GMC Jimmy Why so many problems?
I have a 2000 jimmy purchased with 32,000 miles 4 years ago. The manifold intake was replaced at 36,000, the recliner seat handle broke off early on. It now has 53,000 miles ( I drive 5000 a yr. as a retiree). At 52,000 the ABS brakes failed and the module and master cylinder were replaced for $479. This did not solve the problem so the ABS system was disconnected. At 53,500 I heard noises underneath and Belle Tire replaced the wheel bearings to repair the ABS's, ball joints. shocks, calipers, rotor, and alignment to the tune of $1,900. What is going on??? He said it's because I have a GMC, or is it because I am a woman???? How can all of these things go wrong at once???
If 4wd the lower ball jointrs are a known problem area but 2wd no way. Shocks are Bilstins and my 4 Blazers have over 130k and all originals. If brakes done then yes calipers are good (rears a must but fronts optional but most shops do all as ensures no returns).
So, look thru the posts and you will see many other things upcoming as the beast ages - These are not low maintenance vehicles. If you have not had that coolant changed do so now and have the thermostat replaced and get a new Stant cap - that should save a few worries. At some point get the trans filter/fluid done (simple drop pan at $100 and don't pay for a full flush of the trans only extra $$ for them). If 4wd do the transfer case too and if the 4 button Autotrac case requires blue syn fluid so a dealer might be good on this. If fact a dealer may have saved you $$ as they have the experience with these and the local shops mostly (not all of course) go with the max work and common things. Last that ABS should be easliy fixed by a dealer - anything else is just bull. Good luck.
I don't have time to add up what I've spent on this piece of junk. I have replaced so much especially wheel bearings, ball joints numerous times as well as the brakes, front & back. The emergency brake has never worked. It would take me hours to let you know all that has been replaced. It's unreal how much money I've spent, I should be driving a BMW by now. WILL NEVER EVER BUY ANOTHER GMC VEHICLE. BIG DISAPPOINTMENT
