Subaru Forester (up to 2005)
I have almost every accessory in the catalog, it's hilarious. Too many to list, honest.
-juice
Scott
Again, thanks,
Scott
-Frank
Scott
Also in NJ, we can't pump our own because the attendants are 'supposed' to be trained on how to deal with a fire, should one occur. (Good idea, but I have asked a few kids in stations and they haven't a clue...Not their fault directly).
As far as early shutoff, there was a Subaru problem in the 2000-01 cars (ALL SUBARUS), where the 'vent valve' was not opening all the way. When you insert the nozzle and open the small flap in the filler, it opens a valve which vents the tank fumes to the charcoal canister to be stored during fillup. After restart, the fumes are the passed to the engine to be burned. On some this valve was not opening, consequently the pump would shut off continually. There were stories of 30 minutes for fillups. If your still under warrenty, I would have Subaru check it out. Some mechanics may not evevn be aware it's there, unless they have dealt with it.
Oil drain plug if Std Right hand thread.....'leftie loosie.....rightie tightie'
Spark plug torque 20.6 Nm , 15 ft-lbs (manual also states without torque wrench, finger tight until gasket touches (hard to see that one), then 1/4 to 1/2 turn with a wrench)
I think some plumbing is an exception to that rule, but I've never seen a bolt on my Subies that were not that way.
Try a 17mm socket with a long shaft driver.
-juice
Sounds like job security to me...not that there's anything wrong with that... But I know how to run too.
Kavoom
Chuck
---Mike Savad
You can peel off the plastic protective coatings and give it a wash can't you??? That should be the first fees negotiated away... They might as well call it "free money" for us because you (as a customer) don't know any better.
Ranks right up there with document fees (they have to fill out all those papers anyway and why not get you to pay the Secretary's salary). If you could get someone to pay you for breathing wouldn't you? And when they give em up easily they can point out how big a favor they have done for you and then they are right where they wanted to be in the "real" negotiating process with you at a disadvantage thinking well, they have already given up that money... There is less of this nowadays, but it is still there. Remember the Saturn commercials saying you pay for what is on the sticker, no negotiating, no "hidden" fees etc. That was originally to counter this very strategy.
And at the end of a model year, they shouldn't even bring em up you would think...on the previous years left overs.
You will note some of the best deals you see on these boards never mention these fees.
Other
I am glad I got a 2004 Forester (2005's also) and like the looks over the 2006's. I prefer my straight "unpainted" plastic on the bottom and the gray back panel and side support panels. No dings of any sort yet in the parking lots (knocks on wood). I like the front end looks better also. Less "refined" and more scrappy looking.
My dealer noted they were unimpressed by the extra 8 horsepower in the 06 Foresters. They say they don't even notice it and were surprised because there was a 3 or 4 horsepower increase a few years ago that was distinctly noticeable.
fyi, (after market parts)
The LL Bean "self levelling" rear suspension is ALL in the struts (thanks to others informing me of this). You can buy them (not cheap I hear) if you tow a trailer. I am also hearing here that the "much vaunted" filter system is already pre-installed on Subies with no filter in the housing when not on the sticker and you can buy and install yourself...??? Subaru's have a "tow package" (wiring harness knockouts etc) pre-installed. Why don't they advertise it (in the U.S.) That saved me over a hundred bucks to the surprised hitch installers who had never done a Subaru. They said it was one of the easiest they had had to do and became interested in Subaru as a tow vehicle noting someone had obviously considered it for that purpose.
And why does Subaru NOT offer a manual transmission in the LL Bean when it is obviously oriented more than anything else toward towing. You lose towing capacity with the automatic transmission while you have items like self-levelling rear suspensions which are obviously towing oriented and standard on Australian versions of the Forester...along with two stage manual transmissions. They tow a lot and rated the Forester as the best towing vehicle (2004) over roughly comparable vehicles including bigger ones.
