Anyway, glad to hear it was only a thermostat. Seems it's only the expensive stuff that breaks on my burb i.e. transmission and recently an a/c compressor.
___________________________________________________________
How high are you talking about?
A second Chevy dealer checked the whole front end and also could not find anything wrong. Idler arm, ball joints, tie rods, the whole nine yards all check as OK.
Any ideas?
Caesar
terry
Larry
It is supposed to be annoying so that you would take your vehicle to have break system repaired. Why would you keep driving a car with ABS warning light on?
I hope NOBODY gives you instructions of how to disable the chime, but that's just me.
--Arrie--
If it was you I think you need to spend the money and have it fixed. If it was the GM service telling not able to fix it you should contact some government agency and report it. Any brake system alarms are no go.
Yes, cars did not have ABS in the past and you can drive a car without ABS brakes just fine but when your car has ABS built in to it it is not 100% safe to say that when ABS light is on the system works like brake system without ABS.
Just think about it. How does the ABS system control the braking force when it is enabled on slippery surface? It relieves the braking pressure that you apply from the pedal, right? That is why you feel that pulsation on the pedal when ABS works. What if the ABS system with the light ON would decide to just relief all of the braking force as you apply the pedal when you are driving on dry pavement say 50 mph and the car just 100 ft in front of you suddenly slows down for a turn?
--Arrie--
1) every morning, when i start it up to go somewhere, it blows blue exaust out the tailpipe. it shoots one giant poooof then its over with and doesnt do it again till it sits overnight and ran in the morning. i have no clue about it and it is kind of embarresing
2) squeals!!! also, when i start it in the morning the belts squeal like no other. the belts are new and all tight. it will continue to squeal until it is shifted into gear, then it stops immediatley. but, when it doesnt squeal, it whirs, like an idling jet liner, very strange. it isnt harming anything, but it is also embaressing, especially when i live in a nice and quiet neighborhod. something about hearing that at 8 am i the silence of the morning would drive me up a tree. so if any one has any way to fix/help the problem, my neighbors and i would realy appreciate it
If your belt are new and tight and they still slip it probably means that your belt pulleys are worn out so that the belt bottoms out. Belt should not bottom out, it should touch pulleys only at sides.
You probably need to change pulleys or you could try an over size belt, a fat belt, that would work on those worn out pulleys.
--Arrie--
The way belt transfers torque to the pulley (or pulley to belt) is the wedging effect between the angled sides of the belt and angled surfaces of the pulley groove. If the inside surface of the belt comes in contact with the bottom of the belt groove in the pulley this wedging effect is lost and belt can transfer dramatically less torque, i.e. it starts to slip.
When belt pulleys are worn too much even a new belt cross section is not big enough to work with it correctly and for a fix the pulleys must be changed.
In some cases it is possible to use bigger cross section belts on worn out pulleys but the best fix is to have belt pulleys changed. It can also be a hazard to operate pulleys beyond their design as they can break if they become too weak.
--Arrie--
Anyway, it makes sense that with AC on it squeals more when starting the engine. It just adds more load to the belt at the moment the belt is cold and does not have the best friction characteristics yet.
You need to check which pulleys are worn. Perhaps it is the AC compressor pulley, but this probably has been changed somewhere on the way as it is an '88 model vehicle?
The most likely worn belt pulley is in the end of the crank shaft. That probably has not been changed.
Wether it is a do-it-yourself job I don't know. I'm sure it can be done but what tools you would need I can't say. Perhaps a couple of wrenches and a puller will do it?
--Arrie--
If it does not charge after changing alternator and battery for numerous times it is obvious that the wiring is not connected correctly or you have a broken wire somewhere. Also check the fuses, which you probably have already.
--Arrie--
Seems to me it is an electronic sensor that isn't working when engine first starts up or is cold. Please don't tell me I have a fuel injector problem!
