Subaru Forester (up to 2005)
Almost all cars kick A/C on automatically when you use defrost (again, to dehumidify). Note that A/C does not have to mean "cold" (the system will mix engine heat in to warm the air).
After watching my wife fight with the auto climate systems in our Forester and Outback (I have no problems with either car) my advice is to either: 1) go to manual override and do things the way you want or 2) put it on auto and only touch the temperature adjustment -- that's the only knob you should be using to adjust the comfort of the system.
About the only time of the year I override the system is spring and fall, when I can just vent in outside air to be comfortable. Rest of the time I leave it on auto.
Craig
My only gripes with the car: power IS sluggish at times, but am too frugal to keep my foot in it and don't need the turbo; a six would be better, IMHO. Mileage isn't great, which may tip the balance in a year or two from now when Ford gets the bugs worked out of its Escape hybrid and I'm looking to trade. That weirdly-gated shifter makes a third-gear trespasser out of me too often, and I still wish I could adjust the driver's seat higher and further back. But in all, a good car and one I remain pleased with, especially when nice discoveries like the one that led off this post are made!
One of the more enterprising members of the board has come up with a fix / enhancement. I hope to install said fix this weekend. His rationale, and his results both seem reasonable so I think its going to make a difference. A big difference I hope.
The theory behind it, is that the air tube that senses's cabin temperature (it's behind the ignition lock on the dash - the little grille there) doesn't sense temperature quick enough. The solution appears to be to force feed air into the tube and therefore on to the sensor to improve the system's response time.
HTH
Larry
Remember, the Focus and Escape launches were very problem laden.
-juice
Or long necks?
My choices thus far, in no particular order:
2001 Forester (2.5 H4, 165 hp)
2001 or 2002 Mazda Tribute DX (3.0 V6, 200 hp)
2002 Saturn VUE (3.0 V6, 181 hp)
2003 Pontiac Vibe GT (1.8 I4, 180 hp)
2001 or 2002 Nissan Maxima (3.0 V6, 222 hp)
2002 or 2003 Saturn L300 (3.0 V6, 182 hp)
OK, based on what I’ve read here, it seems that the Forester and the Vibe are very popular. However, I am concerned about the power of the 4-cylinder engines. The horsepower, at least in the Vibe, is comparable to that of the V6s in this list, does that mean they are equally as powerful? What is hp all about anyway? With the exception of the occasional camping trip, I don’t do a lot of hauling, but I want something fun, with snappy pick up and the capacity to power up the I5 grapevine with confidence. It seems the VUE would be a good alternative, but the mixed reviews make me hesitate, and I would be turned off by an interior “splashed with plastic.” Plus, used VUEs are very expensive in Southern California, much higher than is suggested by Edmunds true market value for my zip so I’m not even sure I could really afford one.
The power issue is my main question here but I would also appreciate any comments or rankings on the other choices in my list.
JEG
Craig
Edmunds considers the Escape/Tribute a good pick for power and safety with the V6. Skip the 2001 models as some of those version 1 models had teething problems. Before buying the Forester I seriously considered E/T. The main reason I went with the Forester was the 3-4 increases in MPG over the V6 4WD E/T. I don’t know your zip code but I plugged Chatsworth 91311 zip code on CARS.COM and got 50+ hits for max price of $18K, you know wiggle room. There was one 04 V6 2WD Escape for $14.9K. I know a couple people with V6 4WD E/T and they are quite pleased.
With the rapid increase in gasoline prices you may want to put MPG high up in your purchasing priorities. Have Fun.
'17 Chevy Volt Premiere
IRT the HP issue, horse power is the most widely used measurement of how powerful an engine is but as Craig pointed out, taken by itself the HP rating can be misleading. You'll get a far more accurate picture if you compare both HP and torque as well as where the peak output is for both (the lower the rpm the better generally speaking). Many engines have similar HP and torque ratings but if you run across one that has noticeably more HP it usually means that you really have to rev the engine to get much performance. For good acceleration, you want an engine that will produce a lot of torque at relatively low rpms. Hope this helps.
-Frank P
I have a 2001 Forester S and am wondering if there's any info available anywhere on the stereo (in dash 6-CD changer/cassette/radio) that came installed. I'm hoping to connect my iPod to it using one of the mods I read about on ScoobyMods... but that was for an XT. Before I go pulling the console apart and taking out my stereo, I'd hoping to find out if my stereo can even use a 13-pin mini din plug. Does anyone have a 2001 and know the answer? Better yet, have any of you tried this? The iTrip doesn't work too well where I live, and I'd like to avoid the unsightly wire of a cassette adapter. Thanks!
