Lexus ES 350 Voice Recognition
Has anyone had their NAV unit changed out to solve this known problem? The TSB # is EL-008-06. If your VIN # is prior to (less than) JTHBJ46G#72022076 your vehicle is likely affected. My dealership acknowledges that the TSB is accurate but says that when they spoke with LEXUS, LEXUS said the fix hasn't been finalized. The replacement NAV unit, changed under warranty, cost about $10000 to $12000 depending on who your are talking with. Thanks, Alien
IMHO--I find it hard to believe that it would cost $10K to replace the nav unit; no factory nav unit is worth that much, and from what I can deduce, essentially all they're realling doing is a simple swap of nav head units and some kind of reprogramming (someone had mentioned that her nav unit got replaced but the VR problem was still there--only after it was discovered that a required programming step that needed to be performed hadn't been done did the replacement unit work correctly).
The only down side is that I had to reinput all my stored phone numbers (Verizon phone).
also.....
i see it cycles thru mpg and you can see distance traveled but how do you set time clock.... the nav will tell you projected time and distance but not actual time spent driving... i had a es 300 and that was part of the info cycled that you did from the steering wheel but i dont see it on the new 2007 es 500
i have taken ES 350 2010,
how do identify the version of the dashboard unit installed,
what to i ask for to upgrade: currently two main things are missing
1)Audio speaker system the bluetooth does not pair with bluetooth enabled audio players, to stream audio, AD2P
the Audio tabs does not have Bluetooth tab.
2) Voice commands for climate control/navigation/, and all other possible (some uses said upto 100 general commands) do not work.
looks like
pls guide me..
