Ford Ranger 4x4 Problems
124
    thomas60thomas60 Member Posts: 1
    i waswondering if u ever figured out your problem, i have a 91 4x4 ranger with the same exact problem. any help would be appreciated. tmorton@ncdrilling.com
    bears123bears123 Member Posts: 2
    I purcahsed a set of manual lockking hubs for a $164.00 from Tellico 4 x 4 and installed them and everything works great. I have to manully change them when I want 4 wheel drive but at least I have 4 wheel drive now
    cschwartz2cschwartz2 Member Posts: 15
    Get your 4x4 control module checked. That was my 4x4 problem. Works great now.
    ugly_gremlinugly_gremlin Member Posts: 1
    I have a dilemma. According to my VU meter the voltage making it to my fuel pump is about 8.5 volts compared to the 12.5 volts at the battery. I don't understand where the missing 3.5 volts are going to. I tested the fuel pump it works fine. I checked the fuel interia switch, which is also fine. and I replaced the fuel relay switch under the distribution box located in the engine, just to be safe.
    this really isn't related but the fuel filter was also replaced.
    One day while driving down the road the truck just quit on me... I didn't lose power the pump just stopped pumping. At first I thought I needed a new fuel pump, but like I said it works fine. I'm apparently short on voltage by 3.5 volts.
    Is anybody aware of this problem ever happening and if so what caused it?
    bolivarbolivar Member Posts: 2,316
    Lots of problems on Rangers with the fuel pump relay. Bad contacts inside might let the pump still work or be dropping some voltage there. The relays are usually beside or inside the fuse box under the hood. There are from 1 to 3 identical relays there. You can swap them around, but a new relay is only about $25.
    You did not take the measurement with the pump running, did you? This might not show total voltage since some would be dropping across the pump when running.
    avalonjaxavalonjax Member Posts: 2
    hi, i have had the EXACT problem!..my dad was a ford service manager for 35 years..
    he put his best mechanics on it..they heard NOTHING...oasis compute..told them Nothing...!..after.consulting many more knowleageable mechanics, and specialists..still nothing!...finally my dad rode with me and heard it....I test drove with a local mechanic...and sure enough it bogged down after the "thump" sound in the sand...he replaced the engager motorr..This .only made it worse. Afer that, they completely broke down my transfer case and front differential....he could find nothing wrong there!..PLEASE let me know if you were ever successful in getting this fixed...and especially, what was wrong!,, and how they fixed it!...at this point i would just be happy knowing what has broken!!
    prayerhikerprayerhiker Member Posts: 12
    I ended up Changing the Plugs & Wires out. That seemed to Help. Lugging Down. I haven`t used the 4x4 Since Winter Time. I did try it in the Spring but I was on a Rough Road. I couldn`t Tell. I will have to Check it Again before Winter. I will let you Know soon if it is OK . Have a Great eve.
    bluestratbluestrat Member Posts: 10
    if you have auto lockouts on the front axel, that is most likely problem. get manual lockouts and problem should be solved.
    if you have auto locks outs on the front axel, that is moslt likely the problem. the auto ones are infamous for that. install manual lockouts.
    fluid is over filled or you have a plugged filter
    if you have auto locks outs on the front axel, that is moslt likely the problem. the auto ones are infamous for that. replace or the better choice ... install manual lockouts.
    if you have auto locks outs on the front axel, that is most likely the problem. the auto ones are infamous for that. replace or the better choice ... install manual lockouts.
    adesjardinsadesjardins Member Posts: 1
    I have a 94 ford ranger. The 4-high works great but will not go in low range.
    no lights light up and does not engage.
    zapper5zapper5 Member Posts: 1
    I Keep Getting A Code On My Scanner Showing A #4 Cyl Misfire, Truck Runs Rough, I Changed Wires & Plugs, Helped For Awhile But The Problem Came Back? No Oil On Plugs Cyl Pressure Good?
    gyver22rgyver22r Member Posts: 4
    have you tried replacing the ignition coil pack? that could be where the problem is.
    I am having problems on the electrical part of the 4x4 last night the 4wd worked perfectly when i got home the dome light and the 4wd stopped working. fuse on the panel keeps blowing everytime i replace it.checked all the wires from fuse box to the 4wd actuator and also the transfer case.no wires broke. everytime the electronic 4wd box is plugged up it blows the fuse and still doesnt have a working dome light. is there a relay or something that im missing?
    todd98rangertodd98ranger Member Posts: 1
    I havge a 1998 ranger 4x4 with auto locking hubs. The issue I have that seems to differ from most that I have read in this thread is that I am able to engage my 4x4 each time I turn my knob to a 4x4 position (with a clicking followed by a clunk if moving or quietly if not moving) but, it will disengage on it's own within a short distance without any sign of disengagement. I can test it by turning the wheels sharply or stopping and then giving gas. I'm close to ordering the manual lock outs but, wonder if this may sound more like a vaccum issue to someone with more experience. Any help would be greatly appreciated.
    nick9388nick9388 Member Posts: 2
    did you ever get this fixed my 07 is doing the same thing in 4x4 it feels like im hitting a big pot hole every15sec or so?
