Oil Change
Coolant Drain/fill
Brake Flush
Fuel Filter (if it's not in the tank)
air filter
Trans/Diffy/Rear Diffy Fluid change
Various checks
We charge about $65 more for Synthetic fluids
We charge about $90 more for plugs
-mike
I plan to buy the tune-up kit from subaruparts.com (sp-plugs, air-oil-fuel filters) and PCV valve, and go to someone nearby, that has worked on Subies. The website mentions that the PCV valve needs to be changed only if needed. So, unlikely, I'm going to go to the dealer to do stuff I don't need.
Any further thoughts?
-mike
Remove it, and it should let air travel in one direction, but not the other. It either works or it doesn't, pass/fail style.
If it's clean at 30k, you should be fine, but I'd change it at 60k regardless.
I'm with mike on the diff fluid intervals.
My Miata, at just 30k miles, had what looked like melted chocolate in there when I drained it. It was nasty, clowdy and brown. It was 8 years old, so I'm sure it was age.
My Forester wasn't that bad at 60k miles, but it was a lot less than 8 years at the time.
Don't wait 8 years, no matter the mileage.
I think my Haynes book, while it did outline the procedure for removing the filter, never indicated that it should be replaced on a regular interval. I changed the fluid in the car several times, but I never replaced the filter. 220K miles, no problems with the transmission.
-mike
-mike
So I'm considering taking a kayaking trip in the Adirondacks and one of the access points requires a fairly substantial stream crossing (outlet from a lake actually). What is the maximum water depth I should consider driving through to avoid damaging the car (engine). The water level fluctuates but it's at least a couple feet deep - maybe around 3 ft. at high water; last year I went through with a friend who had a Honda Element and it made the crossing several times without a problem.
Does Subaru actually specify a maximum depth for the car ?
23 Civic Type-R / 22 MDX Type-S / 21 Tesla Y LR / 03 Montero Ltd
3ft is highly unlikely though.
Where in the Adirondacks are you going? I have a place up there.
Also if you do it, get a K&N Filter, I've used them in all my offroad vehicles and they are real good at preventing water/mud intrusion from such crossings.
-mike
Oil & filter (which is all I'll provide)
Fuel filter
Automatic transmission fluid service
Change F+R differential fluids
Brake fluid flush
Air filter
Coolant Flush
Its amazing how much prices vary between service locations. Joseph Subaru in Florence, KY, charges about $55-60 to install a cabin filter (parts+labor), while Beechmont Subaru in Cincinnati (28 miles away) charges $90! I think I found a good independant guy. He also deals in Nokians. I plan to replace my worn Falkens with the Nokian WR, and not worry about changing tires in winter.
Thanks for all you guys' help. Any one ever used the WRs on their Subies?
Either way, it is definitely worth checking/replacing fluids after the trip to ensure no water is hanging out in differentials, etc.
-mike
I am a "too bad I did not get a photo of that!" kind of person.
Any how, here's that pic....
lark6 has the black one, mine's the green one.
Brat water crossing
old school subie (must be over 2 ft in spots)
Outback Sport crossing the (pretty shallow) Sandy River
WRX water crossing
and just for fun:
Forester crossing a log
modified subie GL wagon river crossing
Craigslist
Anyways - I'll now be able to judge better whether to risk driving through there or just leave the car on one side and portage the kayaks in...
BTW the location in the Adirondacks is called Chaney Pond and it's a great spot north of Lake George to do some kayak / canoe camping...
After driving it for a few days, I began to notice several things that could be potential problems. I had a Subaru dealership check it out (they did the basic $70 used car 1,200,063 point check). It got a clean bill of health except that it has a small leak in a valve cover that is leaking into the plug chamber (i hope i got that right). He said tht it was not something I needed to worry about right away, but something I would want to get fixed in the future - and then he sent me on my way.
I will now list out the other things that I think could potentially be wrong. Any insight into these problems would be very much appreciated. Here goes:
1. The rear brakes are squeeling when coming to a stop at low speeds. It's a high-pitch squeel, and only when I come to a stop. Wouldn't the dealer have seen poor brakes when inspecting? Any ideas?
2. The rear-end jumps and shakes the car when I let-off the clutch in first gear? The car bounces, and I have to re-engage the clutch and let it out slower. Is this an AWD thing (I have never owned an AWD before), or is it something I should be concerned about?
3. The clutch feels like it might be slipping. When shifting from 2nd to 3rd, or from 3rd to 4th, there is a delay from when I let off the clutch, and when the gear catches. I let off the clutch, and then there is a 1-3 second delay, and then the gear catches (you can feel it and hear it).
4. Puff of blue smoke when starting in the morning. I believe this could be from the oil leaking into the plug chamber. After first startup, the exhaust looks and smells very clean.
So sorry for the incredibly long email. I'm just worried that our new (to us) Subaru might have some issues. I need to figure this out before it is too late to go back to the seller with the problems. Thanks so anyone who can help me out with this.
The rear brakes are drums, so it's probably just collecting some dust inside and causing the squeeking. I would spary in some brake parts cleaner and see if that helps. While you're down there go ahead and spray some lithium grease on the sway bar links.
The rear-end jump is probably caused by a bad wheel bearing. Have those inspected. Up until MY2003 that was a common occurence.
Good news is I don't think any of those issues are very serious. Enjoy your Forester.
My Forester has experienced all of the above issues, and a few more. Despite these problems, all of which have since been repaired, I really love my car, and would probably buy a new Forester again. Best of luck with yours.
Len
As for the jumping in 1st gear, it's common that 1st gear really can't be used on a subaru while moving. You can use it to start out but you can't go back into 1st until stopped.
Smoke is probably from the valve cover gasket leak.
-mike
Finally got new air, fuel and oil filters and the fluids changed (transmission, diffs, brake, coolant, oil). Since the Falkens were worn down to the wear-bars, I finally got the Nokian WRs for $136 each (balanced, mounted, alligned, tire-disposal, free lifetime balancing & rotations). After those Falkens came off, it was like driving a new car.... where was all that road noise? These Nokians are quiet... The car rides smooth. Now I'll sell my Blizzaks, and save the yearly switching expenses.
The total for all but the tires was about $365, taxes included. I only provided the oil & filter.
By the way, should I always stay with 5W30? I hear people with higher milage going to 10W30. That's not what the manual states. I plan to stay with Mobil 1, and aim to run this car into the ground. If the change is advised, at what milage can this change take place?
BB
PS: 4-Blizzaks WS50 215/60/16 for sale!
Mobile 1 is ok, but I'd suggest going to Amsoil or Redline as they have a better synthetic than M1.
-mike
Thanks, Chuck
You can put your head in there if you want. They put 17 inchers on the XT's so you shouldn't have any problem. SubaruForester.org has every question you might have answered...
Maybe, as the engine ages, I'll try the Redline/Amsoil. I plan to change filters every 3.5K miles, and change oil every 7K.
Other than Nokians, there are the Michelin Exaltos and Bridgestone Potenza G009s to choose from. Hope this helps.
Gold one, with a sagging front end?
Looks like a Forester with an Outback nose that melted slightly.
I found it hideous and I'm praying it's not accurate.
http://www.subaruforester.org/vbulletin/showpost.php?p=242881&postcount=206
http://www.subaruforester.org/vbulletin/attachment.php?attachmentid=7829&d=11884- - 29087
The smooth sides are OK, I suppose, but I'd be worried about door dings. Creases add strength.
Where's the cladding? It's too slab-sided.
It really does look like they took an old one, a 98-01 model at that, and grafted an Outback-like front end. The drop in the headlights look weird, though I like a similar design on the GMC Acadia, so if executed properly that could look good.
In the same thread people discuss the Forester as a downsized Tribeca rather than an upsized Impreza. I have mixed feelings about that. The Forester might get too heavy and expensive. Plus it will cannibalize the Tribeca.
They really have to make the Tribeca bigger for the next generation to differentiate it more. If the Forester grows much it'll basically be the same size (like the RAV4 and Highlander were for a while).
-mike
Sadly, there is little point of cladding any longer, since (I believe) they have done away with the unpainted cladding on the Forester.
What is the point of painted cladding? There is some dent resistance, no doubt, but you will still get chips and more visible scratches than the unpainted cladding would suffer.
I guess it's all part of the perpetual "upscale" mania that auto manufactures suffer. Dag-nabbit, give me "Inexpensive and built to stay that way" or in Honda-speak, "We make it simple"... or was that Burger King? :P
crotchety old-timer, james
-mike
Here's hoping they offer a diesel model with unpainted cladding and steel wheels for 09.
-mike
Steel wheels, with hubcaps are cheaper, WAY easier to clean, and in many cases, lighter than alloys. I must confess that I did put 16" aluminum wheels on my pickup, but I'm considering going back to the smaller steel stockers with my next tire replacement.
james
-mike
Still, Subaru has been changing directions lately. 2 years ago we kept hearing the word "Premium" which annoyed me to no end.
Since then, we've seen the arrival of the Outback Basic, with steel wheels. The Forester has always been slotted slightly beneath the Outback in the lineup.
So all signs are for the 2009 Forester base model to get a similar de-contented model. On that one steel wheels and unpainted bumpers (and or cladding) would make sense.
I'm not sure what to think of a baby Tribeca style Forester. Sure, it would be nice, but the Forester sells well now and I really think pricing it higher will backfire.
