I was wondering if anyone knew how much this may cost me to fix?
Any help will be greatly appreciated.
Doug
I took my car back to my mechanic today, explained the continued problem, after checking the break system out completely and replacing the pads, turning the rotors, bleeding the lines, he thought I would be happy. To his disappointment I told him I noticed no change when test driving my car. He is stumped!
If anyone has any ideas please let me know.
My ABS light does not light up when I start my car which from what I understand could mean that it is either faulty or I do not have ABS.
Thank you for your help.
Thank you for checking my vin number. I have had my brake lines bled 3 time in the recent past. 1 when I had the complete break job, 2 when master cylinder was replaced, 3 yesterday after another brake job, and my mechanic checking for any other problems he could find. It is so frustrating.
Rt. Ft. Caliper #YL8Z-2V120-ABRM ($99.37)
Lt. Ft. Caliper #YL8Z-2V121-ABRM ($70.30)
Proportioning Valve #YL8Z-2B091-BA ($55.12)
Power Booster #YL8Z-2005-AA ($210.07)
These part numbers are specific to your Escape and those are its MSRP's
thank you for any help! :confuse:
Were you by any chance accidentally driving with your parking brake applied, even just slightly? Other then that and having the parking brake adjusted too much would cause the smoke and brake burnt smell.
At 36, 600 miles the master cylinder went out. Brakes squishy, would not hold until pressed almost to the floor, very scary. Some surging and acceleration preceeded this problem. I took it in to the dealer, they said the computer said it was the master cylinder, which they replaced to the tune of $1,800. The car was just off warranty.
This sucks. I am dubious about Ford escaping liability for replacement of that cylinder and braking.
Here is my question: HOW LONG SHOULD A MASTER CYLINDER LAST?
I live in Seattle, WA., if that makes it different from South Dakota. Hilly, but not exactly like San Francisco, and in the normal course of driving my routes are pretty flat. Any info about similar issues with your Ford Escape and any basic car knowledge about how long a master cylinder should last would be very helpful! Thanks.
Michele
Hope this helps!
FORD suck not being able to pin point the failure and letting consumers drive these vehicles, talk about Toyota having issues!
Good luck, I hope yours doesn't re occur like mine. I am lucky as mine is a company car and we change @ 65k, 1k more to go whoo hoo!
I have a 2006 Escape Hybrid with 101,000 miles. The ABS Hydraulic Control Unit went out. OK, 101,000 miles. I can see something going out. The dealer said the replacement part was $4,500 plus 4 hours of labor for installation. I paid $29,000 for the car. If you back out transportation, Dealer profits and overhead costs and Ford profits, SG&A, advertising, etc, I can't imagine the direct material cost on the car when sold was more than $20,000. And this one stinking part - which can only be bought from Ford - is $4,500. It's criminal what they charge. So, sorry about the Master Cylinder, but it could have been worse.
At least I received a nice form letter reply from Ford when I complained about a part costing $4,500 though. I mean, no money or recognition that they were screwing their customers, but a nice form letter nonetheless.
did the master cylinder fix your problem?
I have put 2 master cylinders, front calipers, front flex lines, front pads and rotors, rear wheel cylinders and rear shoes and I'm STILL having this problem. tha car will have good brakes for a couple of weeks and then one day i go to stop and the pedal goes right to the floor just like i blew a line. i come home crack the bleeder screw on the left front caliper get some air out and i'm good to go for a couple more weeks. the funny part is the brake fluid never goes down. even when i loose the brakes the level is still right on full.
if someone can help please send advice, before i drive this thing to the scrap yard!
I searched and don't see any recalls. Does anyone have any info on this and is there a way to correct it on my own?
The emergency brake was pulled all the way up (Between the seat brake) and the manual transmission appeared to be in 1st gear at the time. (When I checked, I had to move the stick-shift down slightly before it "popped" into neutral but, I'm guessing it must not have been completely in 1st gear.....either that, or it had popped out ? ??) Who know's - probably operator error there but, the E-brake clearly didn't perform it's job. Especially being the grade was so slight. Thank God, nobody was hurt! and, lucky for me.... no damage to either car.
Lastly, you need the new mechanic to adjust your rear shoes. Your e-brake handle should have resistance and only go up about 1/4 of the way up.
Good luck!
I am grateful the only injury was caused to the pole he crashed into. The air bags did not go off either.
I ultimately resolved a long conflict about my vehicle (FEH 06). I used it as trade-in on a Focus. I'd filed a failure report with DOT previously. I'm sure any glitches with the brake system will get repaired under the warranty for the new owners.
After a quick search of Edmunds.com forum, I found a couple other people with this problem, but they were just asking about how to repair and not if this is an ongoing issue. I think this must be an ongoing issue. What say ye others?
I had a 1997 Ford F150 that I drove for 13 years prior to owning the Escape and experienced the same brake problem your wife experienced. Ford first claimed it was the mats getting up under the pedal (they were the factory ones!) but then they replaced something to do with the speed control tied to cruise a few times on it and I believe there was a recall with the issue...it could catch on fire.
Sad to say, but I've learned to just keep a journal in my car writing down the date and time of everytime the issue happens. Figure if I'm ever in a bad accident it's documented by me as well as at the dealership.
