Mercury Villager Noises
I have a 99 Mercury villager Estate. When I press on the gas after coming to a stop, I hear (and feel under the front of the van) a thumping noise. Sometimes it is only one thump, sometimes a couple. What could this be?
Shannon
Shannon
Initial Diagnostic gave them no answers, so did what they needed so ‘codes’ would come up….they cleared those and got a “3rd gear” something not doing its job. {that’s what the man said and to him and the others, it made no sense} SO…the Cap and rotor were replaced…all 6 plugs {not wires} replaced. [Wires are fine, they allege.] Changed oil and filter, don’t know why. Checked timing marks -- there fine. Removed oxygen sensor from converter, didn’t make a difference. Tested the distributor, alleges is fine. They Changed the Ignition Coil. Voila! NOT!!!
When the coil was changed, she fired up, and they said yeah! Drove her out of the bay, and assumed it was fine. When I arrived to pick her up, she started, idled for a few minutes. As I was about to leave, put her into ‘drive’ and she sputtered and shook again. Then she stalled out. She turned over 2 more times, but was still misfiring. Then she stalled out and wouldn’t restart. They haven’t a clue as to what to do next. I want my baby back. I am concerned, especially when the main mechanic said he’s never seen a Nissan engine inside a Mercury Villager. EXCUSE ME!??! What kind of mechanic do I have? Be that as it may, she’s still not working. I offered up the “Possibility” of the alternator having an issue. They said no way, since it has nothing to do with the electrical system. Can you POSSIBLY offer suggestions to ‘what else it could be’? May be I could call the mechanic and pass on your advice. Don’t worry, I won’t be taking her back to them EVER. Need a mechanic whom knows what their doing. Please Help!
Has anyone experienced this noise?
also it help to park on a hill with the cap side of the radiator on the high side.
Is this in fact a tappet issue? How difficult are they to change? How much are they?
Any insight on the oil leak?
Both of these issues started close to the same time, right around 100,000 miles. It now has 108,000.
Thanks for the help
I've got the same issue. I think it's the hydraulic lifters... and it takes some time to heat the oil up. I switched the oil to a full synthetic.
Regarding that oil leak... It could be the oil pressure sender (switch). Mine was leaking onto the oil filter...which made me think it was the gasket around the filter that was leaking. After installing a new filter...it still leaked. Then I noticed that the pressure sender was leaking. I got a $8 pressure switch from Autozone, and installed it with teflon tape....NO more leaks!!!
