Ford Ranger Engine swap
I have a 1990 Ranger, Extended cab,5-speed, but motor is messed with high kms. Just woundering if a 2.8 carbuted would bolt in my truck and if i could use the same wire harness. Right now there is a 2.9l fuel injected
Both vehicles are ranger pickups GF
kcram - Pickups Host
The discussion you want is 2007 Chevrolet Silverado/GMC Sierra: First Impressions. Remember, you can always use the make and model search boxes in the left margin to find the discussions for the vehicle you're interested in.
Complete wiring harness[not compatible]
Exhuast manifolds and type and size of exhuast pipes and muffler.
Motor mounts and transmission mount, and drive shaft. I'm not sure if the ring and pinion in the rear end is compatible or not.
PCM-Power Control Modual. Its an on board computer consisting of a computer board, and ECM [electronic control modual]. Primary purpose is to take in sensor info and control spark, injection pulse, fuel pump power and to monitor emission related componets. It also makes timing decissions, pulse width decissions for injection amoung other adjustments that are measured in mili seconds. Your talking about decissions made at about the speed of light.
You will also have to make a lot of other modifications like on how the fuel lines connect up ect. You may also run into a problem if one of the motors is designed to work with ABS brakes due to a harness and compatibility issue with either of the vehicles. Some Ford models have 4 wheel ABS, some have 2 wheel ABS, and others have no ABS. Your in for a lot of work. Good luck. It would almost be easier to change over the bed, doors, hood, fenders and interior than to do this type of motor change. Either way you decide to do it, its going to be some work.
The exhaust isn't a problem, I do exhaust. I went out yesterday and scoped out the motor mounts they appear to be the same, not sure about the tranny and I knew I had to switch the computers and yes a whole lotta work ahead. You did say one thing that I'm kinda weary on.. . . the ring and pinion. BUT . . . can't I just switch the rear ends since I have two complete trucks?
Doing the computer work does suck . . . its been awhile but me and a friend did a real nice job on switching a 350 to a '89 Toyota Supra. Really awesome car now. It was computer swap and all of course. . .
I reckon I just needed someones 2nd opinion on this. . . . I appreciate the input alot! Thanks
Any Ideas on where I can grab a Wiring Diagram for the PCM?
As for the wiring diagram, you won't need one. You will be using a factory harness that has plugs that will only plug in to the right thing. Its all plug n play. Just mark the plugs as to what they are connected to incase you run into a confidence or memory issue. Here is a tip. Use a numbering system to identify the plugs, and write what they are for by the corosponding numbers down on a piece of paper. This way, if you don't know what something is, but know its location and description of what it plugs into, you will be able to figure it out.
Thanks for all the help!
On my 3.0 V6 engine its extremely hard to get cranked. . . . sounds like it wants to as soon as you turn the key but doesn't. . . . if I do get it cranked it only last for about 5 minutes, and and can't give it any gas or it will turn off?
Just figured I would throw the question your way.
He said his truck was very hard to start, but after starting would run for a minute or so, then die.
If the fuel safety cutoff is set or bad, the engine would never start, right? So, that can't be the problem.
How tough/expensive would it be to replace engine?
thank you
WHAT DO I NEED TO DO TO MAKE THIS CHANGE WORK ... PLEASE HELP , I WOULD LIKE TO GET THIS THING IN BEFORE WINTER COMES...
THANKS,
GRUMP
I 'am In Need Of Some Help Here ...I Have a 1983 Ford Ranger 4x4 With a Bad 2.3 Carbured Motor ... I Just Purchased a 1988 Ford Ranger 2 Wheel Drive With a FI 2.3 Engine In It.......I Would Like To Swap Out My 1983 Carbured Motor For The 1988 2.3 FI Engine ...
What Do I Need To Do To Make This Change Work ... Please Help , I Would Like To Complete This Before Winter Comes .
Grump
:confuse:
Thanks Again ,
Grump
:confuse:
