They only have 2003 Forester XS: 60.2.
I guess Cayenne showing a good number for its weight. The comparable MB ML63 AMG 64.4: huge difference from its 'inexpensive' sibling ML350: 57.5
Surprised that Murano performs so low: it looks sportier.
Must be the tires.
I own a Toyota and a Subaru and I'll be the first to say the Subaru handles 100 times better.
The numbers don't tell the whole story. Intrusive stability control would also seriously limit slalom times.
Does anyone know if Edmunds tests with the VSC off, if so equipped?
http://blogs.insideline.com/straightline/2009/10/il-track-tested-2010-mitsubishi- -outlander-gt.html
I'm sort of disappointed they didn't offer the dual-clutch transmission, I recall in 2007 Mitsubishi said it would come. They must have cancelled those plans.
Looks like Mitsu bumped HP to 230 and put on 18" rims. That explains the good slalom numbers - those must be very low profile tires.
0-60 in 7.9 is also a nice improvement, I watched this comparo video yesterday and they said their Outlander took 9 seconds:
http://www.edmunds.com/insideline/do/VideosTypeIndex/type=Crossover#74
Middle of the page, under Comparison Tests, "2007-2008 Compact Crossover Comparison Video".
It also took 4th place out of 4 competitors.
Time for a rematch?
Actually the 2007 Outlander XLS is also equipped with 18" tires.
According to the article, 2010 Outlander GT was tested with pretty standard tires:
Tire Size: 225/55R18
Tire Brand: Goodyear
Tire Model: Eagle LS2
Tire Type: All-season
Mitsubishi explanes improved handling:
More Aggressive Handling
With the Outlander already one of the best handling SUVs on the market, engineers had a great base from which to begin. Slightly lower with the use of a shorter and stiffer suspension, the Outlander GT lends a menacing and race-bred look...
Super All Wheel Control (S-AWC)
Merging Mitsubishi's experience in off-road and rally racing with production car development, the Outlander GT features the revolutionary Super All Wheel Control (S-AWC) system. More than just four-wheel drive, S-AWC is a handling system that provides increased handling, traction and stability...
Utilizing a first-in-class active front limited-slip differential and an electronically controlled 4WD coupling, S-AWC can prevent wheel slip between front to rear and side-to-side to enhance tire grip. To the driver this translates into greater traction through all types of terrain and inclement weather, including ice, snow and rain. By measuring throttle input, wheel speed, engine output, steering angle, gear selection, acceleration and yaw rate and combining that data with input from the Active Stability Control (ASC) and Anti-Lock Brake (ABS) computers, S-AWC can accurately detect driving conditions and adjust accordingly. With S-AWC, the Outlander GT can turn tighter, find traction and is more stable during cornering...
My impression that yes, they test slalom with VSC off, if it could be disabled. Quote about FJ testing:
"Toyota's Vehicle Skid Control severly hampers at-the-limit handling maneuvers in both the slalom and skid pad tests. Most intrusive in the radical transistions encountered during slalom testing, VSC significantly limited slalom speed through brake application and throttle reduction. *Because Toyota doesn't allow disabling of its stability control system, editors elected to eliminate the slalom test from performance scoring in this comparison."
http://www.edmunds.com/insideline/do/Drives/Comparos/articleId=115472/pageId=972- 60
The EVO has S-AWC so I wonder how much the systems have in common.
It goes from being way too intrusive (can't climb my driveway with an inch of snow) to being just about right (you don't notice unless it's intentional).
It's never all the way off.
The front and rear wheels are powered by two electric motors that total 60 kw, and there is a 1.6 L gas engine that can both power the front wheels and act as a generator. All of the driving configurations are managed by a power control unit and software called the “MiEV OS.”
EV mode can be automatically switched between front wheel drive or 4 wheel rive depending on road conditions. When the battery is depleted to a certain level, the vehicle transforms into Volt-like series hybrid operation where the generator simply provides energy for the electric motors. However unlike the Volt, when power demands become high, the engine can also turn the wheels supplementing the electric motors as a parallel hybrid configuration.
The EV mode range is 31 miles from a full charge, and the car seats 4.
Mitsubishi claims the vehicle will achieve about 117 MPG overall.
Mitsubishi throws in lots of concept auto show goodies, including LED head- and rear-maps; an aerodynamic shell-like metal appearance; seat upholstery that deactivates allergens and kills bacteria; airplane cockpit instrumental panels; and wireless charging for programming charge times. Mitsubishi is also looking to the future when vehicle-to-grid becomes more feasible by creating a “power supply mode” to allow owners to use onboard stored energy to power home appliances—or in the short run to run campsite electricity via a 100-volt AC auxiliary socket.