    I have a 07 ford ranger xlt 4x4 and any time im in 4 wheel and driving it feels like i am hitting large bumps or pothole that arnt there. its like a thud or thump that i can hear and feel dosnt do this at all in 2 wheel drive and also im am not driving on dry pavment this is on icey and snow covered roads. This is not just a little thump or thud its loud and hard this isnot a normal 4x4 noise or feel i have always had 4x4 trucks and never nothing like this.
    Any help would be great need to get this fixed roads are bad here. thank you
    I had same problem...no answer to problem we were going to replace xfer case.......I ended up buying new truck
    lostinconfusedlostinconfused Member Posts: 1
    I have the same problem on a 2000 Ranger do You have any advice?
    Good evening,
    It`s been a While since I was here Last... I have an 06 Ranger. It`s winter in Pa. again. So the Ranger is acting up again. I changed the Plug wires. Frequent oil changes. Only use 4 wheel when I Really need it. It seemed to run Fine during summer off Road. But when it`s blowing & drifting snow . It started again this week. Feels like you are hitting Bumps or sticks in the Road when the Road was clear . On a good note it will engage in 4 Hi & 4 L ... We do not have a Garage to work on it at home. My 98 Ranger did not do that. so what Changed during those years . The bugs should be worked out by now. Let me know if you figure it out. Prayerhiker
    When it is in two wheel drive it feels like that?? Or 4 wheel drive? Mine will feel like that when the road is clear and I am making a turn in 4 wheel drive.
    Good Evening ...Today the Roads were clear. No snow . I put it in 4 Hi on the way home and it started again after about a mile or so. It only happens in 4Hi . I was going to stop at the Ford Dealership to have them check it again on Fri. but I`m sure I`ll get the same Response. We can`t find any problem. so I drove by.... I drive it every day and you know if there is a problem/ funny noises etc. My wife even noticed it last winter. We are to get more snow in Pa. by Wed- Thur. Maybe I will request to go and drive with the Mechanic and point it out when it happens... if possible. Just frustrated when your paying for a quality Truck you expect the 4 wheel to work . Prayerhiker
    do you by chance have the vaccum pulse auto locking hubs?
    ttpttp Member Posts: 1
    What year is your truck? I have a 2000 xlt ranger and it was not designed to run in 4x4 on clear roads. Due to the front axle design the diff does not allow one wheel to spin faster or slower than the other which can cause it to buck and cause damage to the truck.
    Good evening, Replying to cschwartz2
    I have a 2006 Ford Ranger 4x4 . It still feels like it Bucks or hits bumps that are not there. on snow Covered Roads or Dry Roads. That should not be an Issue . Lets say it snows 4" and You pull off and engage the 4Hi and it starts doing that again. When I first bought the truck 2 years ago . Used & Low mileage . It did not do That at all. So what Changed? I only use the 4x4 when I really need it. Some times the Front locks up. If I do not take it out of 4Hi and Use the Emergency Break. Now I just park it in Gear / 2wheel I don`t seem to be getting any answers to this Problem. It runs fine in 2 wheel. It has been very Frustrating to find an answer. PrayerHiker
    Mine is a 2002 xlt. That is odd. Mine is a automatic. Maybe that has something to do with it, possible not fully engaging for some reason. Before mine locks in totally it sometimes grinds or will have a hard time moving if going slow(5 MPH). But it will engage and be fine. My truck has 68,000 miles, What does yours have? Have you had anybody look at it? Have someone also check your 4x4 control module. Small brain on passenger side under kickpanel that controls 4x4. Mine was shot costed 200 to replace it. Works perfect again. Good luck!! Also, I'm tired of my small truck! Anyone want to buy it!
    enriquesalasenriquesalas Member Posts: 1
    Mine does the same thing I have a 2000 ford Ranger 3.0 4x4 and I need help, and I don't know why is doing that. Can somebody help?
    vicc24vicc24 Member Posts: 1
    my 06 ranger does the same thing,have an appointment thurs. hope my garage is better at figureing this out.......
