4-Wheel Drive vs. 2-Wheel Drive Trucks
I am considering buying a pickup truck for the
first time. I understand you can put chains on
wheels for snowy mountainous terrain in lieu of
having four wheel drive, but just how good a
substitute is this? If it is as good, how much of
a pain is it to equip your truck every winter.
Also, are studded tires as good as chain laden
tires?
I really don't want to take on the expense
of adding 4-wheel drive to the list of features
but maybe there is no suitable alternative.
tires?
Chains / Studs can help, but check your local laws, they are not legal on all roads in all states, some ban them, some only allow them on unmade roads - the rules differ considerably.
It really comes down to how much you are planning to use the truck off road, the inconvenience of putting chains or studs on your tires, or even buying a separate sets of winter tires / wheels can soon add up.
Even here in Denver, I only need it maybe 3-4 times per year. But when you do need it, you need it right NOW.
Off-roading is the least consideration, but the transfer case is protected in any event with a skid plate on Z71's. What's not protected is the fuel tank...
Plenty of valid reasons for 4wd systems. If you live in rural areas where roads are dirt, they turn to mud and muck when it rains. Far more slippery than any snow or ice I have encountered.
Chains work well, but vastly limit your speed and comfort, and are a big hassle to put on and take off.
You don't need a Hummer or Wrangler to get up my driveway, but at times, you do need 4wd.
BTW, rsk where abouts in Ontario?
Randy
Been driving your truck a year and a half and are in the mountains when a freak early season storm gets you stuck. You're not going to say, "sure glad I got 2wd since I haven't needed 4wd for 18 months". That's an extreme example, but you rarely ever use that ABS braking system either. Might as well not get it. In fact, might as well pull out those seat belts, crumple zones, and air bags, they just cost a lot and weight your truck down.
Fact of the matter, pickups have poor balance, so even if you never leave pavement, a wet launch ramp will paralyze a 2wd (seen it happen).
Personal experience. We had a pickup with a camper on it out on a nice open hillside on a hunting trip. We weren't planning on needing 4wd, but we got an early season snow overnight. The snow melted in the morning and turned the hillside muddy. Went to leave and the 4wd did not engage. Found our very fast how worthless the truck was in 2wd. Now before you say that 4wd can fail, that's the first time I've had it happen, never heard of it happening to anyone else, and they don't make those kind of hubs anymore ('89 Dodge).
Now to me, these situations, however rare, more than make the relatively small investment in 4wd a no-brainer. Even if you never leave the street though, it is worth it. Someone was talking about how his new GM with Autotrack probably saved him a collision on a rainy day when someone was running a 4-way stop as he was going through it, he hit the gas, and since the pickup has such poor balance, he was sure the Autotrack 4wd kicked in and saved his you know what. Get what ever you want, but don't be deluded into thinking the 2wd is just as good as 4wd, it just costs less.
If you do decide to get 4WD one thing to make you feel better(at least in my area)is that a 4X4 holds its value much,much better.My truck is 4X4 with an open rear end,I have never needed anything more than a quick shift to 4 Hi to get me home.I will say though that my 17,000$ truck does not see heavy offroad duty,just some muddy backroads,and an occassional Buffalo,NY area blizzard.
A 2WD drive truck...is well.....a Station wagon with No roof!...(actually I think a wagon would be even better than a 2WD truck?)...(more weight)
Why get a 2WD truck?...get a car man.
For a 2WD...get a Lim.slip rear at least....a 2WD with open rear..is well....a useless truck.
Michigan snow season has several people kidding themselves they can do just as fine with a 2WD as someone can with a 4WD.....Bull!
I can drive very well in 2WD....but not as superior and SAFE and in control as 4WD. It's the other idiots out there who can't control themselves that we need to beware of.....and someday I may need to punch it in the snow to avoid them.....what will happen to YOU in your 2WD when Joe A-Hole is coming head on into your truck and Family and you are forced to punch it in the snow????
I think you know the answer...
I use it for much more than snow....but even if I didn't....My life and family/friends are worth much more than a few thousand dollars for the best option a truck can have.....
- Tim
Whoduthunkit?
Actually that is a good point.....and that is also the Joe I am talking about we have to look out for!
with 2 trannys,diffs,and drive shafts going...it does slow you down to a certain degree faster when you let off the gas....but not enough for what some morons need.
A truck with no 4WD is like...
- Ordering a Jim Beam and Pepsi..
...Eating a Resee's with NO Peanut butter inside!
...Going to the pet shop and NOT tapping the aquarium..
- or think of it like the stooges and having Shemp(2WD) or Curly(4wd)
.....Yeah Moe and Larry made due most of the time with Shemp......but it just wasn't Curly!!
Understand?
..Now spread out..
Nyuk Nyuk
- Tim
So...what does a clown in Florida, who doesn't boat, use as an reason? LOL! (oh sure--you all go into the swamp....uh huh...sure.)
Yes, I own 4x4s but it's really do to the construction sites they're on as opposed to the MIGHTY BLIZZARDS every man seems to face while in a 4x4. If your not a manly man, generally a limited slip on a 2wd gets you by 365 days a year.