Cristina
My other concern would be torque. Put 900 lbs of weight in both and the Forester's 166 lb-ft will much better be able to handle to load, vs. the 130 lb-ft of the Vibe GT or the 125 lb-ft of the base Vibe.
But go back to the basics, are you looking for a fuel mising FWD small wagon, or the all-around hauling/foul weather utility of an AWD Sport/Cute? Or even a sporty FWD sedan?
Sedans give up a lot of practicality. I've hauled a full-size clothes washer still in the box. See above, someone recently hauled a full-size dish washer IIRC.
I don't think the Vibe or Maxima could do that. Fork out $50 for delivery.
-juice
I used this setup for a few months and it sounded pretty good. The cassette adapter wire is tucked into the dash and barely noticeable.
My WRX had the DIN connector on the back, but I was unable to get it to work. Other people have reported mixed results. I ended up getting an Alpine head unit a few months later, which has a line-in which I use for my iPod.
Craig
Cristina
Someone like Pat would cut into the cover itself and use a heat gun to shape it nicely, I bet.
-juice
Having tried several things, I'd say have enough cable so that you can hold the iPod in your hand for adjustment. I try to not fiddle with it during driving, but find that I can make quick adjustments as needed.
Craig
Hmmm... cutting a hole into the compartment cover might work for the dock, maybe just the width of the iPod... That compartment's been empty for the 3 years that I've had this car. I ordered the Belkin TuneDok that supposedly fits into the cupholder but I'm prepared for the fact that it probably won't. I'll definitely want the iPod controls within reach. Though I suppose I could use the wired remote.
Cristina
Cristina
In my WRX, I ended up wiring a second cigarette lighter in the glove box and located the Belkin auto-kit there. When the iPod is not in use, I can just tuck the white cable into the glove box.
In my Outback, I actually took the Belkin auto-kit apart and hardwired it. The guts of the auto-kit are in a small plastic box tucked up in the center console near the shifter. So you can definitely get creative how you mount and wire these things!
My wife has an old-style iPod without the dock connector. She uses a cassette adapter in her 03 Forester, and is pretty happy (so I haven't inflicted any custom install jobs on her).
I agree, the FM modulators suck. I first used them in the late 80s, to connect Sony Discman CD players to car stereos, and they were horrible then too. Generally, the direct-wired ones have a clear signal, but you lose the highs and lows and the resulting sound is kind of flat.
Craig
I love the Forester for its versatility and cuteness. It is also more "me" - sporty, youthful, and practical.
The Maxima is exceptionally nice to drive, making it easy to imagine taking long road trips up and down the state (CA). And, for 80% of all driving that I do, I think I'll get more for my money with the Maxima than I would with the Forester. The Max, however, is really my father's Oldsmobile.
The more "me" Forester, unfortunately, is plagued by a lack of availability and high price tag in my area. Some perspective: there are exactly 0 with less than 30,000 within 40 miles of my zip. There are 12 within 100 miles, but the lowest asking price is $17,000 and the average is $18,500. There are 173 Maximas and they start at $13,900. I'm really aiming for $15,000.
It sounds like I'm really leaning towards the Maxima, doesn't it? I can't get over being a young, single, outdoorsy chick and driving a SEDAN.
It seems the Tribute would be a great alternative: it's also "me," and is very available and very affordable. I hesitate because of the road noise, which is annoying, and because if I pay the $$ for a mini-SUV, I might as well spend extra and get something with better mpg, AWD, and better resale. Except that I don't want to assume that much debt...
So, this is where I'm at. Thank you again for your comments, I found them very useful.
Happy driving,
JEG
Let me just say that when I was a young, single, outdoorsy guy, I would have definitely gone ga-ga over a young, single, outdoorsy chick driving a Forester! Maxima is more of a yawner car...
Now that I am a 34 year old married outdoorsy guy, I am only allowed to go ga-ga over my wife in her Forester! Though, I do manage to go ga-ga over my WRX a few times a week...
Craig
Edmunds might consider developing a Personality and Lifestyle Assessment Tool (PLAT) to match personalities and lifestyles with potential cars.
-Steven-
YES! I am dying to learn more about the personalities of those who actually shelled out dough to buy Pontiac Azteks.
http://classic.subarusdc.com/liberty/parts_home_page.cgi
And browse the parts catalog for your 02 to identify the part numbers of the brackets.
Craig
fitzmall.com is a local no-haggle dealer, they've had a few 2004s come in at under $19k. You get a 5/60 powertrain warranty so if you take on a 5 year loan you shouldn't be stuck with payments + repair bills at the same time.