The gadget list continues with a “multi-around monitor" system using cameras located around the car, and an on-board receiver to receive signals about vehicles or pedestrians in the driver's path. Finally, the PX-MiEV is fitted with an electronically-controlled air suspension that gives the driver the choice of three ride height modes.
Bloomberg reports that Mitsubishi aims to introduce a similar vehicle around 2013.
more picts | dashboard
Any input is appreciated; the dealers are quickly running out of the Santa Fe's apparently.
VCR1
My concern would be fuel economy, that and depreciation will make your TCO higher on the SF.
Drive one - you may find it's worth the extra outlay, but just go in knowing it will cost you a bit more to operate.
Santa Fe is more luxurious, offers V6, better 5/10 warranty and more space, so seems it would serve your needs better. If it costs you little more overtime, you would get your money worth.
(Forester or Outback vs SF)
Hyundai doesn't offer a 4-cylinder 2009 Santa Fe. The GLS (what you drove) uses a 2.7L V6 engine, with 185 horsepower and 183 ft-lbs of torque. It's actually quite smooth to me, even at high RPM, if not particularly quick off the line. For 2010, Hyundai is replacing that engine with a 4-cylinder delivering 200 horses and better fuel mileage.
The manuals have a simple viscous coupling mating the front and rear axles together, acting like a center diff. When one rotates at a different rate than the other, the fluid sheers and thickens, temporarily locking the two axles together. Subaru lets their AWD systems act first, but as a backup there is also a traction and stability control system, to manage traction on each axle (if one side is slipping).
The automatics use a clutch pack to adjust the amount of power sent to the rear axle, and they manage both axles with traction control as well.
Hyundai's system is FWD based and on-demand only, rather than always engaged. It's a pretty basic system, AFAIK.
A bigger factor may be ground clearance and angles of approach and departure, where the Forester broadens its advantage.
A Forester XT (turbo) will easily outrun the much heavier Santa Fe even with the big V6, but the SF is bigger inside so consider your needs carefully. The Subie is CR's top rated small SUV, MotorWeeks driver's choice, and a MotorTrend comparo winner plus their SUVOTY so it's been the darling of the media as of late.
Happy shopping.
Some excerpts:
Most agree that Subaru has benefited greatly from the Forester's 2009 redesign, which earns nearly universal praise from our members.
[sales are] up 35 percent from the same period in 2008. That's mighty impressive considering industry sales were down 27 percent
But most insist that AWD-only is integral to Subaru brand in the U.S. and that if "they start offering FWD or RWD even on just a few models that... brand identity starts getting watered down." One post questions, "Is it worth losing your identity for a 10% gain in fuel economy?" Another argues, "They need to maintain the exclusivity of AWD standard; otherwise... they'd wind up being in the same position as Mitsubishi or Suzuki -- good but overlooked over for having nothing to stand out." And a third likens the potential effect of Subaru abandoning AWD-only to GM overtaking Saab in the 1990s, noting that Saab was "no longer the 'quirky car' once GM homogenized and pasteurized them."
In other words, it appears that the company, like the AWD drivetrain that it is known for, handles great in any kind of weather.
Let's keep in mind, though, the Hyundai is probably 2nd to Subaru in this economy, with sales decreases lower than just about anyone else.
I am quickly coming to the conclusion that the Forester is the best of the bunch when it comes to compact SUV's in the price range I am looking at (around 30K Cdn). Can anyone persuade me otherwise?
That’s easy. The 2010 Mitsubishi Outlander GT is a much better crossover then Forester (and better then anything else in this class):
• 6-speed auto with paddle shifters and idle neural logic vs. dated 4-speed transmission.
• 40 GB mp3 music server vs. nothing.
• Premium 710-watt Rockford Fosgate stereo with 8 speakers + 10" subwoofer vs. generic 6-speaker stereo.
• Sirius satellite radio vs. nothing
• Outlander GT demonstrates spectacular handling: 66.2 mph slalom beating every CUV except for $95K BMW X6M with $500 sport tires.
• Larger 18" tires vs. 17”
• FAST key entry/keyless start (your key is always in your pocket)
• Voice control and Bluetooth music streaming Link System
• Diamond Lane Guidance real-time traffic navigation vs. basic navigation.
• Rear View backup camera. Parking sensors available.
• Superior AWD system with both front-to-back and side-to-side torque control, with Auto, Lock and FWD modes, form the manufacturer of 12-time Dakar champion.
• More cargo space, flap-fold tailgate and 3-rd row seating for kids.
• Rain Sensing Wipers vs. regular
• Xenon Headlights vs. regular
• More horse power and higher towing capacity
• 5/10 warranty + free roadside vs. basic warranty
• Top CR reliability rating.