The cardinal sin when driving on snow and ice is breaking traction at hwy speeds. If you do it with 2wd, the back end is going to fish tail and the chances of recovery at hwy speeds are not good. In 4wd, the front tires are pulling the weight. If you break traction in 4wd, all four tires break traction and the rear end isn't likely to fishtail. If you have ever had the opportunity to drive a 4wd on icy roads, it's a night and day difference from being in 2wd.
Still, there are just as many 4wd vehicles in the ditches up here. Overconfidence is the biggest culprit. Alot of them end up there because of lane changes. The 4wd will help prevent fishtailing when accelerating, but when you are turning the front tires to change lanes, especially if there is a slight snow burm between lanes, you risk going sideways if you try to make too drastic of a lane change. The other problem is following to close. You may be confident with your 4wd, but the guy in front of you may not be. People do unpredictable, and often stupid, things in the winter. If you're behind one of those people, your evasive options are limited without risking losing control if you are followig too close. I'm a pretty agressive driver, even in the winter, but I make very gradual lane changes and try to maintain a reasonable distance.
Get 4WD if you get a truck....Period.
- Tim
To you guys who actually do go off road and slog through the mud and the muck, you don't have to remind me that you have an actual need for a 4x4. The rest of you who commute with a 4x4, too bad you don't know how to drive.
- Tim
BUT MOST OF ALL, ENJOY THE TRUCK YOU'VE GOT!
..(sounds like a song)
- Tim
...Now that would have to be love to buy one of those!
LOL
(Welcome back)
- Tim
I don't think anyone is saying that you can't do it or that those kinds of driving habits will be within the limits of the law. Then again, road courtesy has nothing to do with the law anymore than table manners do. Just my biased $.02 worth.....
EVERYONE was that way with their first 4WD.....weather you admit it or not...
But I would still take a 4WD...over a 2WD...period..
Actually I would never buy a 2WD truck....period.
- Tim
- Tim
The extra they cost is also a good investment for re-sale....as you get just about that much extra!
- Tim
My feeling is, if you need it, and you're not asking for it, you're asking for it!
- Tim
What am I to do?...sit around and wait for it all to be delivered?...think not..
I even went with a 2500 as I do enough heavy hauling to warrant that. (Also wanted to try the new 6.0)
Yes...most never leave the road....but off roading is not the only issue for a 4WD. I consider it even a safety option when you really think about it?
I know several people that never use their truck...believe me. One has a 2500 Ram and says he would never put more than 1000 pounds in it cuz he does not want to "hurt" it?.....huh!??
I saw a couple at the yard getting dirt...rolled back the cover to expose a perfect bed liner with not a nick on it....layed down a tarp....and stopped the bucket truck at about 1/5- 1/4 of a yard (but payed for a yard) of dirt....cuz that was all the weight they wanted to take at once with a 1500 4WD.
Give me a break people...
I use mine...so that's all I care..
Good Luck
- Tim
A 2wd truck has a very low percentage of its weight over the driving wheels, unlike an SUV.
Just go back and review the postings on these and similar topics any November / December - you will see all kinds of amateur hour attempts to provide more traction to the rear wheels - usually involving putting sand bags over the rear axle - but hey, they don't need 4wd!!
And lets be honest, we all know what happens in 2wd on icy ashphalt if we want to turn left or right from a stop sign - you drive slowly so that the back end doesn't slide TOO fast.
Anyway, dont quote me on this but I think if you get your GMC in 4WD I think theres a mode where you can have it on and it will act as a 2WD until it gets slippery.
GMC's tend to be more expensive than Chevy's and should have more goodies standard. I think the C3 has 325 HP from its 6.0 when the normal 6.0 has 300.
However, if the weather is that icy you don't drive - you will never, ever see me on the roads during an ice storm / freezing rain - it's just too damn stupid.
If there are patches of black ice, frozen puddles, whatever, then you stand a much better chance of getting through it with 4wd than 2wd.
If you slide whilst driving in a straight line it's no big deal, providing you are driving at sensible speeds and know what to do - and in such a situation it doesn't matter how many wheels are driving the vehicle. However, if you are maneuvering - i.e. all four wheels are not pointing in the same direction then the greater the ability to prevent traction loss / recover from traction loss, the better - to take the simple example of patchy ice, there is twice the chance that you will have a driving wheel on pavement with 4wd. As I mentioned at the start if there is so much ice that it forms a complete coverage, then I am not on the road.
I am slightly confused by the direction this discussion is taking. theliz, you seem to be disputing whether 4wd is better than 2wd in marginal conditions - it flat out is, and at the risk of sounding rude it should be obvious that it is.
Now whether 4wd is necessary for individuals, well that is down to individual applications and preferences - however, my view on this is that you are more likely to slide at a bad moment (when maneuvering) with 2wd than 4wd - if you are out of control there is a distinct possibility that you will end up off the road or in the wrong lane. I will pay the relatively small price for the security of 4wd, and use it whenever there is any doubt in my mind about the road surfaces.
The problems start when people think that 4wd makes you invulnerable - I see more 4wd vehicles in the ditch than 2wd because drivers of 2wd vehicles know that they have to be cautious - 4wd owners think that winter doesn't exist for them.
Even with extra weight over the axle...it still sux!
"but I can go any place with a 2WD that you can with a 4WD"
....Keep telling yourself that....
- Tim