Thanks for your help
Anyway my problems, first I have a serious issue with the truck starting. About 5 months ago, not long after I had the battery replaced (after having problems with buying a new battery that turned out to be bad) I started to have problems with it not always starting, all the electrical would go on, the radio, climate control etc. but nothing would happen with the engine, no sound nothing. Usually if I just sat there and continued to turn the key it would eventually go, but sometimes I could be sitting there for quite a while. I checked out the battery cables and made sure they were tightened down, one was really loose, so I thought I had solved the problem, no such luck. Next I had the starter replaced, I had it checked out and it was pulling way too much power from the battery to start, indicating that the starter may have been warn down. That actually seemed to work for about 2 to 3 weeks with no real problems, sometimes I would turn the key once, got nothing then tried again and it was fine so I just shrugged it off. Now it's back to it's old antics of just not starting. This is a car I inherited from my parents when they decided to move across the country, when they still had it about 3 years ago they had the engine replaced, and at that time they put in all new spark plugs and wires, (the engine however was used, I believe it had 10,000 miles on it.) So all I know is that those things were replaced recently, the battery is good, the alternator is goos, the starter is brand new. So what else is there?
Also, a much more minor problem, when the airconditioner is on the suburban makes a HORRIBLE buzzing sound that makes passers by think it's about to die. This has been a problem on and off for a couple years. I've been told it's the compressor (I think... I honestly can't remember anymore) which would cost me $900 to replace, if that's the case I don't have much need for airconditioning at the moment.
any help at all would be wonderful!
You say the problem is that the engine does not even try to turn over when it won't start. This means that 1. Your starter motor is bad (yes, new ones can be bad too), 2. Your starter solenoid is bad, 3. The wire from the key cylinder to starter solenoid has bad connection, 4. The Park/Neutral switch is not in Park/Neutral position at time you try to start, or The key cylinder itself is bad.
I would not go after the starter motor at first as it has been replaced, but sometimes a new motor can have a problem though...
The starter solenoid is a very likely problem, i.e. when you turn the key a small wire from the lock cylinder powers up and engages the starter solenoid. Starter solenoid then allows the high amperage current to flow from the battery to the starter motor. Have your starter solenoid checked and also have it checked that the wire from the key cylinder powers up when you turn the key.
Another likely problem is the Park/Neutral switch. You know that all vehicles must have the gear shift at Park or Neutral for it to start. This is done using a small switch that engages that small wire from key cylinder when gear shift is in Park or Neutral position. Have this switch checked.
Sometimes you can also work on the Park / Neutral switch yourself. Next time the engine won't turn move the gear shift a little bit or move it to Neutral position and try start there. The Park / Neutral switch can become flaky and it looses it's correct set position.
Then the key cylinder itself can be worn out. It is a mechanical electric switch and it wears out over years and can become flaky before going all the way out.
The horrible sound from the A/C compressor probably can be helped by putting an oil charge in the system. This is very easy and low cost fix and could just fix the whole issue. You say the horrible noise has been there for a couple of years but the compressor still works?
Go to car part store and buy a can of A/C oil charge and the service port hose. Follow instructions and charge the system with oil.
A/C systems must be charged with oil from time to time as the oil in the system wears out just like motor oil does. Also, the dryer in the A/C system tend to 'collect' the oil leaving less and less for the purpose of compressor lubrication.
The compressor is a 'piston engine' which has metal parts sliding against each other. This needs lubrication what the oil does. Your vehicle being a '94 model, your A/C probably needs some oil...
--Arrie--
I had a bad connection on the MAP sensor wire harness and when I had the problem it shut down the engine when I touched it but no code was present. Big surprise not to have code for this. Repeated it for about half dozen times and no code was set.
--Arrie--
I replaced mine. The sensor cost I think about $65 + tax.
For changing the sensor the starter motor must be taken down, two bolts. Sensor has one bolt. Need torque wrench for starter motor bolt tightening.
If you buy plastic ramps and torque wrench and part I bet the cost will still be well less that $200 doing it yourself.
I had the tools already so no cost buying those but $325 is just ridiculous when the job itself takes about 20 minutes at the shop. For me it took about 30 minutes when I need to set the ramps and then crawl under the vehicle.
Being hands-on person really pays back quickly with these cars.
--Arrie--
OH, I am also having problems when accelerating up a grade and the engine starts shaking. Replaced the coil, spark pluhgs and wires and now , the number 3 injector. Any ideas?
Have not had a chance to follow up on some of the suggestions. I do plan to take it to a garage and have them check codes on the PCM(powertrain control module). That was one of the suggestions that I check to see if that produces any codes related to the problem.
Didier
