Honda CR-V Power Window Problems
The front passenger power window on my CRV wont go down. I've changed the motor; replaced the switched and it still wont work. Can anyone help?
Recently, my 2002 CR-V front left side power window stops working. I tried both the driver side control button and the button on the door. Just nothing happened. (no any motor noise) All other windows are ok. Actually, this happened in one trip on my way home one month ago. It was good at the beginning and became not working when I got home. I did nothing during the trip.
Could anybody tell me what's the possible reason? And how to check it?
If your handy you can tackle it,otherwise,a dealer,or trusted mechanic.
Check the owners manual, I think there is a procedure to program the auto window feature.
If she had an owner's manual she probably wouldn't be asking for help here.
SUVs and Smart Shopper
How To Find Your Car Owner's Manual Online
Any suggestion what is going wrong?
http://autorepair.about.com/library/a/1i/bl830i.htm
Good luck!
I have an 06 CRV with an issue similar, but not the same as some others here. From the driver’s seat the master power window switch won’t move the front passenger window up or down. It will control the other windows. Also note that from the front passenger seat the window can be controlled.
I’ve had the master power window switch replace per recall by a dealer. Still the right front window won’t go up or down from driver seat, but it will go up and down from the passenger seat.
So it’s not the switch and not the window motor. Any suggestions?
What are the common problem if the battery installed wrong way? Negative to positive and positive to negative.
