SUVs and Smart Shopper
On a side note, I had no idea the 2011 was out.
So if I were you I would fight and get it fix asap. Good luck.
However, it is still quieter than my Pathfinder!
I was experiencing a vibration that would begin at 30mph and 70mph in the steering wheel and seat, not to mention tires chopping at 12,000 miles. After numerous dealership visits, three sets of tires, new drive shaft, new brake rotors at my expense the problem still exists. the most troubling aspect is hondas lack of interest in resolving the problem.
I must have missed the small print in hondas brochure, stating premature tire wear, vibration and brakes are characteristic of the vehicle.
After 10 months of frustration in dealing with Honda, performing at the highest levels of mediocrity, I have resolved my vibration problem with a FX Infiniti purchase.
Also, anyone had the rust problem on the surface paint of the trunk door. I have called the dealer to ask for warranty on the paint. He told me Honda have no warranty on this rust problem. This car have given me a lot of problems.
I plan to file another complaint with Honda and perhaps the BBB. Rotors should not be bad with this low mileage.
Any tips for dealing with Honda?
My issue: car would not start but light did come on some which indicated issue. Jumped it without problem.
Bought new battery and went to install it and found the positive battery connector was corroded. So called around for positive battery cable and only two dealers carried it and they were in Midwest or California and it would take 3 days to arrive and cost 110
I got the positive cable part from online at parts now.com or something like that overnighted for less than whAt dealers charge for the part
Service center not Honda dealer cost 275 for labor to replace battery and positive cable. They also found. The positive battery cable connected to alternator was also corroded (there are 3-4 cables that come together on the positive battery cable.
After replaced worked fine. It also temporarily stopped the vibration between gears caused by the Eco system. Seems having the computer reset helped that for a few weeks but it is now back.
Hope this helps
Did you get an idea of cost from the dealer to replace your leather?
KK
The only solution is to either turn or replace the rotors.
Good Luck.
Well, hello Honda.... where is the recall on this? Oh anyway.. don't know if this is your problem, but you may want to check. It is for my car!!!
when opening the back cover, note how that cover fits into the remote so you know how to close it back up. pretty easy.
i did finally have to replace the battery after 2.5 years.