What Forester could offer instead? Larger sunroof, and that’s about it. It's well build but basic car.
Even with that steering Equinox probably earns the Most Improved award.
Do keep in mind that trailer brakes are required by all major manufacturers for a trailer of that weight. You don't want to end up with the tail wagging the dog.
What's on your short list of choices? I bet most of them have a model that can easily handle that load. Pick something with good torque so you're not struggling up those hills.
Maybe big brakes as well.
The current state of this one just makes me tired, and it was one of my favorites in-spite of me having only sedans in the driveway.
I think some of the last posts can be moved over there and the other one merged or archived.
Here's the link:
Mitsubishi Outlander vs. Subaru Forester
Please continue ... wherever.
The OP asked about the Forester and the Santa Fe, I don't know how we got on the Outlander. My response was on topic.
I'm fine with moving the posts there - that's where this belonged once the Outlander was brought in. In fact I suggest from now on, in any thread, when chelentano wants to recommend the SUV he did not buy that he link to there instead.
Like the Accord Crosstour.
/hint :shades:
An H6 Outback Ltd runs about $3k less, at $31.7k. It's a tad smaller, but probably the best value of the 3.
As usual, Toyota gives you 1,000 a-la-carte optinos. Venza V6 AWD, add Comfort Package for heated leather seats and EJ sound for 6CD/Bluetooth, then SR for the sunroof, and you get $34,240. IMHO it's the best looking of the bunch. Haven't driven it yet but I've heard the huge wheels give it a brittle ride, odd for a Toyota.
http://www.msnbc.msn.com/id/33605151/ns/business-autos/
In short, here is what they have to say about the Venza:
Pros: Comfortable ride, superlative fuel economy for its size, the brand name that makes grizzled baby boomers behave like irrational adolescents
Cons: Insultingly cheap interior, lousy steering, useless automatic headlights
Verdict: Toyota is off its game and needs to refocus on giving customers more than they expect rather than thinking they won’t notice that they are being shortchanged.
Just kidding.
I was under the impression that the ride was not good. Maybe they tested a model with smaller rims?
Also, the interior looks fine to me. It has a padded dash and far better materials than what you'd find in, for instance, the RAV4. Maybe they have much higher expectations in that price range?
I'm not surprised about the steering - my Sienna is number than my Wii-mote. The weight is right, but there is zero feedback.
Also, I do think that the mere volume of production Toyota has can make quality control suffer.
I thought that review was pretty harsh. And how old is that article? He compares it to Pacifica and Taurus X. Venza doesn't even offer a 3rd row.
CR gave it a pretty good score overall, but the Outback scored higher (even though they tested the 4 cylinder OB).
My response was on topic too. Post 7060: user yvr1 posted:
"...Forester is the best of the bunch when it comes to compact SUV's... Can anyone persuade me otherwise?"
So I responded:
"That’s easy. The 2010 Mitsubishi Outlander GT is a much better crossover then Forester... " then I listed my points why.
Midsize SUVs
Dodge Journey
Subaru Tribeca
Volvo XC60
Volvo XC90
Small SUVs
Honda Element
Jeep Patriot with optional side torso airbags
Subaru Forester
Volkswagen Tiguan
The list shrunk substantially because this year they added the roof strength test as a requirement to make it.
* Element has upright pillars, which may have helped.
* Honda said early on that they would seriously reinforce the A- and C-pillars since there is no B-pillar.
http://blogs.thecarconnection.com/marty-blog/1038759_mitsubishi-debuts-sync-riva- l-called-fuse-in-2010-outlander#comments
New Mitsubishi Nav System Includes Free Traffic Service:
http://blogs.thecarconnection.com/marty-blog/1038615_new-mitsubishi-nav-system-i- ncludes-free-traffic-service
SMALL SUVs
Honda Element
Jeep Patriot - with optional side torso airbags
Subaru Forester
Volkswagen Tiguan
It's in alphabetical order. This does not mean the Element won, in fact the Forester's 4.64 strength-to-weight ratio actually beat the Element in the new-for-2010 roof strength test.
Not that it matters, both Element and Forester are Top Safety Picks, and extremely safe choices.
Forester has other best-in-class claims but you'll ignore them anyway so I won't bother listing them.
23 Civic Type-R / 22 MDX Type-S / 21 Tesla Y LR / 03 Montero Ltd
And people in there have been put on notice that all the niggling details are of little interest to most readers. Cabin fever perhaps?
Ok, how 'bout some crossover news?
Deal of the Week: 2010 Infiniti QX56
Or maybe you'd like to dream about one we don't get in the US:
Inside Line (In the rest of the pics it looks more like the compact car it really is).
This is more like it - but it's another one we don't get in the States:
2011 Mitsubishi RVR
