Subaru Forester (up to 2005)
-Frank P.
Ed
Len
Ross
-Frank P.
Bob
Ross
Drew
Jeff
I would agree with you about the wonderful visibility..I traded in a Honda and it's a whole new world with what I can see.
Ron
s
joe
My average MPG is in the 25-26 range on my normal commute (65%hw, 35%city). On a 300mi trip, with 4 people and gear aboard, I got 29.5mpg. I have gotten as low as 21 during cold winter months.
There are some others on this message board that have complained of mileage worse than yours. Dealers tell them it's normal, also.
One of the main reasons why I bought the Forester was for it's mileage - I would be disappointed if I could only achieve 20mpg.
-Tony
Your milage sounds a bit on the low side, but may not be completely out of bounds. The EPA sticker figure is based on very ideal conditions. I don't remember exactly how they do it, but it's something along the lines of driving at consistent 55mph on flat ground.
Lots of factors can affect your gas milage: What are your tire pressures set at? The recommended pressure by Subaru tends to be biased towards comfort. You can get better handling and gas milage by increasing them. I use about 32 psi all around. Do you drive aggressively? The boxer engine loves to be pushed, but you do pay a penalty in gas milage. What type of gas do you use? Our engines are designed for 87 octane. Using too high or too low an octane can hurt fuel performance.
Also, your Forester engine is still new at 8000 miles. I saw my gas milage average improve by 1mpg over the first 30K miles or so.
As for myself, I own a 98 Forester with a manual tranny and average about 24 mpg with 90% highway driving. My best tank has been 29mpg and my worst, 21mpg.
Ken
Any other suggestions/comments?
Tamara
Judy: Contis sound good. Hope they do last. 80k miles? I'd be impressed if they actually do last that long.
Jeff: 20.6mpg is a bit below average, but definitely within normal variations. If you bought in February it's still new and not yet fully broken in. I get about 2mpg better now than I did in my first year, so hope for 22.6mpg, which is about right.
-juice
Ross
Also, are there any subaru forester owners in california participating in rallies? I was thinking about going to an entry level one just for fun, but don't know where to start. I just want to find some dirt roads to drive on, anyone know any good places to go in northern or southern california?
I have some pictures i want to post, i'll try and figure out how to put them up. thanks
forester owner
2001 S+
25,000 miles since november
avg 24-25 mpg 70/30 highway/city driving
K&N filter
possible 18 mm swaybar upgrade in the near future
uh..that's about it
Steve
Tires? I'm not 100% sure that 225/60s would fit on the stock rims. I have that size tire, but my offset puts the wheels 15mm further out from the body of the vehicle, to allow clearance for the rear spring base.
On the 15" rims, I've heard of 215/70, 205/75, and even one case of a 215/75 tire fitting. Keep in mind there may be variations from one manufacturer to another, so just because one fit does not mean another will.
For stock 16" rims, some 225/60 tires could rub the rear spring base, some may not. 225mm is the section width, not the tread width, so it will depend on how the tire is built (square will rub, rounded will not). I'm guessing, but you could probably squeeze in a 215/65 tire in there, maybe.
If you want a little more room, though, do what I did and get a different offset. My rims are 16"x7" wide, while the stockies are 15"x6" or 16"x6.5". The 225/60R16s fit, but 235/60s would probably begin to rub at the front mud guard. Of course you could trim it back, remove it, or use a heat gun to mold it, but then you're getting into customizing it a bit.
Another consideration is gearing. A much taller tire will give you taller gearing, and you definitely do not want that off road. You lose major leverage, and effectively, torque.
Instead, consider slightly taller tires and get a lift. You can get taller springs for about $400 a set, and get a 2" lift.
You could even go a step further and get a lift kit. That give you another 2" for about $360, but with a 4" lift you'll have some teething issues with your transmission that is common to the Aussie boys.
Stock clearance is stated at 7.5", but it's closer to 6.8". My tires gave me at least a .75" lift, don't ask me how, I just measured. Maybe they deflect far less. The math didn't explain my results. So I'm up to about 7.5". Toss on taller springs and you've got a very capable 9.5", and a vehicle that is still manageable.
If you go beyond that, you could get to 11.5", but at that point you're really sacrificing driveability. That would be a beast in a big way.
