I am no mechanic but I did notice an article (Edmunds Tech Center) Injector Perfection that seem to me that it could be a sensor problem.
I would like to know has anybody been able to solve their stalling problem. This is frustrating, time consuming and not to mention dangerous.
Also, how do you change the bulbs for the odometer/trip display and the clock? Someone told me the dash has to be removed. They have not worked since I bought the car and now the lights on the gear shift are out as well. Is that a bulb too?
Finally, it has a little over 200,000 miles on it. When I reach certain speeds it kind of hesitates and I have to accel for it to go into gear or let off the gas for a second or two. When it does this and goes into the next gear it kinda clunks which I have been told happens with the kind of miles that is on it. Could the hesitation and clunking be a sign that I should have the transmission flushed? I don't know what the previous owner did with it so it could be non-Honda fluid in there.
Bad Relay Info
Henry
Some people can't hop on Edmunds at work!
This can be easily replaced, just follow the directions, which you can find here.
He has a link on the page to a Acrobat file that you download that shows pictures.
I don't know what Midas uses for brake pads, but let's just say there is the good stuff and there is the better stuff. The front brakes will usually wear out faster because most of the weight is on the front end of the car, especially under braking. Midas probably has a lifetime warranty on the pads, but you'll basically be paying Midas for another brake job minus the cost of the pads if you return there to cash in on your warranty.
Your choice, but I'd have the dealer or a shop specializing in Honda's take care of this if it was me.
The dash board light, door and trunk indicator lights stay on even when everything is closed. any clue what might be wrong 1992 honda accord.
Please email to zoinks68@gmail.com if you have any information. We're trying to find a good mechanic and we don't want to GUESS as to what the problem is.... any information would be great! Thanks.
I have an '01 Accord 4 cylinder with 69k miles. At regular idle the car runs pretty smoothly. However, with the A/C on or the headlights on, the car idle much more roughly, particularly with the A/C, where moderate vibrations are felt throughout. Now I know that both these processes put extra strain on the engine, thus causing more vibrations. However, my question is, if there is any way to reduce the load on the engine with the A/C or headlights on? My motor mounts (the two that I can see) do not look bad, and the engine does not seem to move too much. I have heard information about performance pulleys, but I am not sure. Any info would be appreciated.
off their is a very loud noise that is coming from the rear left side of the car - almost
like a exhaust problem. I looked at everything and the exhaust looks great. So I changed the rear wheel bearing and again nothing. Also the second problem is that the paint is starting to flake off. Is there a way Honda could help cover it or should I just bite the bullet and repaint the whole thing?
Thank you for your time if you would like to email me its twoobaron@aol.com
Dealer found the transponder for the ignition interface as well as the chip in the ignition key to be defective. Made new keys (did not do the valet key) at half price and discounted the transponder. I did have the recall work done previously.
Hope this helps.
http://www.honda-tech.com/zerothread?id=1844067&page=1
Iwantone,
If you want to, don't go to the dealer; get the check engine light analyzed for free at AutoZone if you want to make sure that is the problem.
