Well, considering the fact that the old Hondas really don't have that many "electronics" as far as luxury features (NAV, heated seats, etc), I can't honestly say, because they aren't old enough yet. If the rest of their cars are any sign to the integrity and reliability of their engineering though, I'd say yes.
The best I can tell you is that all the power features in my 96 Accord work (with the exception of one noisy power-door lock)... A/C, power windows, stereo was still working until I replaced with aftermarket Pioneer CD player (had tape deck), cruise control, all work without any problems.
Our van was 5 years old when we traded, it had a flawless Auto Climate Control System, Stereo, all power features including power doors; no problems to report on the electronics.
Check out the "Problems and Solutions" boards to see where people are having trouble; it tends to be with other things than electronics (V6 transmissions), with the exception of 2003-2004 stereo head-unit display failures, which Honda seems to be good-will-repairing even on the cars already out of warranty.
Great choice. I have a 6-speed Accord and put a 6-speed Civc Si on order. The special order fell through so I bought a nS2000. Put an Invidia exhaust on it and not only does it sound like an F14 , it runs like one also!
Enjoy you Si, a sweet car
MidCow
thus far i really am happy w/ my choice. carefully monitored (i.e. exact routes, 2runs) mpg checks seem to indicate 36-37 mpg in the 70 mph range. its true what they say about the i4 once vtec cuts in. i'm amazed. as mentioned elsewhere its a hoot in the twisties, given class of car. still, true fun in the twisties is enhanced w/ a manual trans vs auto trans, IMHO. a disability precludes daily use of manual trans otherwise a manual would have been the only consideration.
having said that, i sometimes wish i'd gone for the v6. fun factor is undeniable but again its enhanced w/ a manual vs auto trans, again IMHO. one thing against the v6 (I stand to be corrected) is inability to disable vsa/tc. fun factor is all about engine control so its de-enhancing.
in the end the main factor in choice of i4 is that i was unwilling to pay inflated car insurance premiums, fines and loss of points w/ the v6. there would be speeding tickets! believe me. some things don't change w/ age. )
I'll correct you. Pressing the "VSA" button completely disables the Stability Control, allowing full control of the engine. It's not like some cars that only reduce the amount of intrusion, it does completely disable it. The button is next to the moonroof switch.
b>.......having said that, i sometimes wish i'd gone for the v6.
.....the four - to be sure - gets better fuel econ than our six............
...but you know, it ain't THAT much better...............
True, there are always exceptions............
....but the six has this really tremendous reserve bouyancy
(forgive me - I was at sea too long)...POWER, POWER, POWER is whut I mean........
..best..ez
Hmmm... I wonder if that's what Chrysler referred to in the '30s in the company's "Floating Power" advertising campaign...
OK, I've read differing stories about when's a good time to switch from dino to synth. For instance the AMSOIL website says at 500 miles, while you seem to indicate that you will wait for 10,000 miles. I have also seen others saying 1000 miles. What's up with this?
A related question: Once you start using synthetics you don't have to change your oil as frequently as Honda tells you to. However, waiting longer between oil changes would possibily have an affect on your warranty and/or EW. Any ideas on this?
I tore the engine down to replace both head gaskets, and found the engine to be perfectly clean, and most importantly, you could still see the cross-hatch honing marks in the cylinder bores done at the factory. This, of course, means the oil was really doing its job.
I use Mobil 1 5W-30, but still adhere to 3K/3month oil change intervals as the vehicle is used under severe service with substantial stop-and-go city driving.
I've owned Hondas before, and although their oil maintenance minder system is good, I'd still change at a shorter intervals, even using synthetic. Changing oil at 10,000 mile intervals is not good regardless of oil used - just ask any good automotive tech. And, this is especially true if you do any city driving.
I guess I was thrown off by the AMSoil website, which recommends running their oils for 25-35,000 miles. I use a Mobil station for service, and have changed my Mobil 1 every 7000 miles, but before I traded in my Passat I had decided to cut that to 5000, so I'll stick with that. Any opinions about AMSoil vs. Mobil 1? If you read the AMSoil website they seem to have lots of empirical proof that they have the better oil. I don't mind paying a few dollars more for a better oil if I only change my oil three times per year.
Someone has to be kidding here. The oil will get way too dirty by 25k miles. And change the oil three times a year, not unless all it does is sit in the garage. And do you actually believe what a companies own web-site says about it's own oil.
It says 100%, 50%, 40%, etc.--but of HOW many miles?
The maintenance minder goes on engine revolutions, instead of mileage.
25,000 miles is completely bogus; I'd never go past 10,000 miles for an oil changes.