-juice
I took the Forester back to the dealer today because after the new Aqua Treds - 30k service and a 4 wheel alignment I've noticed a slight pull to the right. Plus, the car feels "nervous" on the highway. They confirmed the alignment is ok and the tech. said he thought it was "radial pull". (Pulls to the right stronger when power is applied.) I've never heard of this .. He said normally he would switch the tires (side to side) but couldn't because these are directional.
Kinda sounds like a load of bahwanna to me. You guys heard of this before?
- hutch
Was it pulling before? If not, it was something they changed.
-juice
The Premium S rear track was widened in order to compensate for the weight of the huge moonroof. I think it's more than just the offsets, but not 100% sure.
Hutch -- I have heard of radial pull and the rememdy usually has been to try swapping sides with the tires. Not exactly sure why it occurs, however. Are the tires brand new? If so, the "squirminess" may just be that they haven't broken the mold yet. If all else fails, I'm sure Goodyear (?) has some kind of warranty.
Ken
I just put a set of Goodyear Aquatred 3's on my wife's 2000 Honda Odyssey van. They are unidirectional, so they can only be rotated front to rear (and vice-versa) on the same side. If you look on the sidewall, you'll see an arrow showing the rotation direction. I haven't noticed any more torque steer on the Odyssey since I got them last week, but the steering feels a bit more "positive" compared to the Firestone Affinity's it had before. (I don't know if the previous generation Aquatreds are also unidirectional).
Len
Thanks for the response. Yep, they're new "3's" and no it wasn't pulling before. It's difficult to assess blame when several new things happened at the same time. New tires .. new alignment all within a couple of days.
I'm gonna check Goodyears website to see if they can provide any insight. Thanks.
- hutch
--'rocco
Kate - I'm in your neck of the woods on a business trip. My rental - Mercury Sable! My poor OB is at the airport. Can't wait to drive her again....and wash her as my apology. Kinda like buying flowers for my honey after I did something stupid. :-)
Greg
Jack: if you floor it, that's normal. It'll rev all the way to redline, which is fine if you need maximum power. There is a rev limiter that will cut off fuel to prevent damage to the engine, and most likely the tranny would shift a bit before then anyway.
To shift sooner, ease off the gas a bit. But don't be afraid to rev - the engine is designed to safely go to redline (but not beyond) on a routine basis.
Though Greg is right - try to take it easy over the first 1000 miles. Once isn't going to kill you, though.
-juice
- hutch
ps - I should just restrict my driving to the WRX and .... nah .. never mind.
- hutch
thanks for the feedback. I was thinking about a slightly larger tire to give me just a little more ground clearance without having to lift it. i know this will affect handling, which is why i was also gonna get a 18 mm sway bar. As for the taller gearing, i know it'll be a little slower at the low end, but may improve my gas milage since i spend most of the time on freeways.
hutch - had the same problem with my car, a slight pull to the right. but it seemed to disappear when i rotated my tires. Did they replace your tires before or after the 4 wheel alignment? If they double checked the alignment, I think it might be your tires. try switching the tires side to side temporarily (don't keep it like this) and see if that fixes it. then you can narrow down the problem. maybe try putting on the spare on each wheel one at a time if you have a full size spare.
Topic: July 24th: "What is the stupidest thing you've seen someone do while driving?"
Ross
I saw something on MotorWeek that was interesting. Newer shops have a treadmill-style machine to balance tires that actually puts a load on the tire itself. It could be worth it to check if they have one of those.
Most shops just use a cheaper machine that spins the tire and balances the weight only. The newer ones make sure none are out of round as well.
-juice
The treadmill thing sounds cool but I wonder how compatible it would be with our AWD transmissions. You probably could only put a MT Subie on it if the treadmill spins all the tires at once. I don't think you could do it with an AT Subie.
Ken
Frank
"This is possible...You should contact the people you bought the tires from and this sounds like a warranty situation..."
Well, ok, not exactly the words of wisdom I was looking for but they did provide direction. So, radial pull is for real. What the heck it is ..I have no idea. None of the major tire mft's websites offer any insight (of course, that's like asking Oscar Myer about rat hair). If anybody finds a sourse of info on the subject, I'm interested.
- hutch
http://www.geraldstires.com/Services/alignmnt.htm
bit
refers to as "conicity". Comment anyone?
Ross
Frank
