Jaguar XJ-Series Electrical Glitches
Mr_Shiftright
Member Posts: 64,481
Any stubborn electrical issues on your XJ that you'd like to ask about? Post your questions here:
i am a woman who needs help
Manuals you can buy from Ebay.
I bought mine for $36.(the whole leather binder with all the manuals)
We had windows tinted. There was water dampness inside car from process.
On way home, one window automatically went down anf the steering wheel moved.
Returned and dealer said it would be okay when it dried out.
Today it is still doing these things.
Has damage been done? If not, what should or can be done?
Taking it back tomorrow to dealer.
Appreciate your direction.
battery drains down over-night. belts squeal when first started each morning. battry (amp) guage shows charging.
eventually goes away after driving.
FIN control module has been replaced??
belts are new & tight.
Five chimes five times.
I have a light out on the rear-deck light.
Could this be it?
Help !!
If the clicking you hear is deep with the door, and a heavier mechanical clicking, then I would say (like skipping teeth on a wheel, a sound you can probably feel with your hand against the panel) ) that your window regulator is broken and that there is no relation to the sunroof.
Visiting Host
PLEASE tell me that you found the (an) answer to this problem with the blowers. I have the exact problem just as you described it and as a result I have no a/c in my 1990 Jaguar xj6. Local dealer is no help and wants a fortune to just diagnose the problem.
My problems are: 1. The ignition switch does not activate . 2. Seat does not automatically adjust to set position when car is cranked. 3. Doors lock and then immediately unlock when the plunger is pressed. To lock doors, it is necessary to use the key or the FOB.
This guy only has a few hours left before I hang him from the highest tree. Thanks for you help.
I did work out my problems, I change the front right door module. This module is the main brain for all of those items. Was a bit costly, over $300.00, easy to change. Make sure you get one with the right code the dealer can not reprogram the module. The code can be found on a sticker under the trunk matt on thr lift side, it will start with DDM ######## and don't buy a use one I tried that and just wasted money. Hope this works out sounds like the same problems I was having
Will the battery cause everything to go fritz on the car...?
1) doors won't lock when pushed down
2) interior lights stayed on
3) seat won't set properly
4) **and it won't start...
Also, mechanic replaced the back door module w/ a used part that he swore would work. This guys been there for 26 years and I thought he might know what he was talking about.
Thanks, guys...I'm about to lose my rosy disposition over this.
Now, same problem again. Cleaning module did not solve problem this time. Questi
on:::: should I replace the module??? coil??? other???
Other info: Starter turns over engine briskly. "Occasionally" I can get it star†ed by topping out the battery charge, and putting a battery booster on it, about 1 in 4 attempts. Runs great once started. (Until next attempt to start). Comments appreciated.
When I said it won't start - everything lights up when the ignition is switched on, but when I turn the key all the way, nothing happens. I mean nothing. No sound at all, no engine turning over, no starter sounds, not even any clicking of relays. Absolute silence. Is it the GEM? Will it cost thousands of dollars? Can't we just cross a wire somewhere and bypass all this electronic crap?
Deadjag
It will be interesting to try disconnecting the battery though and let the computer reset. Thanks for that one.
This a '93 xj6 VP
Anything some can shed light on to check?
Jim
Now the window on the driver's side not working. Mechanic said he worked trying to get the window to work but no luck...wants me to purchase a new motor for the window. The window worked fine until the new handle was put on.
Just read on another forum where someone else had the same problem but there is no response to this issue. Any ideas out there? Would dearly appreciate your information!
Missmaryquinn
If you want the best XJ6 of that body style, 85-86 could be a better choice for you since they have fuel injection, not old-fashioned carburetors. Better gas mileage and cold starts.
Hope this helps
Kenneth
kbeerden@bellsouth.net
Diconnecting battery did nothing for me,I solved my problems with changing the drivers door mondule.The correct code can be found in the trunk ,under the carpet, driver side. I tried to go cheap and buy used,Waste of money. Recommend to buy new, not cheap about $300.00. hope this helps
Kenneth