    Good Evening vicc24,
    Let me Know what You Find Out. I had to use my 4x4 this week and it was still bucking or feels like you hit Bumps that are not there. I use the Truck for Work and I need to get there on the snow days. Keep me posted on what you find out. I have an 06 Ranger about 58,000 miles on it. PrayerHiker
    fastgtfastgt Member Posts: 1
    I have a 4wd 93 ranger. my 4wd works but the problem i am having is when im in 2wd driving down the road the front diff acts like its trying to lock in 4wd. if i come to a stop it will grind and thump. when i take off it grinds, if i push the 4wd button it locks in and its fine, push the button to go to 2wd and its fine. it acts up every now and then. anybody have any suggestions or fixes.
    bradley8688bradley8688 Member Posts: 1
    i have a 2000 ford ranger xlt and i can turn it over to 4 high and low and and light comes on and you can hear noises to it like it kicks in but it dont kick in at the wheels i have to take the wheel caps off and take the boot off and lock it in myself its like its somethin with the suction not kickin it in and out..anyone know anything let me know plz..thanks
    habesthabest Member Posts: 1
    Im not the greatest with the knowledge of things so help me out. My ranger died today on the side of the road after a huge pope, it seemed to start to slow down then it poped and started to clank alot, i pushed clutch in and engine stayed running when i let clutch out it dosent go anywhere. any ideas? 2.9l 1991
    budyzer72budyzer72 Member Posts: 2
    I have a ford ranger xlt 2000. which way do you turn the tooth gear to tighten up the emergency brake..also is it opposite on each side or do you turn them the same way on each wheel???
    sounds like you blew the clutch...sorry
    Emergency brake? Most have an 'turnbuckle' type adjuster in the single cable running back, before it splits into two cables.
    I think you are talking about the 'star adjuster' on rear drum brakes for the automatic adjustment? Where you put a tool or screwdriver thru a slot on the back plate and move it up/down? I never know which way to turn these, you just have to pull the drum off and mess with it to see which way tightens the bands (screws the adjuster out). Then remember after you put the drum back on. If this adjuster is 'close', backing the truck up and stopping it multiple times will make this auto adjuster put the bands into adjustment. If it's overly loose, you will not have any rear brakes and it would take forever backing up, so in this case you do have to do a manual adjustment/tighten thru the slot.
    Want to hear a good story on my POS 02 Ranger XLT 4X4! Well I have been trying to fix my odometer for quit a while now. Put in new worm gear, put in new transmission speed sensor, and still not working. Today I am going to purchase a used cluster with about how many miles my truck should have on it. Also my timing chain guides need replaced(LOTS of chatter), my ABS breaks kick on when I am almost to a complete stop(needs new hub), and it needs new lower arm bushings on passenger side(LOTS of squawking!). Oh it is also stalling when I put in reverse(new spark plugs needed).... I LOVE my POS Ranger!!!!
    the speed sensor on a 99 ranger is located in the rear axle,not sure on a 02 model hope this might help.
    10 year old truck. Give it some love, do the maintenance it needs.
    I will, but all these parts plus labor is very costly. Even with a friend mechanic doing all the labor. It was $440.00 just for the timing chain kit at Autozone... I will fix it all and wait for the next thing to break on it. I could understand if I beat on the truck, but I baby it. My friend has a rolled over(not odometer roll over) ranger same year as mine and his runs like a champ and he BEATS on it, weird. I will not ever buy another Ranger. I think I am going to go diesel next and atleast get better gas mileage.
    And pay 20% more for diesel.
    I would pay a little more for the diesel, but I would get better gas mileage than my Ranger Danger.
    jegs74jegs74 Member Posts: 1
    can any help me i got a 99 ford ranger and im not getting any response from my 4x4 selector on the dash and no power to the shifter motor when i plug the motor in the plug coming out of the cab.. i check every single fuse, and both my 4h an 4l indicators on my dash keep flashing . and im stumped. and after i check all the fuse now i have no turn signals and my key chime wont go off. so i could really use the help.
    I would go through your fuses again to get the key chime and signals to work correctly. Possibly you mixed a couple of the fuses. They take the specific fuse for a reason. For your 4x4 I would check the 4x4 control module. Have a ford mechanic or someone with brains on fords to check it. Good luck
    jsiegristjsiegrist Member Posts: 2
    06 Ranger 4x4, when driving in a straight line I get a whining noise that sounds like very bad tires, when taking a long sweeping curve to the left the noise ceases. A friend tells me it's the RH wheel bearing, someone else said they are a bear to replace. Any advice would be most welcome. I'm fairly good at auto repairs in general.
    I would replace the whole right hub. Couple hundred maybe to do it. If you replace the whole hub you won'r have to worry about your ABS sensor or anyother sensor down there going bad for a longer time than just changing the bearing.
    Thanks so much for the advice, so I take it you have seen this problem & resolution previously?
    rfaris81rfaris81 Member Posts: 1
    Ken, did you ever figure this out?? I have this same problem right now. Can you help? Thanks
