Chrysler 300M: auto-dimming side view mirrors
I just purchased a 2000 Chrysler 300M and really love the self-dimming (electrochromatic) rear view mirror. I would like to get some side view mirrors with this technology but can't find it anywhere on the web. Does anyone know if any exist that would work and where can I get it?
Here is a picture of another 300M with a blue (mine is white) lighted ignition.
This is an old thread. If anyone wants to know, then I will explain my procedure for remedying this.
Brad
My procedure is based on my experience with a relative's 2001 Jeep.
The photochromic layer is between a outer clear pane and and an inner regular heated mirror bonded to the plastic backing. The simplest solution is to remove the outer pane and carefully remove any residual photochromic material. You end up with a heated mirror which is not autodimming.
To do this turn the mirror all the way out and unplug the photochromic connection which will be seen to enter the bezel. Do not mix up this with the wire which powers the heating element to the back of the mirror.
Then separate and remove the bezel with a razor scraper, perhaps starting at the seam at the bottom, center. Then separate the outer pane by using a gentle stream of water and a razor scraper as a wedge between the two panes of glass. Carefully scape away any residual brown photochromic material from the front surface of the mirror. Do not use an abrasive pad, some contain embeded alumina particles which will scrape the front surface of the heated mirror and ruin it.
I will let you know how it turns out.
Brad
1. The connector for dimming function is connected to the bezel and can be disconnected by titlting the mirror outwards.
2. To drain the photochromatic liquid, I used paper towel to wick it out, thereby reducing the chance to get it on the panels.
3. I fixed the bezel back using 100% silicon cauck, which will preven any water getting into the heating element area.
I really did not believe it would be so easy to fix the auto dimming mirror. Now I have all the features, i.e. heating, memory etc. and I don't care for the auto dimming any more.
