Honda Accord Hybrid Tire/Wheel Questions
Discuss Accord hybrid tire and wheel questions and problems here
I am a newbie and would like to thank you for all that I've learned about the HAH.
I now have a 93Civic and plan on purchasing a HAH in the coming months. What I have not really heard about is the spare tire issue. Does anyone know if the dealer will provide you with a spare? I believe there is a space for it.
Thanks again,
Bugsndaffy
If I decide to get a hybrid, I don't think I will be too concerned about no spare. I will probably look for an extra rim at a junk yard and get an extra tire mounted on it to keep at home. Then worst case - I get a hole in the sidewall or fast leak I can put it on the car. Maybe for a long road trip I might toss it in the car, but probably not.
AFAIK, there is no place (except using up trunk space) for the spare in a hybrid.
Dennis
The Hybrid does indeed have space for the spare tire without taking up trunk space.
The "tool caddy" which holds the jack, compressor, sealant et.al., is removed and the stuff put aside, revealing the area where the spare is bolted. Included in the "wheel kit" box is another caddy that fits into the spare complete with spots for the jack and lug wrench and jack handle. There is a picture of the setup under "spare tire/ Canadian " in your owner's manual. The cover of the trunk bed closes up flush just as before.
NO trunk space is taken up. You do have to stow your compressor and sealant in the garage though.
thanks!
I am just wondering if I need to buy anything else.
Any thoughts if a maintenance issue is causing the rear tire cupping issue? Has anyone bought replacement tires they might recommend?
Handling has improved a lot, especially in rain. Those Michelins were lousy.
Only diadvantage is that mileagehas suffered a little. I don't mind because the car feels a lot safer now
Sorry for the answer more than 5 years later. You can buy rim and spared tire at a tire outlet. Honda dealers do not carry those. Remove all those sealant, air pump and "big black tray" you will have a space (with bolt) for the spared tire.