If I have misspoken anywhere here, please enlighten and/or correct me.
Kavoom<checks the balance in his checkbook...
Kevin
I'm contemplating taking our 05 Forester back to a particular 4x4 trail that is technically rated from 4 to a 7. Last time we went there were a few deep ruts where I gently scraped the front plastic protector beneath the engine block. There appeared to be no major damages from rocks, aside from a few small scrapes on the surface of the muffler.
Any suggestions to further protect the car? Does the rear differential plate protect enough? How is the front differential protected? Any suggestions on helpful modifications are appreciated. Obviously, bigger tires and raised suspension will be great...or renting a Wrangler but they're asking for $130/day!
-juice
Now, maybe there was no damage to the engine, in spite of the blue smoke I saw. But the car has been driven over 800 miles with oil overfill, and the dealership completely refuses to accept any responsibility. All maintenance has been done by the book, at that dealer, Subaru Beechmont. I think anything above the notch is overfill and should be documented as such.
Since I might be looking at expensive repairs down the road (I agree that the risk is small, but the potential repair cost is high), caused by the dealer's negligence, should I pursue this further (BBB, Attorney General)?
Daniel
Thanx in advance. Pert
And find another dealer!
-juice
MSRP: $ 25,929.00
COST: $ 23,787.00
this is with a rebate of $500 - for a 2006 subaru forester, with auto, and premium. buying it in NJ. another place had it for $200 less, but so was their MSRP. one site showed it to be that much more as well, they stated it was an AD fee of some kind, and not everyone shows that kind of info.
so does anyone know if it can be lower than this? or do i have a good deal now? i'll try for the lower one anyway, but i'd just like to know. thanks.
---Mike Savad
Question is.. they had an extended warranty (not the Subaru one) for 1,895. Sales Manager said he could write down that it would be refunded if not used (less 200 bucks processing fee). Is it worth it? I said no since its over 20% of the price I paid and the Forester is going to be the spare car and the bad weather car.
Smart move to decline? My 01 Forester was pretty reliable. What trouble spots would a 99 Forester have?
With the car now well broken in and using Mobil 1 at 5K intervals, along with tire rotations, I'm happy to report my MPG is in the upper 28's 80/20 highway-city. This compares to the mid 27's I was getting this time last year. No doubt this is optimal and will unboubtedly decrease with new tires and the advent of stink gas this fall.
We recently purchased an 05 EX CRV after our 98 Taurus was rear ended and totalled. Thought you all might be amused that the wife disregarded my initial suggestions about getting an Outback for a replacement because see didn't want a "station wagon" and a name that reminded her of the little house outback .
Have fun all.
99s had some head gasket issues, but you can replace a head gasket for $400-600 so even if *both* fail you'd spend less than that warranty costs.
Besides that there were wheel bearing issues, rear only, that would run about $600 or less, each.
Worst case scenario, if all 4 failed you'd spend about the cost of the insurance policy, so I'd say no, it's not worth it.
-juice
John
Actually, it's Island Beach State Park in NJ. Not to be confused with Long Beach Island, NJ or Long Beach, Long Island, NY.
Air down to at least 15 psi's on the stock tires. I would probably go down to 12-13 on the rears to be safe (you can go lower on the rears because you don't have to worry about the engine underguard).
If it's dry and there are a lot of people on the beach that weekend, the sand will be deep but you should be fine. I would head all the way to the very last parking lot/4x4 entrance because the sand north of there is looser and deeper. I've never driven an auto there, but I used to drive my OBS there. I used to get stuck until I started airing down to under 15 psi's with that. With my 225/55/17's I only need to go down to 16-18.
Make sure you have your list of required items (shovel, tow strap, rod/reel for each person over 12, board for jacking, etc.). Keep it slow and steady. Also watch your speed on your way back to the air station. Cars dart out from the parking lots and you don't want to have to swerve when you're running low air pressures. Check out the Subaru Crew - pictures section. I think I have a couple of pics there.
