a belt as part of their CVT..which is one reason I am leaning towards getting a Prius."
    The CVT belts are pretty reliable, unlike the CVT of a decade ago. They are metal now.
    BTW, timing belts are still present in the engines - I believe the Prius also has a timing belt for the ICE.
    cionnicionni Member Posts: 1
    what response did you get to your question? I just bought a Prius in the mountins of Colorado and am trying to decide about snow tires. I've used Blizzax for years on my Outbacks with great success. What are you using? Thank you, dcionni
    mimicowmimicow Member Posts: 1
    Hi, Can you please let me know if you find out how to turn off the warning light 'maint reqd'? If so, can you please share the knowledge with me?
