Honda Civic Clutch Questions
wsustudent
Member Posts: 35
in Honda
I have a 2003 Civic EX 2 dr. coupe with 76,000 miles thus far. I've been having some issues with the clutch making a lot of noise when depressed/released, like a creaking sound if you will. This happens intermittently but frequently. It does not seem to affect the performance of the overall vehicle or transmission. Has anyone else had this problem and know a fix for it, or if it something I should really be concerned with? I don't want to have to take it to the dealer if it's really not going to ruin anything. This has been happening since about 39,000 miles (of course right after the warranty expired). Thanks in advance for any inputs or similar experiences.
Good Luck :lemon:
I was told that the problem comes when one rests their foot on the clutch while driving, keeping the plates(?) only slightly apart.
He pointed out that I had to have my clutch replaced at about 120,000 miles and he has never had to replace his -- coincidence? Or could he be right?
G
When the clutch is out, the throwout bearing is not normally engaged nor are the ball bearings spinning. Unlike a wheel bearing or engine bearings which are made to handle a lot of pressure and spinning all the time, these aren't. With you sitting there with the clutch in, you are forcing those bearings to engage and spin. If it's a long time in traffic, put it in neutral and let the clutch out.
When you have the clutch in, and the transmission in first gear, then you know you are depending upong the clutch to slip (since you are in 1st gear, but you have the brakes on and don't want to move). There isn't a whole lot of pressure on it however. You get more wear when you are actually letting the clutch out wanting the car to begin movement. It's overcoming the inertia of a stopped vehice, and getting it to move.
Friends right, let the clutch out in neutral.
I always feel safer in gear because I can move fast if I need to.
My mechanic said it's OK to keep the clutch in with the car in gear at a light as I do, but my friend was not buying it so I posted here.
Anyone else want to weigh in?
I'd personally be more worried about the throw out bearing, than the incremental wear of the clutch plates.
It's your car, if it makes you feel safer doing what you are doing....continue doing so. Worst that can happen is that you might have to do a clutch repair service earlier than someone else, thats not the end of the world...it's only a car.
I'm relatively new to driving manual transmission, with about 2-3 months of experience. I was just wondering if there are any bad driving habits that I am using. I wanted to know if it's recommended to hold the clutch in without the gas when I am cruising around corners at a low speed. Also, I am not sure if it's worse to downshift to a stop or to just pop it in neutral and cruise to the stop using the brakes. On that topic, though, I would like to know the proper way to downshift. Thanks.
I believe my head gasket is also blown so would that have anything to do with the clutch? (sorry I don't know very much about cars)