*For do-it-yourselfers anticipating draining the factory-fill oil, do not be alarmed if the oil drains with a puzzling, gray-black metallic sheen (page 4 of 8). It's NOT indicative of excess bearing wear metals. That sheen is the excess moly that's still suspended in the motor oil. These are particulates that are milled to less than 5 microns, so they freely pass through the oil filter and remain in the oil where they're available to "heal" wear areas that shed their initial moly coating during run-in. (Moly is intentionally sacrificial to protect bearing metals under high load or momentary oil film loss situations.) Among conventional motor oils, Chevron Supreme and Havoline [one and the same since, a) they're both produced by Chevron Oil Co., and b) list exactly the same physical properties in their respective online product data sheets] have especially high moly treat rates. CS is typically priced less than Havoline for some reason, but may be the more difficult to find at retail channels other than Chevron gas stations - where it will command an inflated price. Happy motoring all you Honda-heads!
I am planning to buy 2007 accord EX-L but still can't decide V4 or V6. What do you guys think? I wanted it to be fuel efficient but I am afraid the I4 can't move when it's going up a hill.......
Oh, one more thing, the sales give me $22000 for V4 Auto includes every fees, except Tax. Do you think it's a good deal?
Thanks, guys!
I suggest you drive both and then make the decision. You know your driving habits and routes so you'll know if you want to give up the mileage to get more power.
I love the I4... although I didn't like the automatic. The manual is quick and responsive. I don't find the lack of power to be much of a problem... but I'm a mpg freak so I really appreciate the great mileage. I've got almost 19,000 miles on my 06 EX-L and I've never had a tank below 30 mpg.
PS: It is an inline 4cyl. (I4, not V4).
But you will pay a small price for the V6 at the pump!
I imagine the I4 with manual 5 speed is probably the most perfectly balanced choice of mileage, reliability and power. Having said that the v6 adds the unquantifiable element of 'fun'.
I think either choice is great.
I think the quantity is the increase in horsepower and torque
Steve
....another V-6 6M here....agree w/Bristol across the board.
...BTW, recent highway fuel data:(LA to Vegas, Burbank to the state capital)...both were a micron under 36.
..very little skill will get you over 36 with the 4 cyl.
..a great deal of concentration, patience and so forth CAN get you over 36 MPG with the V-6 6M....
..looking forward to driving the NextGen $ cyl 5M......
..best, ez..
He speaks the truth my friends! I got 36.4 MPG on my very first trip in my I4 Auto Accord (2006 EX). I did that by driving up the highway with the cruise on 78. After that, I have tried to maximize my mileage, and have cracked the 40 MPG barrier twice!
Try buying that little baby in any set-up other than v6 6m and you will definitely feel like you missed out!
Can't wait!
Also this car does excellent, on the interstate, but at
points maybe-maybe it could use a bit more power.. Very smooth, handles the road very well. I love my I4, but for those that want even more fun, Go for it! can't blame ya.
Test drive them both, although I have not test drove the v6 at all, so all I know is the I4, I am afraid to test the v6, I don't wanna wish I had it.
Also, my car already has equity in it, so when I trade it in, its going to be great. I think I have atleast $4k equity right now, Awesome,
I CANT WAIT TIL THE NEW ACCORD>hope there not too expensive.
The reasons I'd like a V6 are typical- I'm young, I want a speedy car.
My gf has a 4 SE, and I am very impressed with the I-4 engine. I have a 95 Maxima which is just awesome in my opinion, and the 0-60 time in the I-4 SE is only about 0.5 seconds behind my V6 Maxima. But for some reason, it doesn't feel nearly as fast or fun to drive as the Maxima.
The primary reason I'd want the EX-L is the leather seats. Honestly, I don't care about the other goodies in that car, but the leather seats do make it very attractive.
So any opinions would be appreciated.
Also, would it feasible/possible to later on get leather seats aftermarket in a car?
If you drive a lot on highways that are pretty fast flowing, the extra power of the V6 is nice to have.
And, of course, you can only get the heated seats with leather. That isn't a big deal with me but it is VERY popular with my passengers, even though only the seat is heated on the passenger side.
The worse part about the SE is the steering wheel - a leather wrap on that would make such a difference.
But then again, we all know that some of us would go out of our way to stick with the I4.
..One has to draw the line somewhere.... we all have a different line.
4 cyl has a timing chain; my 6M uses the 105k-limited belt.
Advantage: 4
However, the six has better numbers than my 350/350 'vette.
..and still will approach 40 mpg using cc/6thOD/2150......
Advantage: 6
..both great cars; both with a "different line"
best, ez..
....whatever.....
(..had a problem believing it myself...)
..ez..
I have a 4-cylinder 5-Auto Sedan that is capable of over 40 MPG when very steady at 72 MPH. Imagine at 60MPH!
Like I said, very steady. Any acceleration or speed fluctutations put me back into the mid-high 30s.
2. Consider moving closer to work.
The gas mileage averaged around 24-26 mpg with 80% highway & 20% city.
Ended up having a lot of problems with the car but a co-worker has 120k+ on a 4cyl LX w/no issues. He gets 35 mpg on the highway & has plenty of power.
I would get the '07 4cyl to save on gas + it is more reliable than the V6.
It was from a one single price type of company so no haggling was involved.
...me too (23.4 plus TTL). If you can possibly go 2-3 grand more - - - - - the new vehicle would seem preferable.
..ez..
