Pontiac Grand Am Heating/Cooling
Sometimes the temp. gauge goes up to 90 degrees, and I finally have heat in the car, but usually it stays below that.
HELP please........
This is the second time I post my question....if anyone can help I would appreciate it so much..
I also need to replace one of th bulbs inside of the control unit, so any insight that anyone can provide about the other problem would be great so that I can take care of both issues at the same time.
Thanks!!
Not sure where blower motor resistor is located in my 12002 Grand Am. Could you please point me in the right direction?
I have been to "Pull-a-Part" junk yard, and the blower is located, and removed under dash???
On older pontiacs, with blower on fire wall this is easy to test and fix. Ussually a loose connector, bad fan, etc. On this piece of crap its a b*&%th.
Thought I'd ask first, any hel out there??
Bill
The "resistor" is a small circuit card located next ( behind ) the blower motor.
On my 2000, the blower motor is under the dash on passenger side. You need to remove the shrouds under dash, and maybe the glove compartment, then get in the car and look under the dash. Really stinks!!!
The card is in a plastic bracket held by 2 screws.
Good luck working up side down.
2002 Grand Am SE V6
Also, my heater works great, but the AC doesn't blow cold. I think there's a leak somewhere. I had it charged a couple years ago and it lasted for a couple days.
any ideas, Thanks Cliff .
my 94 Pontiac grand am GT has an issue with the heater control.
problem is, no matter what i set the control to, air will flow through every vent; top, bottom, and defroster.
I already went ahead and replaced the heater control as I thought that was the problem, but it didn't resolve my problem.
I really wish to get this fix so that I can the A/C working again and also so my windows can defrost much better during the winter months.
I appreciate any help provided for this issue I'm having.