Let's say you take a 3 year loan on that used Maxima, it'll be out of warranty before you pay it off, so in that way it's actually riskier.
My usual rule of thumb - don't make your loan longer than the powertrain warranty period. That way you don't get stuck double-dipping into your finances on any given month.
-juice
$19,309 for an X, auto tranny
That's new.
If used prices start at $17,500, well then, that's not very much depreciation is it?
-juice
Labor they are billing me 2 hours for "sheet" metal repair at 64.00 total and then 4.3 hours of refinish work at a total of 137.60. Total repair costs would be 491.10
Would like to know opinions of this estimate. I did go to Kenwood autobody in Germantown and they were higher.
This is for a 2004 XS forester premium
-Frank P
Anyone here have any experience with installing an antenna amplifier on an '03 Forester XS Auto? We've got a great classical station across the border in Tijuana (XLNC/90.7 FM) but it's power isn't too strong. I'm not into satellite radio because I like to get local flavor as I travel around, but would like to get a stronger dose of it. Any suggestions?
My Polk 5 1/2s and 4 inchers in the front and rear doors, respectively, are doing great with the tweeter kit I installed. I was really surprised to see how pitifully cheap the paper- coned stock door speakers were when I replaced them - and how much better the present setup sounds. Don't let anyone talk you into an amp; the stock receiver is just fine for all sorts of tunes, although installing an RCA plug kit when you do the upgrade will guarantee better sound all around.
You could get a bumper from a wholesaler, I think they run about $125. That would save a bit, but it might not be worth the trouble.
-juice
No amount of utility is sufficient to outweigh its appallingly bad styling. One of the two or three ugliest vehicles of all time.
-Frank P
Greg
If he's considering the Element, let's go ahead and disregard styling because he must like it, and styling is subjective anyway.
I like it too, FWIW. I do think there are drawbacks you need to take into account:
* just 675 lbs payload (very easy to exceed)
* seats only 4 people
* front seat belts anchored to rear doors
* part-time only AWD
* gas mileage only so-so
If you read the May 5 Autoweek, they did a long-term wrap up of the Element. It was one of their cars that accumulated the fewest miles, and they complained loudly about the inconvenience of having to remove your seat belt every time you open the rear doors.
With that in mind, if you only carry 2 people, and often have muddy bikes or plants in the back, or carry small trees or grandfather clocks that can stick out that rear roof, then it's the cat's pajamas.
The Outback is a lot more conventional. Permanent AWD is better, IMO. Payload is 900 lbs, usefully higher. The rood rack can hold 150 lbs IIRC, and it can tow more than the Element can, too. HP and torque are slightly higher, and overall I think it's a little more substantial feeling. Plus you get 3 years of roadside assistance (zero for Hodna) and 5/60 powertrain warranty (just 3/36 for Honda).
Trade offs? It's the outgoing model. That can be bad (it'll seem old) or good (it's proven and kinks have been worked out). Everybody has one.
The Crew will help take care of you if you get the Subie, I'm sure you know that.
-juice
Wow Juice, that's quite the command of the American lexicon. Next thing you know you'll be saying it's "the bee's knees" :-)
-Frank P
John
Put in 3 200lb guys and you can then get what a few cases of beer with you?
-mike
The DX model is stripped, but the EX isn't that way. 4WD models get the rear roof opening.
-juice
Acura used to fair a little better, until they brought out the ridiculous looking RSX to replace the somewhat "cute" Integra. I think the sales are down 80% on that model. Bu then again, what to expect when a car is shaped like a door stop...
Element gets noticed, you can't argue that.
-juice
-Frank P
I wouldn't agree with that at all, even though I'm probably the Element's harshest critic. I think most Hondas have been at least inoffensive and in quite a few cases quite good looking. The earlier Civic SI squareback 2-door was great looking and highly functional. Its successor is still attractive. The 2nd or 3rd-generation Prelude (I forget which) was a stunner from every angle. Various Accords progressed from fair to quite attractive through the generations.
Then comes the Element. The shape is bad enough, but those gawdawful primer-colored fenders are simply atrocious. Did Honda fire every stylist and hire a 3-year-old to replace them? Or did they all start ingesting psychedelic drugs? There is not one single appearance aspect that I find even remotely acceptable. This unfortunate trend to separate one's products from the sensible pack by intentionally uglifying them is not something to be encouraged.
Our Foresters take a bump at the same speed, mine is much more likely to be undamaged than your painted-bumper XT.
-juice
