Jaguar XJ-Series Electrical Glitches
Go ahead - great car. The later 2003 onwards is even better, but watch out for paintwork bubbling on early (2003) ones.
Just registered after reading all of the posts on this topic. I have experienced most of them already on my '99 XJ8, including the headlights going out at night, and most recently the driver window not rolling down and also the sunroof closing on it's own after opening it. OK, I did have to get a locksmith to tear into the driver's door panel recently to read the key code to make a temp to open my trunk with the key left in it while at the fishing pier changing clothes. Oops! The window problem eventually corrected itself after about 3 weeks of driving with it shut surprisingly. Now I have a major problem after returning from a NC mountain river tubing excursion this past 4th. of July weekend. The car did great all the way there and back from Raleigh, and then the throttle stuck as I got in town and I had to hit the brakes real hard to get it to stop before plowing into another car at the first traffic light. Ugh! The car stalled and hasn't run since then. My now disappeared mechanic had told me a year earlier the throttle controls looked like trouble down the road and he was right. Good man, but can't find him now to deal with this situation. After walking to work for the past 2 wks. only a mile or so away, I decided to purchase a backup '97 XJR with low mileage which I will finalize on Monday. Sweet! No problems with it that I don't know about yet, but stay tuned to this channel for updates. OK, so now I was also previously wondering if disconnecting the battery cable would possibly reboot the entire computer system's monitors in case they got freaked out by the sudden stop I had to make on my '99 XJ8. I saw the fail safe mode light flash on just before it stalled in any case. It knew it was in some sort of predicament, but maybe over reacted. Any ideas or clues around here while I continue to search for a new mech to work on it?
Cheers,
Jagzilla
Goodkitty
I am not sure I ended up replacing the whole wiring harness on the drivers side. This solved a lot of problems, very expensive but now it all works. not sure if that helps or not. If you want a harness try car-part.com they are a salvage yard type thing and you can put in what you are looking for. With the jags one bad wire and the whole car is NFG, Good luck Brian
CAN ANYONE OFFER SOME HELP?
Goodkitty
:confuse:
Have you check the brake light switch itself for loose wires, etc? I'm not sure if yours is brake pedal activated or master cylinder activated (mechanical switch or hydraulic pressure switch).
- Scott
2005 JXL
maybe www.johnscars.com
also some guy splitting up XJSs petroske@tds.net
www.vintagejag.com
www.jaguarsouth.com
I've never done business with these people, so the usual caveats apply.
