Nissan Titan Towing Questions
Hi all, I am wondering whether anyone has any experience with adding a regular truck camper to their Titan - gross vehicle weights, airbags, etc. ?
Peter
Peter
Peter
Wondering if anyone can help me with a fuse/relay location question for my '05 Titan SE 4x4. I have obviously blown a fuse that powers the trailer running lights. There was power at the 4 pin plug but now it's gone. Brakes & turn signal lights work and they are marked in the fuse box under the hood. Can't seem to locate the running light fuse though.
Any help will be appreciated!
Hope this helps.
Did you ever complain to the BBB, file a suit, or anything against that dealer?
SP
As far as towing, I recently purchased a 29 ft Starcraft Travel Trailer. The Titan towed it with absolutely no problems, (aside from sucking lots of fuel)! The trailer weighs about 4,600 lbs but I do have the Equalizer Weight distribution hitch and the Prodigy electronic brake controller. I believe these two things made a big difference.
So,has anyone put a 5th wheel hitch on their nissan without buying that expensive hitch???
If so,could you send the plans on what parts I need to use my old hitch.
Thank you. Steve