If you see a silver FXT, with tinted windows and 17" wheels/tires that'll be me.
-Dennis
Funny thing was an F-250 that forgot to air down got stuck while I was there.
Drive smoothly, follow the tracks already established, and don't stop on soft sand.
-juice
I cant find same.any advise please.
I have a 2003 XS Premium I've lurked here and on a couple of the other Subaru boards for a while now, but I had to join to rave about the new tires I got yesterday. Based on Consumer Reports, and the positive reviews here, I now have 4 new Falken Ziex 512's! I never would have said the OEM Geolanders were bad, especially after 45000 miles, but seriously, I feel as though I have a whole new car -- quieter, smoother ride, and definitely more responsive through highway ramp corners -- the limit of my handling demands thus far. I'll report later on any change in gas mileage -- I had only driven 50 miles on after a fill-up before the installation.
BOB
PS: I know 45k in 2 years is a lot, but relocating from MT to DC accounts for more than a few of those, plus we're a one-car family. The Forester replaced a 1985 Honda Accord with 195k miles, so I figure the trusty Forester will be around for a while yet.
I have never "disliked" the Yokos, and the cheap side of me says rotate the spare in and buy 3 new ones. But, 3 new Yokos are about the price of 4 new Falkens, and if there are all the additional benefits, I am leaning your direction too.
John
My '01 L turned 110K on the trip from the Chicago area to Ft. Collins, CO. The average uphill mileage was 23.2 mpg. The return trip averaged 23.76 mpg. There were three people in the car and luggage.
The average outdoor daytime temp was over 100F so the AC was on continually.
The lowest recorded tanks of gas were burned at 22 mpg. One of these was used to drive from Nebraska into Wyoming and then Colorado (all uphill). The other was from a leg my wife drove and she likes to drive a little faster.
The best reading was 24.87 mpg.
I wish I could send you a picture of my Forester parked at +12,000 ft but I didn't drive it into the mountains. Instead, my daughter let me drive her brand new Outback. After mastering the Old Fall River Road in Rocky Mountain National Park (and grateful to be in a Subaru the whole way) I advised her to get the skid plate.
BTW, is there any city in America with more Subies than Ft. Collins?
I ignored the light--if there was a real problem, it wouldn't go off the next day. It didn't affect performance in any way that I could detect.
Maybe it has something to do with the type of gas pump.
CEL: hard to say now that the codes have cleared. If you have an ODB2 scan tool it stores the codes. Also, some AutoZone stores will scan it for you for free (and of course try to sell you parts afterwards).
No biggie, probably a single misfire or a vacuum leak in the fuel vapor recovery system. Light would stay on if it persisted, blink if you had to stop.
-juice
John
When you consider that nation-wide it's just 1.1% or so, that's amazing.
-juice
John
When you handicap for all the pick-ups in Colorado and considering that there are more of the Subie-type people (named Dave?) in Ft. Collins than you might find in, say, Colorado Springs, I wouldn't be suprised at 10% for that part of the state. Naturally I'm inclined to attribute the phenomena to superior intelligence. I'm convinced that some day, when my car finally dies, its' spirit will go to Colorado or Alaska. Maybe the ghost of my smashed OB is already there.
It seemed, as well, that there was more local advertising by Subaru dealers than one would see in Chicago.
Thanks, Juice for confirming the lack of gravity to the CEL situation. I hadn't know about the flashing CEL, but I think I would stop the car if anything started to flash.
One more thing, since I was reminded of my old OB, I had taken the crossbars off the roof rack to better fit a luggage carrier and they were still off when the car was totalled. Is there anyone out there who could use a pair? I will give them free of charge to whoever has the best story.
If I were in the market for snows, I would consider the Nokian WR's. They're the only all season that gets the Severe Service Emblem that snow tires get.
-Dennis
